[GeoNetwork-users] GeoNetwork 4.0.5.0 facets and categories
Dear colleagues,
I’ve just release a new version of our renewable energy community catalogue with the V 4.0.5.0 version of GeoNetwork.
It is accessible here:
http://geocatalog.webservice-energy.org/
I would like to customise the frontend with facet approach as presented here:
https://geonetwork-opensource.org/manuals/4.0.x/en/customizing-application/configuring-faceted-search.html?highlight=facets
Unfortunately I tried several configuration options and did not managed to end-up with such options both for look & feel with colors and icons and as well for traduction of the categories.
Would someone having implemented such features could kindly shared the needed facets code sections to help me doing so.
As an example (if hopefully relevant) I share my current Facets configuration:
  "inspireThemeUri": {
    "terms": {
      "field": "inspireThemeUri",
      "size": 34
  "cl_topic.key": {
    "terms": {
      "field": "cl_topic.key",
      "size": 20
  "cl_hierarchyLevel.key": {
    "terms": {
      "field": "cl_hierarchyLevel.key",
      "size": 10
Thanks a lot in advance for your support.
Best regards,
Lionel
Lionel MENARD, MINES ParisTech CS 10207 F-06904 Sophia Antipolis France Tel +33 493957423
I think you more need to follow
https://geonetwork-opensource.org/manuals/4.0.x/en/administrator-guide/configuring-the-catalog/inspire-configuration.html?highlight=inspire
You need to enable INSPIRE in the settings, load the inspire themes
thesaurus, then try to add in the editor an inspire theme keyword from the
thesaurus to one metadata.
If it works correctly, you should see the colored entry points in the home
page, and then entries in the facet panel of the search page.
Good luck.
On Thu, Jan 13, 2022 at 6:04 PM Lionel Menard via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Dear colleagues,
here:
configuration:
    "terms": {
      "size": 34
  "cl_topic.key": {
    "terms": {
      "size": 20
    "terms": {
      "size": 10
Best regards,
Lionel
Tel +33 493957423
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
*Technical Leader - Architect*
+33 4 58 48 20 36
