[GeoNetwork-users] Geonetwork 4.0.6 K8S deployment with Elasticsearch, Kibana and PostGIS
Dear all,
I am trying to deploy GeoNetwork 4.0.6 on Kubernetes with Elasticseach and Kibana support.
I've basically adopted the configuration on docker-compose.yml for GeoNetqork 4.06 on DockerHub and translated it into a K8S manifest file.
Here you are the most important pieces of K8S yaml file:
apiVersion: apps/v1
kind: Deployment
metadata:
   namespace: geonetwork
   labels:
     app: geonetwork-depl
spec:
   replicas: 1
   selector:
     matchLabels:
   template:
     metadata:
       labels:
     spec:
       initContainers:
         - name: check-db-ready
           image: postgres:9.6.5
           command: ['sh', '-c',
             'until pg_isready -h postgres-svc -p 5432;
             do echo waiting for database; sleep 2; done;']
       containers:
         - name: elasticsearch
           image: elasticsearch:7.11.1
           ports:
             - name: elastic-srv
               containerPort: 9200
               protocol: TCP
             - name: elastic-cluster
               containerPort: 9300
               protocol: TCP
           env:
           - name: ES_JAVA_OPTS
             value: -Xms1G -Xmx1G
           - name: discovery.type
             value: single-node
           volumeMounts:
             - mountPath: /usr/share/elasticsearch/data
         - name: kibana
           image: kibana:7.11.1
           ports:
             - name: kibana-srv
               containerPort: 5601
               protocol: TCP
           env:
           - name: SERVER_NAME
             value: kibana
           - name: SERVER_HOST
             value: 0.0.0.0
           - name: ELASTICSEARCH_HOSTS
             value: http://127.0.0.1:9200
           - name: SERVER_BASEPATH
             value: /geonetwork/dashboards
           - name: SERVER_REWRITEBASEPATH
             value: 'false'
           - name: KIBANA_INDEX
             value: .dashboards
           - name: XPACK_MONITORING_UI_CONTAINER_ELASTICSEARCH_ENABLED
             value: 'true'
         - name: geonetwork-core
           image: geonetwork:4.0.6
           ports:
             - name: tomcat-http
               containerPort: 8080
               protocol: TCP
           env:
           - name: DATA_DIR
             value: /catalogue-data
           - name: JAVA_OPTS
             value: >-
               -Dorg.eclipse.jetty.annotations.AnnotationParser.LEVEL=OFF
               -Djava.security.egd=file:/dev/./urandom -Djava.awt.headless=true
               -Xms512M -Xss512M -Xmx2G -XX:+UseConcMarkSweepGC
               -Dgeonetwork.resources.dir=/catalogue-data/resources
               -Dgeonetwork.data.dir=/catalogue-data
               -Dgeonetwork.codeList.dir=/var/lib/jetty/webapps/geonetwork/WEB-INF/data/config/codelist
               -Dgeonetwork.schema.dir=/var/lib/jetty/webapps/geonetwork/WEB-INF/data/config/schema_plugins
           - name: GEONETWORK_DB_HOST
             value: postgres-svc
           - name: GEONETWORK_DB_PORT
             value: '5432'
           - name: GEONETWORK_DB_NAME
             value: geonetwork
           - name: GEONETWORK_DB_USERNAME
             value: geonetwork
           - name: GEONETWORK_DB_PASSWORD
             value: XXXXXXXXXXX
           - name: GEONETWORK_DB_TYPE
             value: postgres
           - name: ES_HOST
             value: 127.0.0.1
           - name: ES_PROTOCOL
             value: http
           - name: ES_PORT
             value: '9200'
           - name: KB_URL
             value: http://127.0.0.1:5601
           volumeMounts:
             - mountPath: /catalogue-data
             - mountPath: /tmp/geonetwork-web-inf/config-security/config-security.xml
               subPath: config-security.xml
             - mountPath: /tmp/geonetwork-web-inf/config-security/config-security-ldap-recursive.xml
               subPath: config-security-ldap-recursive.xml
             - mountPath: /tmp/geonetwork-web-inf/web.xml
               subPath: web.xml
             - mountPath: /tmp/geonetwork-web-inf/encryptor.properties
               subPath: encryptor.properties
             - mountPath: /usr/local/tomcat/conf/
             - mountPath: /usr/local/tomcat/conf/Catalina/localhost/
           lifecycle:
             postStart:
               exec:
                 command:
                 - "/bin/sh"
                 - "-c"
                   cp -f /tmp/geonetwork-web-inf/config-security/* /var/lib/jetty/webapps/geonetwork/WEB-INF/config-security/;
                   cp -f /tmp/geonetwork-web-inf/web.xml /var/lib/jetty/webapps/geonetwork/WEB-INF/web.xml;
                   cp -f /tmp/geonetwork-web-inf/encryptor.properties /var/lib/jetty/webapps/geonetwork/WEB-INF/data/config/encryptor.properties;
       restartPolicy: Always
       volumes:
The deployment seems to go fine and I can login into GeoNetwork GUI using my LDAP credentials, but when I click on "Content Statistics" in "Admin Console" -> "Statistics and status" I cannot see Kibana dashboard in the frame, and if I capture the request and Tomcat response I see a "frame-ancestors 'none" CSP policy that probably caused the DENY response, here's the full tcpdump capture:
.,.~:4.CHTTP/1.1 500 Server Error
X-Frame-Options: DENY
Content-Security-Policy: frame-ancestors 'none'
Cache-Control: must-revalidate,no-cache,no-store
Content-Type: text/html;charset=iso-8859-1
Content-Length: 7698
Connection: close
Server: Jetty(9.4.45.v20220203)
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1"/>
<title>Error 500 java.lang.NullPointerException</title>
</head>
<body><h2>HTTP ERROR 500 java.lang.NullPointerException</h2>
<table>
<tr><th>URI:</th><td>/geonetwork/dashboards/s/geonetwork/app/kibana</td></tr>
<tr><th>STATUS:</th><td>500</td></tr>
<tr><th>MESSAGE:</th><td>java.lang.NullPointerException</td></tr>
<tr><th>SERVLET:</th><td>HttpDashboardProxy</td></tr>
<tr><th>CAUSED BY:</th><td>java.lang.NullPointerException</td></tr>
</table>
<h3>Caused by:</h3><pre>java.lang.NullPointerException
         at org.mitre.dsmiley.httpproxy.ProxyServlet.copyRequestHeader(ProxyServlet.java:410)
         at org.mitre.dsmiley.httpproxy.ProxyServlet.copyRequestHeaders(ProxyServlet.java:385)
         at org.mitre.dsmiley.httpproxy.ProxyServlet.service(ProxyServlet.java:258)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
         at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1459)
         at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
         at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)
         at org.eclipse.jetty.websocket.server.WebSocketUpgradeFilter.doFilter(WebSocketUpgradeFilter.java:230)
         at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
         at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
         at org.fao.geonet.web.CORSResponseFilter.doFilter(CORSResponseFilter.java:129)
         at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:121)
         at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:58)
         at org.fao.geonet.web.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:110)
         at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
         at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
         at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
         at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
         at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
         at org.fao.geonet.security.AuthenticathedUserFilter.doFilter(AuthenticathedUserFilter.java:17)
         at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
         at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155)
         at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
         at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
         at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
         at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
         at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
         at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
         at jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)
         at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
         at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
         at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
         at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
         at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
         at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
         at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
         at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
         at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
         at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
         at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
         at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
         at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
         at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
         at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
         at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
         at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:191)
         at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
         at org.eclipse.jetty.server.Server.handle(Server.java:516)
         at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
         at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
         at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
         at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
         at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
         at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
         at org.eclipse.jetty.io.ChannelEndPoint$1.run(C
15:59:03.820375 IP 10.104.194.95.8080 > 10.104.126.45.51418: Flags [P.], seq 41412:42239, ack 11213, win 424, options [nop,nop,TS val 3173780606 ecr 976523843], length 827: HTTP
E..o..@anonymised.com@..s
h._
h~-........e`J.....X......
.,.~:4.ChannelEndPoint.java:104)
         at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
         at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
         at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
         at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
         at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
         at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
         at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
         at java.lang.Thread.run(Thread.java:750)
</pre>
<hr/><a href="https://eclipse.org/jetty&quot;&gt;Powered by Jetty:// 9.4.45.v20220203</a><hr/>
</body>
</html>
Moreover, if I try to check Kibana status directly from http://localhost:5601, here's the (404 Not Found) response of the server:
h._.n........e.....p......
g....t.sGET / HTTP/1.1
Host: localhost:5601
Connection: keep-alive
sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="99", "Google Chrome";v="99"
sec-ch-ua-mobile: ?0
sec-ch-ua-platform: "macOS"
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.83 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
Sec-Fetch-Site: none
Sec-Fetch-Mode: navigate
Sec-Fetch-User: ?1
Sec-Fetch-Dest: document
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.9,it;q=0.8
Cookie: ui_language=en_US
16:10:24.327421 IP 10.104.194.95.5601 > 10.0.150.101.52846: Flags [P.], seq 738:1074, ack 2134, win 303, options [nop,nop,TS val 2893412483 ecr 1740641433], length 336
E.....@anonymised.com@...
h._
..e...n..e......../n......
.u..g...HTTP/1.1 302 Found
kbn-name: kibana
kbn-license-sig: 9697c476d1852e065a1ece447ec6b0750345fd95f7440a076084ede030cf68de
cache-control: private, no-cache, no-store, must-revalidate
content-length: 0
Date: Tue, 29 Mar 2022 14:10:24 GMT
Keep-Alive: timeout=120
16:10:24.327528 IP 10.0.150.101.52846 > 10.104.194.95.5601: Flags [.], ack 1074, win 284, options [nop,nop,TS val 1740641445 ecr 2893412483], length 0
E..4y.@anonymised.com@.T.
..e
h._.n........f.....mS.....
g....u..
16:10:24.443800 IP 10.0.150.101.52846 > 10.104.194.95.5601: Flags [P.], seq 2134:2868, ack 1074, win 284, options [nop,nop,TS val 1740641561 ecr 2893412483], length 734
E...y.@anonymised.com@.Q.
..e
h._.n........f.....p1.....
g....u..GET /geonetwork/dashboards/spaces/enter HTTP/1.1
Sec-Fetch-User: ?1
The Elasticsearch service is up and the indexes status is:
$ curl -XGET http://localhost:9200/_cat/indices
green open .apm-custom-link 5Hq-XfZaQgi5IuaomGkyFA 1 0 0 0 208b 208b
green open .kibana_task_manager_1 50YtCkgVTWy7Ka72vKkBJg 1 0 8 849 187.4kb 187.4kb
yellow open gn-features WtDbkOA_Q3SaGkMsBJ0TpA 1 1 0 0 208b 208b
green open .apm-agent-configuration AGPARm6zSViImCE9wAu3TA 1 0 0 0 208b 208b
green open .dashboards_1 VU-xPuDEReKpL0lYX49h6g 1 0 11 0 2.1mb 2.1mb
yellow open gn-records V0wTMf2oQ2qsvLywVMzC0g 1 1 147 0 820.7kb 820.7kb
green open .dashboards-event-log-7.11.1-000001 8iyArYvFS-mviXNVlwTSFQ 1 0 0 0 208b 208b
yellow open gn-searchlogs aIuwpjxTRlSDMCYnj2OxjA 1 1 0 0 208b 208b
Can someone help me to identify the problem in my deployment?
Best regards,
Pierpaolo
I'm not an expert in Kubernetes, but are you sure that ES_HOST and KB_URL
can be 127.0.0.1 instead of elasticsearch and http://kibana:5601 ?
On Wed, Mar 30, 2022 at 3:53 PM Pierpaolo Culurciello via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Dear all,
and Kibana support.
apiVersion: apps/v1
kind: Deployment
metadata:
   labels:
spec:
   replicas: 1
   selector:
     matchLabels:
   template:
     metadata:
       labels:
     spec:
       initContainers:
       containers:
           ports:
             - name: elastic-srv
               containerPort: 9200
               protocol: TCP
               containerPort: 9300
               protocol: TCP
           env:
             value: single-node
           volumeMounts:
         - name: kibana
           ports:
             - name: kibana-srv
               containerPort: 5601
               protocol: TCP
           env:
           - name: SERVER_NAME
             value: kibana
           - name: SERVER_HOST
             value: 0.0.0.0
             value: 'false'
             value: .dashboards
             value: 'true'
           ports:
             - name: tomcat-http
               containerPort: 8080
               protocol: TCP
           env:
           - name: DATA_DIR
           - name: JAVA_OPTS
             value: >-
             value: postgres-svc
             value: '5432'
             value: geonetwork
             value: geonetwork
             value: XXXXXXXXXXX
             value: postgres
           - name: ES_HOST
             value: 127.0.0.1
           - name: ES_PROTOCOL
             value: http
           - name: ES_PORT
             value: '9200'
           - name: KB_URL
           volumeMounts:
             - mountPath:
             - mountPath:
               subPath: web.xml
           lifecycle:
             postStart:
               exec:
                 command:
                 - "/bin/sh"
                 - "-c"
       volumes:
Connection: close
<html>
<head>
</head>
<table>
</table>
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
h._
         at
         at
         at
         at
         at
         at
         at
</pre>
</body>
</html>
server:
Accept:
Sec-Fetch-User: ?1
h._
kbn-name: kibana
kbn-license-sig:
content-length: 0
length 0
..e
g....u..
..e
Accept:
Sec-Fetch-User: ?1
1 0 0 0 208b 208b
1 1 0 0 208b 208b
1 0 0 0 208b 208b
1 0 0 0 208b 208b
1 1 0 0 208b 208b
Best regards,
Pierpaolo
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hello Juan Luis,
yes, Kibana and Elasticsearch URLs are reachable from GeoNetwork container, here's a wget and curl output for their URLS:
root@anonymised.com:/var/lib/jetty# wget http://127.0.0.1:5601
--2022-03-30 15:53:00-- http://127.0.0.1:5601/
Connecting to 127.0.0.1:5601... connected.
HTTP request sent, awaiting response... 302 Found
Location: /geonetwork/dashboards/spaces/enter [following]
--2022-03-30 15:53:00-- http://127.0.0.1:5601/geonetwork/dashboards/spaces/enter
Reusing existing connection to 127.0.0.1:5601.
HTTP request sent, awaiting response... 404 Not Found
2022-03-30 15:53:00 ERROR 404: Not Found.
root@anonymised.com:/var/lib/jetty# curl -XGET http://127.0.01:9200/_cat/indices
green open .kibana_task_manager_1 50YtCkgVTWy7Ka72vKkBJg 1 0 8 28 118.6kb 118.6kb
yellow open gn-features 3rxKeSMvRo2-VZhr5IT5LA 1 1 0 0 208b 208b
yellow open gn-records V0wTMf2oQ2qsvLywVMzC0g 1 1 147 12 1mb 1mb
green open .dashboards-event-log-7.11.1-000001 8iyArYvFS-mviXNVlwTSFQ 1 0 4 0 21.8kb 21.8kb
What else can I try?
Pierpaolo
Quoting Juan Luis Rodríguez Ponce <juanluisrp@anonymised.com>:
Dear all,
and Kibana support.
apiVersion: apps/v1
kind: Deployment
metadata:
   labels:
spec:
   replicas: 1
   selector:
     matchLabels:
   template:
     metadata:
       labels:
     spec:
       initContainers:
       containers:
           ports:
             - name: elastic-srv
               containerPort: 9200
               protocol: TCP
               containerPort: 9300
               protocol: TCP
           env:
             value: single-node
           volumeMounts:
         - name: kibana
           ports:
             - name: kibana-srv
               containerPort: 5601
               protocol: TCP
           env:
           - name: SERVER_NAME
             value: kibana
           - name: SERVER_HOST
             value: 0.0.0.0
             value: 'false'
             value: .dashboards
             value: 'true'
           ports:
             - name: tomcat-http
               containerPort: 8080
               protocol: TCP
           env:
           - name: DATA_DIR
           - name: JAVA_OPTS
             value: >-
             value: postgres-svc
             value: '5432'
             value: geonetwork
             value: geonetwork
             value: XXXXXXXXXXX
             value: postgres
           - name: ES_HOST
             value: 127.0.0.1
           - name: ES_PROTOCOL
             value: http
           - name: ES_PORT
             value: '9200'
           - name: KB_URL
           volumeMounts:
             - mountPath:
             - mountPath:
               subPath: web.xml
           lifecycle:
             postStart:
               exec:
                 command:
                 - "/bin/sh"
                 - "-c"
       volumes:
Connection: close
<html>
<head>
</head>
<table>
</table>
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
h._
         at
         at
         at
         at
         at
         at
         at
</pre>
</body>
</html>
server:
Accept:
Sec-Fetch-User: ?1
h._
kbn-name: kibana
kbn-license-sig:
content-length: 0
length 0
..e
g....u..
..e
Accept:
Sec-Fetch-User: ?1
1 0 0 0 208b 208b
1 1 0 0 208b 208b
1 0 0 0 208b 208b
1 0 0 0 208b 208b
1 1 0 0 208b 208b
Best regards,
Pierpaolo
this email.*
