That did the trick!
Thanks Francois!
Nagore González Echepare
Analista / Consultora GIS
nagore.gonzalez@...1602...<mailto:nagore.gonzalez@…1602…>
Tfno.: +34 945 13 13 72
C/ Pintor Clemente Arráiz, 3 BJ (01008) Vitoria-Gasteiz, Álava
De: Francois Prunayre <fx.prunayre@...54...>
Enviado el: martes, 11 de mayo de 2021 10:30
Para: Nagore González Etxepare <Nagore.Gonzalez@...1602...>
CC: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] GeoNetwork 4.0 add category to filters
Hi, for now you've 2 options:
* Update JS locale files and clean translation cache
https://github.com/geonetwork/core-geonetwork/blob/main/web-ui/src/main/resources/catalog/locales/en-core.json
* Or use the translation API which allows to store custom translations in the database (better on the long term as you don't need to change the source code)
https://github.com/geonetwork/core-geonetwork/pull/4823
Francois
Le mar. 11 mai 2021 à 10:25, Nagore González Etxepare <Nagore.Gonzalez@...1602...<mailto:Nagore.Gonzalez@…1602…>> a écrit :
Hi Francois,
I am coming back with this issue. Recently, we have updated to version 4.0.4 and we managed to add the categories in the main page. The problem is that it is showing the id and not the description of the category in the UI language (we have descriptions of the categories in different languages). Is it possible to show the description instead of the id? We are adding the facet in the following way:
"cat.keyword": {
"terms": {
"field": "cat.keyword",
"size": 22
We have tried also with cat.key and cat.default without result.
[cid:image001.png@...1913...]
De: Francois Prunayre <fx.prunayre@...54...<mailto:fx.prunayre@…54…>>
Enviado el: martes, 2 de marzo de 2021 13:37
Para: Nagore Gonzalez Etxepare <Nagore.Gonzalez@...1602...<mailto:Nagore.Gonzalez@…1602…>>
CC: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Hi, you should probably update first to 4.0.3.
In user interface configuration, Filters is used to restrict all searches to some records eg. none harvested records, not obsolete records, ... That means that they will not be visible in search results.
In your case it looks like you want to add a facet on the category field. So you should look to https://geonetwork-opensource.org/manuals/4.0.x/en/customizing-application/configuring-faceted-search.html. To explore what are the fields available you can also check a document in your index using http://localhost:9200/gn-records/_doc/fd2ba1d6-71e5-468d-b052-ad31ad121286. category field is "cat", ISO topic category will be cl_topic.key or cl_topic.default if your catalog is multilingual or not.
HTH
Francois
Le mar. 2 mars 2021 à 12:27, Nagore Gonzalez Etxepare <Nagore.Gonzalez@...1602...<mailto:Nagore.Gonzalez@…1602…>> a écrit :
Hello,
I am working with GeoNetwork 4.0.0.
I have created some custom categories and assigned my metadata records to those categories. Now, I would like to add the category as a filter in the Search page to be able to filter my records by category. I believe it has to be configured in the user interface (https://localhost/geonetwork/srv/eng/admin.console#/settings/ui) Search application > Filters.
But I don´t know the code to use to add the category. Which is the field name I have to use? And the facet name? What am I doing wrong?
"topicCat": {
"terms": {
"field": "tocpicCat"
Thanks in advance for your help.
Best regards,
Analista / Desarrolladora GIS
Tfno.: (+34) 656 63 59 02 / 945 13 13 72
[https://www.geograma.com/pie-de-mail/geogramatalks.png\]<https://bit.ly/geogramatalks>
Si no ves la imagen puedes acceder al boletín de Geograma desde aquí.<https://bit.ly/geogramatalks>
Tratamos su dirección de correo electrónico y otros datos personales para mantener el contacto y comunicación con Ud. y, en su caso, remitirle información sobre nuestros productos y servicios. Si no desea recibir tal información envíe un e-mail en tal sentido a dpd@...1602...<mailto:dpd@…1602…>. Puede acceder, rectificar y suprimir los datos, así como otros derechos, como se detalla en la información adicional y completa a su disposición en nuestra política de privacidad en la URL bit.ly/geo-privacidad<http://bit.ly/geo-privacidad>\. Este mensaje y los archivos adjuntos al mismo son privados y confidenciales, si no es Ud. el destinatario y ha recibido este mensaje por error, rogamos nos lo comunique inmediatamente sin difundir, almacenar o copiar su contenido.
[https://www.geograma.com/pie-de-mail/geo-linkedin.png\]<https://bit.ly/geo-linkedin> [https://www.geograma.com/pie-de-mail/geo-twitter.png\] <https://bit.ly/geo-tw>
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
(attachments)
