[GeoNetwork-users] Geonetwork and S3
I am trying to understand how I can integrate S3 in my running instance of GN3.10.2 I am reading the docs and I need some insight. First of all I would like to mention that some of the links mentioned here: https://geonetwork-opensource.org/manuals/trunk/en/install-guide/customizing-data-directory.html#using-a-s3-object-storage are not working anymore. Maybe that is a small issus to be corrected. Then I need to understand where I have to change my "config-spring-geonetwork.xml"-file regarding S3. When I compare the file in my instance to the one that is on github, there are quite some changes. So can I just add whatever I need to configure about S3 in this file, or do I need to clone the repo and change it there and use maven and so on (which I dont have so many knowledge on how to do). Any help is much appreciated.
Kind regards
Andreas
Is there anybody who can point me in some direction?
Thanks
Andreas
Am 22.03.2021 um 11:57 schrieb Andreas Böhme:
Kind regards
Andreas
GeoNetwork-users mailing list
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
andreas.boehme@anonymised.com, www.ufz.de
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
Hi Andreas
The documentation points to the file in master, that is quite different
indeed:
https://github.com/geonetwork/core-geonetwork/blob/master/core/src/main/resources/config-spring-geonetwork.xml,
it should be updated.
Ian added CMIS support also and refactored the configuration. The file for
3.10.x it's this one, that matches the documentation:
https://github.com/geonetwork/core-geonetwork/blob/2d9d7472fd4045fc2a9719d8a41ca616a7210678/core/src/main/resources/config-spring-geonetwork.xml#L203-L219
You need to change that file and rebuild the core jar package (I think with
the refactor in master branch, that is no longer required and can be
changed directly in a file in the web application, but it's not the case
for Geonetwork 3.10.x.
I can't help much more about the issues in S3, but if you can send the log
files with the error or open a ticket in GitHub, hopefully the developers
of this module can provide support.
JOse García
On Tue, Mar 30, 2021 at 11:10 AM Andreas Böhme <andreas.boehme@anonymised.com..>
Thanks
Andreas
> Hi,
> here:
> Kind regards
> Andreas
Andreas Böhme
Dr. Sabine König
Bücher)
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Andreas,
As Jose indicated, I did make some modifications to the storage layout when implementing CMIS and documentation may need to be updated. In regards to S3, I mostly updated the code so that you can pass an environment variables or via properties so that it is possible to connect to different filesystem storages (default, s3, cmis, jcloud) without having to do a custom build.
i.e.
geonetwork.store.type can be supplied using the -Dgeonetwork.store.type or via env as GEONETWORK_STORE_TYPE If not supplied it will default to "default" store type which is the local file system.
Option include
     default - Default file system store
     s3 - AWS S3 storage (see config-store/config-s3.xml for more details)
     cmis - CMIS storage (see config-store/config-cmis.xml for more details)
https://github.com/geonetwork/core-geonetwork/blob/5ff61938639b3ea33298dd6aafdd18025d6c2982/core/src/main/resources/config-spring-geonetwork.xml#L193-L205
Of course, you can modify the file manually if desired and perform a build.
I also did add a jcloud implementation which is a generic driver that will allow all kinds of cloud storages including S3
https://github.com/geonetwork/core-geonetwork/pull/4570
The PR has instructions on how to test with Azure blob. It should be similar for S3, unfortunately, I don't have access to S3 storage to do testing.
I have tested this with Azure blobs and it works fine. I don't believe many in the community have access to cloud storage such as S3 or Azure Blob so it makes it difficult to get these approved!
I'm not sure if there is interest in adding this feature? The PR has been there for a year now and I have been updating the code to work with the latest changes but if there is no interest, I'm not sure how long I will keep this updated?
Sent: March 30, 2021 6:39 AM
To: Andreas Böhme <andreas.boehme@anonymised.com>
Cc: Geonetwork-Users@anonymised.com <geonetwork-users@lists.sourceforge.net>
Subject: Re: [GeoNetwork-users] Geonetwork and S3
Hi Andreas
indeed:
JOse García
On Tue, Mar 30, 2021 at 11:10 AM Andreas Böhme <andreas.boehme@anonymised.com>
Thanks
Andreas
> Hi,
> here:
> Kind regards
> Andreas
Andreas Böhme
Dr. Sabine König
Bücher)
this email.*
