[GeoNetwork-users] [GeoNetwork-devel] Publication of Geosource + Geoevenements
A little bit late but a second event about Géosource will be set during the Geoevenement in Paris. A training session about "Metadata with Geosource" is organized by the BRGM and the Ministry of the ecology the April, 5 (15h30-16h30). It's a free session. The objective is to present the role of the metadata and the use of the MD ISO standards with a opensource tool.
Who would be the developers that need to access/ work on it?
I think it will be good if we could create a specific branch (Geosource_V1) in the Geonetwork code repository with a write access for anthony, laurent and me. I could after commit the current code source.
Pierre.
-----Message d'origine-----
De : Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Envoyé : mardi 13 mars 2007 23:01
À : Lagarde Pierre
Cc : geonetwork-devel@lists.sourceforge.net; geonetwork-users@anonymised.comorge.net
Objet : Re: [GeoNetwork-devel] Publication of Geosource
Hi Pierre,
On Mar 13, 2007, at 4:48 PM, Lagarde Pierre wrote:
Hi Jeroen,
This is excellent work! Impressive new functionality.
Thanks.
In fact, I would be very happy to create a branch on SVN for you to
develop on independently if needed?
Yes, I think also It will be very important to have a unique
repository of GN sources with a specific branch for Geosource, showed
the nearest of the french project. Futhermore, It will be easier to
merge the code. Do you think it will possible to open this branch ?
Excellent! Yes, sure we can set one up. Who would be the developers that need to access/ work on it?
For instance the "metadata loading" message in the metadata view
when changing tabs etc.. .
Thank Ajax
:slight_smile:
It allows for im/export of metadata, thumbnails and possibly also
data and privileges. Your format seems pretty comparable and it
seems pretty easy to align the two.
Very good initiative ! Andra, could you mail the specification of
the MEF format developed in GN 2.1 ?
It is documented in the docs section on the SVN. Here's the URL to
the document:
http://geonetwork.svn.sourceforge.net/viewvc/*checkout*/geonetwork/
trunk/docs/manuals/server-reference.pdf
Let's start discussing a plan to integrate your developments based
on this! We are about ready for a 2.1 beta release, but we can
plan for some of the described functions to still be integrated.
For the other functions we may work on integrating them in a 2.2
release for instance!?
I agree with the approach. Thesaurus --> 2.1 (francois, do you
think it will available ?). Other, I will try to evaluate the job
to add other functionalities... I will be very glad if we could
sent our contribution of GN for the 2.2 release !
Cool! Looking forward to see that happen!
Ciao,
Jeroen
Pierre.
Envoyé : jeudi 8 mars 2007 12:46
À : Lagarde Pierre
users@lists.sourceforge.net
Hi Pierre!
This is excellent work! Impressive new functionality. I really hope
you will be able to port a number of these into the GN 2.1 to
ensure we avoid moving to a forked project :slight_smile:
develop on independently if needed? This may be a good next step
now that 19139 support is available in GN2.1 and François started
working on adding the thesaurus for instance. I think that working
in the same SVN has a big benefit to ensure we all know exactly
where we go and where we can ensure to get the best common approach.
I would like to invite you to start merging translations and
thesaurus support directly on 2.1 and work on merging SRS,
attribute metadata, contact directory support and import export
functions through a branch on the GN SVN. Is that an option?
I noticed a range of small, nice improvements in your site that I
would welcome to be added to GN 2.1 too. For instance the "metadata
loading" message in the metadata view when changing tabs etc.. .
Also the export and import of search results are nice. They are
very much in line with export import functions Andrea has been
working on.
He described the MEF export format that could prove a nice option
for you too. It allows for im/export of metadata, thumbnails and
possibly also data and privileges. Your format seems pretty
comparable and it seems pretty easy to align the two. I was
discussing just this function yesterday with Andrea.
on this! We are about ready for a 2.1 beta release, but we can plan
for some of the described functions to still be integrated. For the
other functions we may work on integrating them in a 2.2 release
for instance!?
Again, I very much welcome having the GeoSource developers actively
involve themselves in the GN project directly! Hope you can make
this happen to further strengthen the project.
Greetings from Rome,
Jeroen
On Mar 8, 2007, at 9:22 AM, Lagarde Pierre wrote:
HI all,
We have the pleasure to announce the publication of a french
"customisation" of GeoNetwork, named Geosource.
Geosource, based on the 2.0.3 of GN, has been specialized for French
users to manage all metadata with the national profile of
19115 standards. But, the development was also the opportunity to:
- finish the translation of all terms and definition (in particular
19115 metadata);
- add thesaurus management with SKOS standards
- add export 19139 XML functionality with the enhancement of the GN
migration tool.
- Add import 19139 XML functionality and 19139 - French profile
- add SRS dictionary import / export with the respect of the 19111
standards about projection systems and use in the metadata editor
tool.
- add the capabilities to describe metadata about attributes (the
table associated to the dataset) with the implementation of a
simplified version of the 19110 standards - see "metadonnées
completes
/ Catalogue des attributs"
- add organisms directory management and use in the metadata editor
tool.
Geosource is available in a french sourceforge (managed by the french
government): http://admisource.gouv.fr/projects/
geocatalogue/ with all documentation and source code (SVN) and you
could see an online demo here: http://212.208.217.23/geosource/srv/
fr/main.home (login/password : geoadmin/geoadmin)
One year ago, during the GN workshop, we chose to split the
development between french needs and current FAO GN developments
(because incompatible completion date). But, we are always OK to
contribute to the GN development, more particularly in the OSGEO
context !
Francois has started the implementation of thesaurus in the current
development GN 2.1. If GN team is interested with one or more
Geosource functionalities, we are ready to try to merge (after the
next realease of GN ?).
Thank again at all GN developers !
Pierre Lagarde
BRGM
Le contenu de cet e-mail et de ses pièces jointes est destiné à
l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de
réception de cet e-mail par erreur, le signaler à son expéditeur et
ne pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient
néanmoins de vérifier l'absence de corruption à sa réception. The
contents of this email and any attachments are confidential. They are
intended for the named recipient(s) only. If you have received this
email in error please notify the system manager or the sender
immediately and do not disclose the contents to anyone or make
copies.
eSafe scanned this email for viruses, vandals and malicious content.
Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys-and earn
cash http://www.techsay.com/default.php?
page=join.php&p=sourceforge&CID=DEVDEV
GeoNetwork-devel mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
l'usage exclusif du
de réception de cet
e-mail par erreur, le signaler à son expéditeur et ne pas en
convient néanmoins de
vérifier l'absence de corruption à sa réception. The contents of
confidential. They are intended for
the named recipient(s) only. If you have received this email in
system manager or the sender immediately and do not disclose the
contents to
anyone or make copies. eSafe scanned this email for viruses,
content.
Le contenu de ce mél et de ses pièces jointes est destiné à l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de ce
mél par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient néanmoins de
vérifier l'absence de contamination à sa réception.
The contents of this email and any attachments are confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
