geonetwork-install-2.8.0-RC1.jar halts during the installation process.
Has anyone been able to successfully install the jar file for GN 2.8.0-RC1
or RC0?
Saher
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-install-2-8-0-RC1-fails-to-install-tp5006375.html
Saher,
What platform are you installing on? This is a common problem with Windows
7. In that case it is solved by installing as administrator or installing in
an alternate location such as C:/geonetwork.
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-install-2-8-0-RC1-fails-to-install-tp5006375p5006504.html
Hi Byron,
I am installing it on Windows 7 64Bit with SP1, and using jre1.5.0_22 & jre7.
I am installing it as an administrator in drive E as E:\geonetwork.
Please provide me some help & guidance. I would be very grateful to you.
Kind Regards,
Saher
From: ByronCinNZ [via OSGeo.org] <ml-node+s1560n5006504h87@anonymised.com>
To: Saher Murad <sahermurad@anonymised.com>
Sent: Friday, 5 October 2012, 0:52
Subject: Re: geonetwork-install-2.8.0-RC1 fails to install
Saher,
What platform are you installing on? This is a common problem with Windows 7. In that case it is solved by installing as administrator or installing in an alternate location such as C:/geonetwork.
Byron
If you reply to this email, your message will be added to the discussion below:http://osgeo-org.1560.n6.nabble.com/geonetwork-install-2-8-0-RC1-fails-to-install-tp5006375p5006504.html
To unsubscribe from geonetwork-install-2.8.0-RC1 fails to install, click here.
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-install-2-8-0-RC1-fails-to-install-tp5006375p5006544.html
