Hello,
I managed to install Geonetwork 3.0.2 on Windows 8.1 (mode "Run as administrator")
but I can't launch it. Below it is log file
Database is H2. I have 16GB RAM.
Any suggestion ?
Piotr
/2015-09-22 10:44:29,273 WARN [geonetwork] - Database does not contain any version information. Check that the database is a GeoNetwork database with data. Migration step aborted.
2015-09-22 10:44:38,227 FATAL [jeeves.engine] - Raised exception during init
2015-09-22 10:44:38,227 FATAL [jeeves.engine] - Exception : org.jdom.JDOMException: java.lang.OutOfMemoryError: PermGen space: PermGen space
2015-09-22 10:44:38,227 FATAL [jeeves.engine] - Message : java.lang.OutOfMemoryError: PermGen space: PermGen space
2015-09-22 10:44:38,227 FATAL [jeeves.engine] - Stack : org.jdom.JDOMException: java.lang.OutOfMemoryError: PermGen space: PermGen space
at org.jdom.xpath.XPath.newInstance(XPath.java:139)
at org.fao.geonet.utils.Xml.prepareXPath(Xml.java:789)
at org.fao.geonet.utils.Xml.selectNodes(Xml.java:865)
at org.fao.geonet.utils.Xml.selectNodes(Xml.java:898)
at jeeves.server.overrides.ConfigurationOverrides.doUpdateLogging(ConfigurationOverrides.java:208)
at jeeves.server.overrides.ConfigurationOverrides.updateLoggingAsAccordingToOverrides(ConfigurationOverrides.java:200)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:129)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:82)
at javax.servlet.GenericServlet.init(GenericServlet.java:244)
at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:532)
at org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:344)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:791)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:265)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1242)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:717)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:494)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:39)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:494)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:141)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:56)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:615)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:540)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:403)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:337)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:121)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:555)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:230)
at org.eclipse.jetty.util.component.AggregateLifeCycle.doStart(AggregateLifeCycle.java:81)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:58)
at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:96)
at org.eclipse.jetty.server.Server.doStart(Server.java:282)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1274)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1197)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:473)
at org.eclipse.jetty.start.Main.start(Main.java:615)
at org.eclipse.jetty.start.Main.main(Main.java:96)
Caused by: java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.jaxen.saxpath.helpers.XPathReaderFactory.createReader(XPathReaderFactory.java:137)
at org.jaxen.saxpath.helpers.XPathReaderFactory.createReader(XPathReaderFactory.java:110)
at org.jaxen.BaseXPath.<init>(BaseXPath.java:113)
at org.jaxen.BaseXPath.<init>(BaseXPath.java:142)
at org.jaxen.jdom.JDOMXPath.<init>(JDOMXPath.java:91)
at org.jdom.xpath.JaxenXPath.setXPath(JaxenXPath.java:281)
at org.jdom.xpath.JaxenXPath.<init>(JaxenXPath.java:99)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.jdom.xpath.XPath.newInstance(XPath.java:129)
2015-09-22 10:44:38,242 FATAL [jeeves.engine] - Raised exception during init
2015-09-22 10:44:38,242 FATAL [jeeves.engine] - Exception : java.lang.RuntimeException: Exception raised
2015-09-22 10:44:38,242 FATAL [jeeves.engine] - Message : Exception raised
2015-09-22 10:44:38,242 FATAL [jeeves.engine] - Stack : java.lang.RuntimeException: Exception raised
at jeeves.server.JeevesEngine.handleStartupError(JeevesEngine.java:211)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:193)
Caused by: org.jdom.JDOMException: java.lang.OutOfMemoryError: PermGen space: PermGen space
... 42 more
