[GeoNetwork-users] Geonetwork load problem
I have a problem loading geonetwork. I'm using tomcat6 and apache2 in Ubuntu
12.10. I've installed geonetwork v2.10.1.war with Mysql behind.
The page is: http://91.121.198.181:8080/geonetwork
Any idea what happens?
Thanks in advance
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-load-problem-tp5084530.html
Is anybody know how to proceed?
I need help
thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-load-problem-tp5084530p5084991.html
Hi
When access to the site, I see this error:
java.io.FileNotFoundException:
/var/lib/tomcat6/webapps/geonetwork/WEB-INF/config-xml-metadata-services.xml
(No such file or directory)
Please verify that the permissions in the folder
/var/lib/tomcat6/webapps/geonetwork are correct. Tomcat probably is
running with the user tomcat6, so geonetwork folder should be owned by
that user.
Jose García
On Tue, Oct 22, 2013 at 11:33 AM, Vaictor
I need help
thanks
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most
from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hi Jose,
Now my folder "geonetwork" (/var/lib/tomcat6/webapps/geonetwork) has entire
777 permission (can read, write and execute) I did with Filezila and then
restart tomcat6 but still not working
Any idea? The error is the same
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-load-problem-tp5084530p5085347.html
Hi
Does the file /var/lib/tomcat6/webapps/geonetwork/WEB-INF/config-xml-metadata-services.xml
exists?
Jose García
On Wed, Oct 23, 2013 at 4:25 PM, Vaictor
Hi Jose,
Thanks
from
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
It doesnt' exist this file. What does it mean? Should I create it?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-load-problem-tp5084530p5085775.html
What should I do Jose?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-load-problem-tp5084530p5086141.html
