[GeoNetwork-users] Geonetwork - Out of Memory error
Dear all,
I already wrote to this mailing list for a problem with an H2 database growing substantially without apparent reasons. This created a very slow geonetwork website. The suggestion I received was to move to PostgreSQL for a production environment, which I did.
Today, again, I have a very slow geonetwork, resulting often in a Out of Memory error when I try to reach the landing page. Checking the database, I noticed that the settings table weight 391Mb, which seems a lot as there are only 118 rows in the table!
My question is: Is this a 'normal' size for a working geonetwork database, considering that I have around 200 metadata records (mostly harvested)?
One 'strange' info I find in the setting table is the system/publication/doi/doipassword value which is an encrypted password, but it is more than 65.000 characters. It seems quite a lot.
Thanks for your help!
Best regards,
Nicolas de Ville
Hi Nicolas,
sounds like your passwords are encoded, re-encoded and again and again ...
Check the startup notice about the encryptor.properties file that must be
preserved on each updates:
2022-02-04 13:05:48,101 INFO [geonetwork.encryptor] - Password database
encryptor initialized - Keep the file
/WEB-INF/data/config/encryptor.properties safe and make a backup. When
upgrading to a newer version of GeoNetwork the file must be restored,
otherwise GeoNetwork will not be able to decrypt passwords already stored
in the database.
2022-02-04 13:05:48,117 INFO [geonetwork.encryptor] - Password database
encryptor - encrypting passwords stored in the database
https://geonetwork-opensource.org/manuals/4.0.x/en/maintainer-guide/updating/index.html?highlight=encryptor%20properties
Reset the password in the settings table
UPDATE Settings SET value = '' WHERE name LIKE '%password%';
Restart and populate them again from the admin.
Once encoded, they should not change on restart.
HTH.
Francois
Le ven. 4 févr. 2022 à 12:59, Nicolas De Ville De Goyet via
GeoNetwork-users <geonetwork-users@lists.sourceforge.net> a écrit :
Dear all,
harvested)?
Best regards,
Nicolas de Ville
GeoNetwork-users mailing list
Dear François,
Thank you for your answer. It seems this long password was indeed the issue. After deleting it geonetwork is back to its normal speed.
Best,
Nicolas
On 4/02/22 13:11, Francois Prunayre wrote:
Hi Nicolas,
Check the startup notice about the encryptor.properties file that must be preserved on each updates:
2022-02-04 13:05:48,101 INFO [geonetwork.encryptor] - Password database encryptor initialized - Keep the file /WEB-INF/data/config/encryptor.properties safe and make a backup. When upgrading to a newer version of GeoNetwork the file must be restored, otherwise GeoNetwork will not be able to decrypt passwords already stored in the database.
2022-02-04 13:05:48,117 INFO [geonetwork.encryptor] - Password database encryptor - encrypting passwords stored in the database
https://geonetwork-opensource.org/manuals/4.0.x/en/maintainer-guide/updating/index.html?highlight=encryptor%20properties <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgeonetwork-opensource.org%2Fmanuals%2F4.0.x%2Fen%2Fmaintainer-guide%2Fupdating%2Findex.html%3Fhighlight%3Dencryptor%2520properties&data=04|01|ndeville%40naturalsciences.be|a91222db10ab4d7ecb4408d9e7d77c11|4da8d35db472419c9e15665786aadbfb|1|0|637795734952051107|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000&sdata=hQipwSA2sD2nlk2GMHzIS0fPRa7ivjwGgYrM2%2F8oc%2Fw%3D&reserved=0&gt;
HTH.
Francois
Le ven. 4 févr. 2022 à 12:59, Nicolas De Ville De Goyet via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> a écrit :
    Dear all,
    database
    very slow
    PostgreSQL
    Out of
    seems a
    harvested)?
    password,
    Best regards,
    Nicolas de Ville
    <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.sourceforge.net%2Flists%2Flistinfo%2Fgeonetwork-users&data=04|01|ndeville%40naturalsciences.be|a91222db10ab4d7ecb4408d9e7d77c11|4da8d35db472419c9e15665786aadbfb|1|0|637795734952051107|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000&sdata=nLTYN5RvJpd%2BFq7koZnL1yBhyhnXllh%2BVB8bf7oUODw%3D&reserved=0&gt;
    <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fsourceforge.net%2Fprojects%2Fgeonetwork&data=04|01|ndeville%40naturalsciences.be|a91222db10ab4d7ecb4408d9e7d77c11|4da8d35db472419c9e15665786aadbfb|1|0|637795734952051107|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000&sdata=HcOmuUG66XFWNfpOKWFq2Ul9SpCzvuwwTuPberAY4m8%3D&reserved=0&gt;
