I'm trying to enable all INSPIRE-specific features in GeoNetwork v3.0.0 but it seems that I can't get it to work. Although I have enabled both 'Admin console'->'Settings'->'System settings'->'INSPIRE Directive configuration'->'INSPIRE search panel' and 'Admin console'->'Settings'->'System settings'->'Metadata views'->'INSPIRE view', neither INSPIRE search panel nor INSPIRE metadata view show up in my interface. I've looked up for documentation about configuring GeoNetwork but the most up-to-date (2.11.0) I found, didn't helped me much.
Does GeoNetwork v3 fully supports managing, validating and publishing INSPIRE metadata as in previous versions?
If it does, can someone please point me in the right direction about configuring it properly?
On Fri, Jun 26, 2015 at 8:58 PM, Konstantinos Tzevanidis <
ktzevanid@anonymised.com> wrote:
Hello,
Monitor 25 network devices or servers for free with OpManager!
OpManager is web-based network management software that monitors
network devices and physical & virtual servers, alerts via email & sms
for fault. Monitor 25 devices for free with no restriction. Download now http://ad.doubleclick.net/ddm/clk/292181274;119417398;o
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
Hi, thank you for your answer.
I have done this before, but I don't have this option... I have also tried
with rebuilding index, but no differences, I only see these inspire themes
under keywords that is why on home page I don't have INSPIRE facets search
enabled...
Do you mean the icons under "Browse by INSPIRE themes" ?
If not, i am sorry maybe hijacking this thread.
But i have problems with Inspire-metadata myself.
If i try one of the inspire themes under "Browse by INSPIRE themes"
GN-3-search never finds anything.
The theme icons show a plausible nr. of metadata but clicking on them yields
only
" No results found"
Browse by topics just works fine.
It could be an issue with the Lucene-Facet-Search as i find several entries
like this:
/[geonetwork.search-logger] - unknown queryInfo type:
org.apache.lucene.facet.DrillDownQuery/
in the Log.
only
" No results found"
like this:
in the Log.
yields
> only
> " No results found"
entries
> like this:
> in the Log.
I can confirm this issue with 3.0.4.
Landry Breuil
Mouton a 5 pattes du CRAIG
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now! http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
In my experience when testing the fix, i had to remove wro4j cache in geonetwork datadir, and the issue disappeared. For good measure i also regenerated the lucene index but i'm not sure that was needed.
The data i use now are from some xml-Metadata exportet from our poductive
GN-10.2-Installation.
But i also tried a bulk approach copying the whole metada_data folder into a
vanilla GN-3.0.3 and using a copy of the GN-10.2-Postgres-DB which was
migrated by GN itself during the the startup of the modified GN.
The whole thing (some minor sql-fixes had to be applied) appeared to be
successful but the INSPIRE-theme search never worked.
So i think i have to inspect the Lucene-Index.
PS: Should i just wait for things to settle down before atempting to use
GN-3? But it looks very pretty.
I confirm that dropping wro4j cache and restart make the changes to be
applied. eg. on Tomcat
rm webapps/geonetwork/WEB-INF/data/wro4j-cache.*
touch webapps/geonetwork/WEB-INF/web.xml
HTH
Francois
a
