[GeoNetwork-users] geonetwork3 startup failed
Dear all,
I was trying to test geonetwork3.2.0 on my ubuntu server 14.04.
I downloaded the geonetwork.war file and put it on tomcat container.
I created a geonetwork db on my postgresql db (with postgis extension).
I modify the database following the documentation I found in internet:
https://www.geodatenmanufaktur.de/howtos/geonetwork.html
or
http://osgeo-org.1560.x6.nabble.com/create-scripts-in-3-0-td5205280.html
or
http://gis.stackexchange.com/questions/160105/configure-geonetwork-with-postgresql
or
https://publicwiki.deltares.nl/display/OET/Geonetwork+3+Installation
Unfortunately, after the changes in srv.xml and in jdbc.properties I still have problems,
the log reports:
INFORMAZIONI: Deploying web application archive /var/lib/tomcat7/webapps/geonetwork.war
gen 30, 2017 4:08:51 PM org.apache.catalina.loader.WebappClassLoader validateJarFile
INFORMAZIONI: validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/geronimo-servlet_3.0_spec-1.0.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/s$
INFORMAZIONI: validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/javax.servlet-api-3.1.0.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/servlet$
INFORMAZIONI: validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/jsp-api-2.1-6.1.14.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/el/Expressio$
gen 30, 2017 4:08:52 PM org.apache.catalina.loader.WebappClassLoader validateJarFile
INFORMAZIONI: validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/servlet-api-2.5-20081211.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/servle$
INFORMAZIONI: validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/servlet-api-2.5-6.1.14.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/servlet/$
gen 30, 2017 4:09:15 PM org.apache.catalina.core.StandardContext startInternal
GRAVE: Error listenerStart
gen 30, 2017 4:09:16 PM org.apache.catalina.core.StandardContext startInternal
GRAVE: Context [/geonetwork] startup failed due to previous errors
gen 30, 2017 4:09:16 PM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
GRAVE: The web application [/geonetwork] appears to have started a thread named [Abandoned connection cleanup thread] but has failed to stop it. This is very likely to create a memory leak.
gen 30, 2017 4:09:16 PM org.apache.catalina.startup.HostConfig deployWAR
Why I got that?
Where I'm wrong?
I don't see any table in the db once I reboot tomcat. It seems it is missing the create*.sql script.
Any hints?
thanks
Eugenio
Hi Eugenio,
you may try to turn on more logging on hibernate (lib creating the db). See
http://geonetwork-opensource.org/manuals/3.0.5/eng/users/maintainer-guide/installing/configuring-database.html
for details.
HTH.
Francois
2017-01-30 16:28 GMT+01:00 Eugenio Trumpy <frippe12573@anonymised.com>:
Dear all,
or
or
or
have problems,
the log reports:
geonetwork.war
validateJarFile
validateJarFile
validateJarFile
validateJarFile
validateJarFile
startInternal
startInternal
Why I got that?
Where I'm wrong?
Any hints?
thanks
Eugenio
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
