[GeoNetwork-users] GN 2.8.x new web interfaces
I've been testing the new web interfaces in the nightly builds of GN 2.8.x
(those in apps/search and apps/tabsearch.) As I run into issues or have
specific questions, is this mailing list the place to report those?
An issue I'm working through now is how to restrict the extent coordinates
in the mini search map. Custom coordinates in config-gui.xml don't seem to
have an effect and modifying value sin App-mini.js causes problems in the
map rendering. Thanks.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
in config-gui.xml [1] define the extent URL parameter like in the
example provided - it will define the extent to start with (when you
access to http://localhost:8080/geonetwork) :
<client type="redirect" widget="true" url="../../apps/search/"
parameters="extent=-5.1,41,9.7,51" createParameter="#create"
stateId="s"/>
After that, when you search zoom is adapted according to the records
in the current page by default.
Coordinates must be in the map's projection.
HTH.
Francois
[1] https://github.com/geonetwork/core-geonetwork/blob/master/web/src/main/webapp/WEB-INF/config-gui.xml
2012/8/28 John Callahan <john.callahan@anonymised.com>:
- John
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
Thank you for your response. However, that does not seem to have any
effect on the new web interfaces.
- John
On Tue, Aug 28, 2012 at 11:03 AM, Francois Prunayre
<fx.prunayre@anonymised.com>wrote:
stateId="s"/>
HTH.
Francois
[1]
2.8.x
coordinates
to
> - John
Even if you add the extent parameter to the URL
http://localhost:8080/geonetwork/apps/search/?extent=-5.1,41,9.7,51
Francois
Thank you for your response. However, that does not seem to have any effect
- John
On Tue, Aug 28, 2012 at 11:03 AM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
stateId="s"/>
HTH.
Francois
[1]
> 2.8.x
> have
> coordinates
> to
> the
> - John
> Discussions
> malware
Yes, it does work to limit the initial extent upon loading. And as you
said, the extent changes based upon search results. This works fine.
Thank you.
A problem occurs when a user clicks the "Full Extent" button on the map. I
believe it uses the extent coordinates found in apps/search/js/App-mini.js
GeoNetwork.map.EXTENT=new OpenLayers.Bounds(-82.0,36.0,-69.0,42.5);
The map displayed is cropped at the extents to the West and South (in my
case). It seems to be one zoom level too low. One zoomin level and it
fits perfect. Attached is a graphic showing the map.
- John
On Tue, Aug 28, 2012 at 11:27 AM, Francois Prunayre
Francois
effect
> - John
> wrote:
>> Hi,
>> stateId="s"/>
>> HTH.
>> Francois
>> [1]
>> > 2.8.x
>> > have
>> > coordinates
seem
>> > to
>> > the
>> > - John
>> > Discussions
>> > malware
>> > _______________________________________________
(attachments)
