Hi together,
I'm trying out GN 4.4.2 for use
As I saw in geonetwork.log, debug mode, the indexing task is working every 30 seconds all the time:
2024-02-14T13:12:30,004 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:12:30 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:13:00,010 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:13:00 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:13:30,005 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:13:30 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:14:00,006 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:14:00 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:14:30,010 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:14:30 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:15:00,013 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:15:00 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:15:30,008 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:15:30 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:16:00,010 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:16:00 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:16:30,007 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:16:30 CET 2024. Checking if any records need to be indexed ...
2024-02-14T13:17:00,003 DEBUG [geonetwork.index] - Indexing task / Start at: Wed Feb 14 13:17:00 CET 2024. Checking if any records need to be indexed ...
I don't know that from GN 3.x.
is that necessary?
It is possible to change the indexing interval somewhere?
I haven't found anything about it anywhere.
Using GN 4.4.2 with ES v 7.17.16 and Tomcat 9.0.85. H2 Database.
OS Win Server 2019 and Java 11
Best regards/
Mit freundlichen Grüßen
Im Auftrag
Robert Kulawik
GA 5372
Eisenbahn-Bundesamt
Referat 53: Umgebungslärmkartierung, Geoinformation und Lärmaktionsplanung
Heinemannstraße 6
53175 Bonn
Tel. +49 (0) 228 9826 - 833
Fax +49 (0) 228 9826 - 9833
E-Mail: KulawikR@anonymised.com<mailto:KulawikR@anonymised.com>
Organisationspostfach: Ref53@anonymised.com<mailto:Ref53@anonymised.com>
GIS-Hotline: gishotline@anonymised.com<mailto:gishotline@anonymised.com>
Internetadresse: http://www.eisenbahn-bundesamt.de/>
Nähere Informationen zum Datenschutz finden Sie auf der Homepage des Eisenbahn-Bundesamtes.
Der Umwelt zuliebe: Drucken Sie diese E-Mail bitte nur aus, wenn dies notwendig ist
