[GeoNetwork-users] GN fails to start after binding to an oracle DB
Good evening fellow GN users,
yesterday I tried to switch to another database system after successfully deploying the latest release (GN 4.0.0) via Tomcat 9 on the dedicated RHEL VM - but failed miserably. The initial startup of GN (still with the default H2 db) worked well and as expected. However, the local database is no option in our case.
So I followed the instructions found in the official documentation <https://www.geonetwork-opensource.org/manuals/4.0.x/en/install-guide/configuring-database.html&gt; and
  * altered the node configuration file |WEB-INF/config-node/srv.xml to
    refer to /WEB-INF/config-db/oracle.xml, then
  * ||adjusted |WEB-INF/config-db/jdbc.properties| according to our setup,
  * and set hibernate related logging to DEBUG level
    (WEB-INF/classes/log4j.xml)
The oracle db was tested and found untouched. The initial startup after this modifications, however, failed due to a missing ojdbc driver. So I downloaded ojdbc8 from oracle, placed it in |/WEB-INF/lib| and adjusted its permissions. But now I am confronted with another series of errors, kind of pointing to a non-functional database connection (full log is attached).
It reads something like:
>2020-10-28 16:25:35,194 FATAL [jeeves.engine] - Raised exception during init
>2020-10-28 16:25:35,194 FATAL [jeeves.engine] - Exception : org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'openAPIBuilder' … Factory method 'OpenApiConfig' threw exception; nested exception is org.springframework.dao.InvalidDataAccessResourceUsageException: could not extract ResultSet; SQL [n/a]; nested exception is org.hibernate.exception.SQLGrammarException: could not extract ResultSet…
…and…
>Caused by: java.sql.SQLException: ORA-00942: table or view does not exist
Later I tried another version of the ojdbc driver (14), but still no luck. The error is similar.
Earlier I read <http://osgeo-org.1560.x6.nabble.com/Where-are-the-SQL-scripts-to-create-tables-tp5448158.html&gt;, that databases do not need to be instantiated by scripts in the latest releases, but especially the last quoted line sort of implies that there is a table expected that doesn't seem to exist. I tried to google this specific errors at lengths today, but weren't able to make any use of the information I found.
Hence, any help would be highly appreciated!
Best of regards,
Lars
Dr. Lars Möller
HCDC Metadatenadministration
Helmholtz-Zentrum Geesthacht
Zentrum für Material und Küstenforschung
-Modellierung zur Bewertung von Küstensystemen (KBS)
Max-Planck-Straße 1
21502 Geesthacht
Germany
Fon +49 (0) 4152- 87 - 1849
Fax +49 (0) 4152- 87 - 41849
E-mail: lars.moeller@anonymised.com
www.hzg.de
Helmholtz-Zentrum Geesthacht Zentrum für Material- und Küstenforschung GmbH Max-Planck-Straße 1 I 21502 Geesthacht I Deutschland/Germany
Geschäftsführung/Board of Management: Prof. Dr. Matthias Rehahn, Silke Simon Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: Ministerialdirigent Engelbert Beyer Amtsgericht Lübeck HRB 285 GE (Register Court) Internet: http://www.hzg.de
(attachments)
geonetwork.log (38.8 KB)
Do you have 3.x working with the oracle server?
In 4, we updated JPA and Hibernate libraries so that may explain the
difference. You could try to change log level to DEBUG for
https://github.com/geonetwork/core-geonetwork/blob/4.0.x/web/src/main/webapp/WEB-INF/classes/log4j.xml#L215-L229
and restart to see if you can get the first exception which is raised.
Francois
Le mer. 28 oct. 2020 à 19:34, Lars Möller <lars.moeller@anonymised.com.> a écrit :
and
attached).
during init
…and…
Earlier I read
Best of regards,
Lars
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
www.hzg.de
Simon
GeoNetwork-users mailing list
A suggestion, are you using the default oracle schema for the user? If not, you need to set the alternative schema also in config-spring-geonetwork.xml (see the commented section).
Groet Paul van Genuchten
Op 29 okt. 2020 om 08:29 heeft Francois Prunayre <fx.prunayre@anonymised.com> het volgende geschreven:
Francois
Le mer. 28 oct. 2020 à 19:34, Lars Möller <lars.moeller@anonymised.com6...> a écrit :
and
attached).
during init
…and…
Earlier I read
Best of regards,
Lars
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
www.hzg.de
Simon
Good morning
We are facing the same issue. Changing the config-spring-geonetwork.xml as suggested hasn't solved it.
Any idea abiout it would be welcome!
Best regards.
Óscar Diago Alonso
Analista / Desarrollador GIS
oscar.diago@...1602...<mailto:oscar.diago@…1602…>
Tfno.: +34 945 13 13 72
C/ Pintor Clemente Arráiz, 3 BJ (01008) Vitoria-Gasteiz, Álava
De: Paul Van Genuchten <paul.vangenuchten@...444...>
Enviado: jueves, 29 de octubre de 2020 8:36
Para: Francois Prunayre <fx.prunayre@...54...>
Cc: geonetwork-users@lists.sourceforge.net <geonetwork-users@lists.sourceforge.net>
Asunto: Re: [GeoNetwork-users] GN fails to start after binding to an oracle DB
Op 29 okt. 2020 om 08:29 heeft Francois Prunayre <fx.prunayre@...54...> het volgende geschreven:
Francois
and
attached).
during init
…and…
Earlier I read
Best of regards,
Lars
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
E-mail: lars.moeller@...1876...
www.hzg.de
Simon
Good morning.
More data about that issue. We have found the following error in the log:
java.sql.SQLSyntaxErrorException: ORA-00920: operador relacional no v⭩do.
Error: ORA-00920: invalid relational operator
Causa: A search condition was entered with an invalid or missing relational operator.
Acción: Include a valid relational operator such as =, !=, ^=, <>, >, <, >=, <=, ALL, ANY, [NOT] BETWEEN, EXISTS, [NOT] IN, IS [NOT] NULL, or [NOT] LIKE in the condition.
I hope it gives a hint about what could be hapenning during the deployment.
Best regards.
Óscar Diago Alonso
De: Oscar Diago Alonso <Oscar.Diago@...1602...>
Enviado: jueves, 29 de octubre de 2020 14:40
Para: Geonetwork-Users@...638... <geonetwork-users@lists.sourceforge.net>
Good morning
Best regards.
Óscar Diago Alonso
Francois
and
attached).
during init
…and…
Earlier I read
Best of regards,
Lars
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
www.hzg.de
Simon
Hi Oscar, if you turn on debug level for SQL you may be able to get the
query which is causing this and it will help a bit more.
Can you also send the full exception if there is any stack trace with more
details on the location.
Thanks
Francois
Le ven. 30 oct. 2020 à 08:37, Oscar Diago Alonso <Oscar.Diago@anonymised.com..>
a écrit :
Good morning.
Best regards.
Óscar Diago Alonso
oscar.diago@anonymised.com<mailto:oscar.diago@anonymised.com>
De: Oscar Diago Alonso <Oscar.Diago@anonymised.com>
Para: Geonetwork-Users@anonymised.com <
oracle DB
Good morning
Best regards.
Óscar Diago Alonso
De: Paul Van Genuchten <paul.vangenuchten@anonymised.com>
Para: Francois Prunayre <fx.prunayre@anonymised.com>
oracle DB
> Hi,
> Cheers
> Francois
>> Le mer. 28 oct. 2020 à 19:34, Lars Möller <lars.moeller@anonymised.com876...> a
écrit :
>> and
setup,
>> attached).
>> during init
ResultSet…
>> …and…
exist
>> Earlier I read
>> Best of regards,
>> Lars
>> Dr. Lars Möller
>> Max-Planck-Straße 1
>> 21502 Geesthacht
>> Germany
>> www.hzg.de
>> Simon
>> _______________________________________________
Hi.
According to the log:
Caused by: Error : 604, Position : 0, Sql = INSERT INTO IsoLanguages (id, code, shortcode) VALUES (280,'mis', NULL), OriginalSql = INSERT INTO IsoLanguages (id, code, shortcode) VALUES (280,'mis', NULL), Error Msg = ORA-00604: error occurred at recursive SQL level 1
ORA-01000: maximum open cursors exceeded
Best regards.
Óscar Diago Alonso
De: Francois Prunayre <fx.prunayre@...54...>
Enviado: viernes, 30 de octubre de 2020 9:28
Para: Oscar Diago Alonso <Oscar.Diago@...1602...>
Cc: Geonetwork-Users@...638... <geonetwork-users@lists.sourceforge.net>
Hi Oscar, if you turn on debug level for SQL you may be able to get the query which is causing this and it will help a bit more.
Can you also send the full exception if there is any stack trace with more details on the location.
Thanks
Francois
Le ven. 30 oct. 2020 à 08:37, Oscar Diago Alonso <Oscar.Diago@...1602...<mailto:Oscar.Diago@…1602…>> a écrit :
Good morning.
Best regards.
Óscar Diago Alonso
oscar.diago@...1602...<mailto:oscar.diago@…1602…><mailto:oscar.diago@…1602…>
De: Oscar Diago Alonso <Oscar.Diago@...1602...<mailto:Oscar.Diago@…1602…>>
Para: Geonetwork-Users@...638...<mailto:Geonetwork-Users@…638…> <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>>
Good morning
Best regards.
Óscar Diago Alonso
De: Paul Van Genuchten <paul.vangenuchten@...444...<mailto:paul.vangenuchten@…444…>>
Para: Francois Prunayre <fx.prunayre@...54...<mailto:fx.prunayre@…54…>>
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net> <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>>
Op 29 okt. 2020 om 08:29 heeft Francois Prunayre <fx.prunayre@...54...<mailto:fx.prunayre@…54…>> het volgende geschreven:
Francois
Le mer. 28 oct. 2020 à 19:34, Lars Möller <lars.moeller@...1876...<mailto:lars.moeller@…1876…>> a écrit :
and
attached).
during init
…and…
Earlier I read
Best of regards,
Lars
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
E-mail: lars.moeller@...1876...<mailto:lars.moeller@…1876…>
www.hzg.de<http://www.hzg.de>
Simon
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Hi.
We are still unable to point out the issue with GeoNetworl 4.0 and Oracle.
I have attached the log of our last attempt.
The database version is: Oracle Database 11g Release 11.2.0.4.0 - 64bit.
We are using the library "ojdbc6.jar" to connect to that database.
We are also using OpenJDK: openjdk64_8.0.265
Anyone has any idea about what it could be happenning?
Best regards.
Óscar Diago Alonso
Thanks
Francois
Good morning.
Best regards.
Óscar Diago Alonso
Good morning
Best regards.
Óscar Diago Alonso
Francois
and
attached).
during init
…and…
Earlier I read
Best of regards,
Lars
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
Simon
(attachments)
geonetwork.log (39.8 KB)
