[GeoNetwork-users] Harvest GeoServer with thumbnails creation (GeoNetwork V. 2.9))
Version:2.9.0-SNAPSHOT
I tried to harvest WMS from my GeoServer with the option "Create thumbnails
for WMS layers." on !
Unfortunately no thumbnails are created after the creation of the harvested
metadata.
I get this error in the "History" link of the "Harvest Management" section:
Total 180
Added 1
179
Thumbnails failed 179
Does this feature is enable yet in the version 2.9 SNAPSHOT ?
Where could I look in order to enable this handy feature ?
Thanks in advance for your help
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662.html
Hello,
turning log level to debug for harvester in log4j.cfg
log4j.logger.geonetwork.harvester = WARN
should provide more information about that including the URL used to
create the thumbnail.
Cheers.
Francois
2012/10/5 Lionel Menard <lionel.menard@anonymised.com>:
metadata.
Total 180
Added 1
179
Don't let slow site performance ruin your business. Deploy New Relic APM
Deploy New Relic app performance management and know exactly
what is happening inside your Ruby, Python, PHP, Java, and .NET app
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
http://p.sf.net/sfu/newrelic-dev2dev
GeoNetwork-users mailing list
Hi Francois,
thanks for your fast and helpful reply.
I've checked my log4j.cfg config file and the the
log4j.logger.geonetwork.harvester is already set to WARN.
So where you I get this information about the URL to create thumbnails ?
Maybe the # Default Logging Configuration log4j.rootLogger currently set to
OFF should be set to ON ?
Just in case I copy this file at the bottom of this email.
Thanks in advance for your help.
Lionel
log4j.rootLogger = OFF
### GEONETWORK SETTINGS
log4j.logger.geonetwork = WARN, console, jeeves
log4j.logger.geonetwork.search = WARN
log4j.logger.geonetwork.schemamanager = WARN
log4j.logger.geonetwork.thesaurus-man = WARN
log4j.logger.geonetwork.thesaurus = WARN
log4j.logger.geonetwork.editorexpandelement = WARN
log4j.logger.geonetwork.editoraddelement = WARN
log4j.logger.geonetwork.LanguageDetector = WARN
log4j.logger.geonetwork.index = WARN
log4j.logger.geonetwork.csw = WARN
log4j.logger.geonetwork.csw.search = WARN
log4j.logger.geonetwork.mef = WARN
log4j.logger.geonetwork.z3950server = WARN
log4j.logger.geonetwork.z3950 = WARN
log4j.logger.geonetwork.sru = WARN
log4j.logger.geonetwork.sru.search = WARN
log4j.logger.geonetwork.GeoServerPublisher = WARN
log4j.logger.geonetwork.data.directory = WARN
### JEEVES SETTINGS
log4j.logger.jeeves = DEBUG, console, jeeves
log4j.logger.jeeves.dbms = WARN
# If resourcetracking is set to DEBUG then each time a resource
# is obtained an exception will be created to track the stack trace
# of where the resource was obtained. The traces can be viewed by
# calling debug.openconnection.accessors as administrator
log4j.logger.jeeves.dbms.resourcetracking = WARN
log4j.logger.jeeves.monitor = WARN
log4j.logger.jeeves.engine = WARN
log4j.logger.jeeves.dbmspool = WARN
log4j.logger.jeeves.resources = WARN
log4j.logger.jeeves.xlinkprocessor = WARN
log4j.logger.jeeves.transformerFactory = WARN
log4j.logger.jeeves.xmlresolver = ERROR
### SPRING ####
log4j.logger.org.springframework = WARN, jeeves, console
### JZKIT SETTINGS ####
log4j.logger.com.k_int=WARN, console, jeeves
log4j.logger.org.jzkit=WARN, console, jeeves
log4j.logger.org.jzkit.a2j=WARN, console, jeeves
log4j.logger.org.jzkit.search.impl.LRUCache = WARN, console,jeeves
### JEEVES APPENDER
log4j.appender.jeeves =org.apache.log4j.DailyRollingFileAppender
log4j.appender.jeeves.DatePattern='.'yyyy-MM-dd
log4j.appender.jeeves.file = logs/geonetwork.log
#log4j.appender.jeeves.file = ${catalina.home}/logs/geonetwork.log
log4j.appender.jeeves.layout = org.apache.log4j.PatternLayout
log4j.appender.jeeves.layout.ConversionPattern=%d{ISO8601} %-5p [%c] - %m%n
### CONSOLE SETTINGS
log4j.appender.console = org.apache.log4j.ConsoleAppender
log4j.appender.console.layout = org.apache.log4j.PatternLayout
log4j.appender.console.layout.ConversionPattern=%d{ISO8601} %-5p [%c] - %m%n
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5006669.html
I think he meant setting it from WARN to DEBUG
On Fri, Oct 5, 2012 at 3:24 PM, Lionel Menard <
lionel.menard@anonymised.com> wrote:
Hi Francois,
Lionel
### JEEVES SETTINGS
### SPRING ####
### JEEVES APPENDER
%m%n
Heikki Doeleman wrote
I think he meant setting it from WARN to DEBUG...
Yes Heikki Francois meant this (private email)...Thanks for replying.
So I turn the mode to DEBUG. Restart GeoNetwork. Delete previous harvested
WMS. Rerun Harvest.
An still I get the same message:
Total 180
Added 1
179
I've check my metadata entries and no thumbnails are displayed with the
record.
I guess I need to look elsewhere to have more info ?
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5006680.html
I move a bit forward....
I re-harvest my GeoServer and I corrected my "Service url" target as follow:
http://my.geoserver.org/geoserver/wms?namespace=test
The last harvest log entry in /var/log/tomcat6/geonetwork.log is as follow
2012-10-05 18:00:55,894 DEBUG [geonetwork.harvester] - Retrieving remote
document:
http://gmy.geoserver.org/geoserver/wms?namespace=test&&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image/png&WIDTH=900&SRS=EPSG:4326&HEIGHT=360&LAYERS=test:res_25_50_lOM_bfond_lFR_Lo&STYLES=&BBOX=-25.043782837128,45.976133651709006,25.043782837304,66.023866348449
2012-10-05 18:00:56,314 DEBUG [geonetwork.harvester] - Get 200
2012-10-05 18:00:56,414 DEBUG [geonetwork.harvester] - - File:
2012-10-05 18:00:56,682 INFO [geonetwork.harvester] - Ended harvesting from
node : Webservice-Energy:Test (OgcWxSHarvester)
So everything seems to went OK.
I can view the b62672909ceda9e5b6fb864476b50086643b9ba5.png and the
b62672909ceda9e5b6fb864476b50086643b9ba5_s.png PNG files.
[root@anonymised.com]# pwd
/var/lib/tomcat6/webapps/geonetwork
[root@anonymised.com]# find . -name "b62672909ceda9e5b6fb864476b50086643b9ba5.png"
-print
./WEB-INF/data/data/metadata_data/00400-00499/446/public/b62672909ceda9e5b6fb864476b50086643b9ba5.png
But unfortunately the thumbnails are not attached to the metadata record
when I display them in the GeoNetwork interface.
Could you put me back on tracks.
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5006720.html
Hi Lionel,
I had the same issue as yourself with the OGCWxs harvester
(no thumbnail displayed in the search results, but harvested
OK to the data directory). I reported this issue here:
http://trac.osgeo.org/geonetwork/ticket/1006
Would be great if the devs. could look into fixing this one.
Andrew
----- Original Message ----- From: "Lionel Menard" <lionel.menard@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Saturday, October 06, 2012 3:24 AM
Subject: Re: [GeoNetwork-users] Harvest GeoServer with thumbnails creation(GeoNetwork V. 2.9))
document:
-print
Lionel
Hi Andrew,
thanks for sharing this info.
Yes please devs...provides us with some hints...
In your ticket, you mention:
"However the XML is missing for the
gmd:graphicOverview><gmd:MD_BrowseGraphic> .... which holds the thumbnail
reference is missing so no thumbnail is displayed in the search results."
Could you tell me in which file this missing tag is supposed to be part of ?
Lionel
andrew walsh wrote
Hi Lionel,
Andrew
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5007071.html
as I always see the glass half full rather than half empty and as the
thumbnails are automatically created during the harvest process I can
manually add them using the "File identifier" unique number to the
Metadata record.
Long operation though with hundreds of records...
By the way, where does the large file is supposed to be available. I was
guessing that this would be done by clicking on the thumbnail, but it is not
clickable ?
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5007116.html
Hi Lionel,
The XML file I mention is the metadata record which is harvested by the
OGCWxS harvester. The XML fragment which references the thumbnail should look
like:
<gmd:graphicOverview>
<gmd:fileName>
<gco:CharacterString>7ebe857c-9e99-4250-ac50-151ff12124d2_s.png</gco:CharacterString>
</gmd:fileName>
<gmd:fileDescription>
<gco:CharacterString>thumbnail</gco:CharacterString>
</gmd:fileDescription>
<gmd:fileType>
<gco:CharacterString>png</gco:CharacterString>
</gmd:fileType>
</gmd:MD_BrowseGraphic>
</gmd:graphicOverview>
<gmd:fileName>
<gco:CharacterString>7ebe857c-9e99-4250-ac50-151ff12124d2.png</gco:CharacterString>
</gmd:fileName>
<gco:CharacterString>large_thumbnail</gco:CharacterString>
<gmd:fileType>
</gmd:fileType>
For example see this URL:
http://www.metoc.gov.au/geonetwork/srv/en/metadata.show?id=2301&currTab=simple
HTH
Andrew
Sent: Monday, October 08, 2012 8:13 PM
Subject: Re: [GeoNetwork-users] Harvest GeoServer with thumbnailscreation(GeoNetwork V. 2.9))
Hi Andrew,
Lionel
andrew walsh wrote
Hi Lionel,
Andrew
Hi Lionel,
Adding the thumbnail manually would be a very tedious and error prone
process, better to get the harvester fixed to back how it was in GN 2.6.4. Generally harvested
records shouldn't be edited as it disrupts the integrity of harvest process should
records be re-harvested.
The OGCWxS harvester is currently only doing "half the glass", its just missing the XML fragment
I mentioned in my last email to you.
Andrew
Sent: Monday, October 08, 2012 10:37 PM
Metadata record.
clickable ?
Lionel
Hi Andrew,
thanks for pointing the xml fragment.
Regarding your advice below, I'm aware of the harvest process integrity.
In my harvest "use case" I have a series of WMS in my GeoServer that I
consider as "final" and I will not harvest it twice.
I have set the harvest process to this series by specifying the GeoServer
"namespace" in the target url of the Harvest Management section.
By doing so I expect to manage possible harvest option of the same GeoServer
(One shot vs re-harvest).
As a result I only get this subset as a starter for editing and enhancing
these harvested records (eg. Thumbnails).
What other option, beside manually editing from scratch hundreds of records
do I have .
Does this practice could present some latter drawbacks I did not think of ?
Of course I would prefer the thumbnails to be ok...
Lionel
andrew walsh wrote
Hi Lionel,
Generally harvested
process
should
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5007306.html
Hi Lionel,
If, as you say your harvests will be "once-only" and you are not concerned with map updates
then I suppose its OK to allow editing of the harvested content. Of course keep in mind
that if you did re-harvest in future you could lose your manual additions.
You could switch off the thumbnail option in the harvestor and add your own thumbnail
graphics later through the Geonetwork editor. This process would let you add nicer
looking thumbnail graphics to than the ones that Geonetwork makes which
are only the 1 basic map layer with points/lines/polgyon
Andrew
Sent: Tuesday, October 09, 2012 4:27 PM
Subject: Re: [GeoNetwork-users] Harvest GeoServer withthumbnailscreation(GeoNetwork V. 2.9))
Hi Andrew,
do I have .
Lionel
andrew walsh wrote
Hi Lionel,
Generally harvested
process
should
Hi Andrew,
thanks for sharing your thoughts and experience about this. I appreciate...
I consider the generation of thumbnails for my WMS based maps to be rather
good and considering the amount of layers (few hundreds) I think this a
quite productive approach vs manually created them.
All the best.
Lionel
andrew walsh wrote
Hi Lionel,
with
map updates
keep
in mind
own
thumbnail
add
nicer
Andrew
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5007326.html
Hi Andrew, testing the WMS you provided using trunk was working fine.
I also tested mapserver or GeoServer WMS with success.
@Lionel, is your WMS public ? so I could have a try. Did you test
using version 1.1.1 or 1.3.0 - did you get the same results ?
This morning, I made a minor changes related to a bug if you use a
custom directory (which is probably not the case). I'll have a try
later on 2.8.x branch.
Cheers.
Francois
2012/10/8 andrew walsh <awalsh@anonymised.com>:
Hi Lionel,
Andrew
document:
-print
Lionel
Hi Francois,
I just test the harvest with 1.3.0:
1/ I don't have any thumbnails attached in the metadata record.
2/ The big png file (900x360) as well as the small one (_s 180x72) that have
been created while harvesting are all containing a blank rectangle as png
result file ?
I will provide you with the GetCapabilities of my GeoServer in a private
email for testing as this section is not yet available for public.
Cheers.
Francois
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5007345.html
any updates on this topic... ?
I have a bunch of WMS layers I postpone to harvest waiting for this feature
to possibly work as it could save me a great amount of time....
Thanks again.
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5008608.html
Lionel,
2012/10/15 Lionel Menard <lionel.menard@anonymised.com>
I finally managed to look more in details into this problem. It should be
fine now [1].
Cheers.
Francois
[1] http://trac.osgeo.org/geonetwork/ticket/1197
Thanks again.
Lionel
Dear Francois, dear all,
I finally coming back on this topic with a successful harvest including
thumbnail creation on the fly.
We have updated our catalog and we use now the latest version (2.9) of
GeoNetwork available in the Github.
Your fix were part of this version.
You can have a look by searching for example for "cener" in our catalog:
http://geocatalog.webservice-energy.org
Thanks a lot for your effort. This is to my opinion a very handy feature.
Nevertheless I've face some problems.
1/ Mapservers that were part of my targeted list of server does not seems to
provide this feature. Search for "sander"in the catalog. Is there a reason
why ?
2/ One Geoserver does not provide thumbnails. Search for "chile" on the
catalog. Is this something on the server side or how could I provide a
diagnostic ?
3/ Some thumbnails are provided but they are blank while the Mapviewer is
correctly displaying the layer. Search for "annual mean wind speed 100".
What is happening in that case ?
Thanks again for any hints or help you might provide.
Best regards,
Lionel
View this message in context: http://osgeo-org.1560.n6.nabble.com/Harvest-GeoServer-with-thumbnails-creation-GeoNetwork-V-2-9-tp5006662p5036682.html
