[GeoNetwork-users] Harvesting ArcSDE metadata - "Harvested Nothing"
I am trying out GeoNetwork and have hit a problem, I am trying to harvest
metadata that is held within ArcSDE - Oracle 11g - Under Harvesting
Management, when I try and Run the harvest i get the following in the
command prompt
/Connected to ArcSDE
start retrieve metadata
cool
Start of alignment for
ArcSDE harvest finished/
However when I go into the History, "Harvested Nothing" appears. I have made
that the data has metadata but it doesn't seem to be picked up.
has anyone come across this problem or know a way so the metadata is picked
up?
Thanks
Halil
View this message in context: http://osgeo-org.1560.x6.nabble.com/Harvesting-ArcSDE-metadata-Harvested-Nothing-tp5072530.html
I have also encountered this problem, any solutions would be really
appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Harvesting-ArcSDE-metadata-Harvested-Nothing-tp5072530p5072680.html
The ArcSDE harvester definitely could use some improvements, but not many developers have an ArcSDE server/license/jars etc I guess.
For some clients we had Heikki develop harvesting from a SDE database schema directly from the database using JDBC (so no ESRI jars required, can be used without ArcSDE server and easier to get working) a long time ago, but that was never merged into the main geonetwork core for some reason.
Recently I dusted off this code and made some improvements to it (support for SDE 10.x schema, MSSQL support, a little bit better logging, etc.). It's still not perfect and I have not had time to make a pull request to merge it back in (was developed on 2.8.x but will probably work on 2.10).
I think you can see most differences here:
https://github.com/B3Partners/core-geonetwork/compare/geonetwork:2.8.x...geonetwork_b3p
Note: use only these files and include the Oracle JDBC driver (ojdbc5.jar) on the classpath:
web/src/main/java/org/fao/geonet/arcgis/ArcSDEConnection.java
web/src/main/java/org/fao/geonet/arcgis/ArcSDEConnectionException.java
web/src/main/java/org/fao/geonet/arcgis/ArcSDEMetadataAdapter.java
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEConnectionType.java
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEHarvester.java
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEHarvesterException.java
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEParams.java
web/src/main/webapp/loc/dut/xml/harvesting.xml
web/src/main/webapp/loc/eng/xml/harvesting.xml
web/src/main/webapp/scripts/harvesting/arcsde/arcsde.js
web/src/main/webapp/scripts/harvesting/arcsde/model.js
web/src/main/webapp/scripts/harvesting/arcsde/view.js
web/src/main/webapp/xsl/conversion/import/Unwrap_ISO19139_and_ArcCatalog9_to_ISO19115.xsl
web/src/main/webapp/xsl/harvesting/arcsde/arcsde.xsl
web/src/main/webapp/xsl/harvesting/arcsde/client-result-tip.xsl
web/src/main/webapp/xsl/xml/harvesting/arcsde.xsl
Note that when configuring the harvester you have to select import xslt Add-gmd-prefix.xsl (actually this is probably required for all harvester types).
Matthijs
On 2013-08-14 16:50, hsiddique wrote:
command prompt
cool
up?
FYI,
NIWA in NZ is currently funding the development of a an Open Source tool providing a CSW service sitting on top of ESRI (Arc Server) geodatabases.
Geonetwork is our preferred metadata catalogiong tool, and we want to be able to automatically harvest the SDE geodatabase metadata into our institutional Geonetwork catalogue. Rather than trying to get Geonetwork to "speak" ESRI, we have chosen to provide a generic tool that ESRI users can apply to their databases to provide an open CSW service, that can be used by Geonetwork users in particular, but also (for example) by QGIS users with a QGIS CSW client.
Hopefully more news soon.
Brent Wood
To: geonetwork-users@lists.sourceforge.net
Sent: Friday, August 16, 2013 7:10 PM
Subject: Re: [GeoNetwork-users] Harvesting ArcSDE metadata - "Harvested Nothing"
reason.
types).
Matthijs
command prompt
cool
up?
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
