When harvesting content from another geonetwork server, is the metadata
schema still supposed to be autodetected? I tested the harvester
functionality to harvest some content from a bluenetMEST server. The data
has the following in the metadata
<gmd:metadataStandardName>
<gco:CharacterString
xmlns:srv="http://www.isotc211.org/2005/srv">Australian Marine Community
Profile of ISO 19115:2005/19139</gco:CharacterString>
</gmd:metadataStandardName>
<gmd:metadataStandardVersion>
xmlns:srv="http://www.isotc211.org/2005/srv">MCP:BlueNet
V1.4</gco:CharacterString>
</gmd:metadataStandardVersion>
This should make it get autodetected to a iso19139.mcp-1.4 however they are
getting loaded as iso19139.mcp. I know on the bluenetMEST server the schema
id are iso19139.mcp. So it seems like it is trusting to harvesting site when
setting the schema id? Is this correct?
Note: If I attempt to load one of the harvested file manually on our server,
they get autodetected to the iso19139.mcp-1.4 as expected.
Thank you.
View this message in context: http://osgeo-org.1560.n6.nabble.com/harvesting-question-regarding-the-schema-identification-tp5012511.html
