[GeoNetwork-users] Harvesting
Hi
My name is maria, I wonder if anyone knows how I can import some
matadatos found
in xml file to local filesystem geonetwork harvesting, I could import them to
be displayed.
Thank you.
Hi Maria
If you need to import the metadata records to edit them later in
GeoNetwork, it's better to use *Administration* > *Batch import* option
instead of harvester, as harvested metadata is not editable by
default. This can be changed in Administration > System configuration,
enabling the setting "Allow editing on harvested records", but if you run
harvester again, will loose edit changes.
If you use *Batch import* option, note that the folder you have to
configure should be a folder accesible from the server where GeoNetwork is
installed, not a folder in your local computer.
If you want to use anyway the *Local Filesystem harvester*, possibly same
stuff related to the directory applies (not sure at all as never used this
harvester).
Jose García
On Fri, Sep 28, 2012 at 10:14 AM, Maria Lozano Bernal <
mafelozanobernal@anonymised.com> wrote:
Hi
matadatos found
to
be displayed.
Thank you.
Got visibility?
Most devs has no idea what their production app looks like.
Find out how fast your code is with AppDynamics Lite.
http://ad.doubleclick.net/clk;262219671;13503038;y?
http://info.appdynamics.com/FreeJavaPerformanceDownload.html
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
Hi Jose, I am a co-worker of Maria.
Our plan is to edit metadata using a separate tool, so the local
harvesting module seems the best option.
We have configured it, but we been unable to harvest any metadata
(even if the same metadata records can be correctly imported using
manual import) and the user manual doesn't contain any information
about this harvester (we are using 2.8.0 RC1 version).
Do you have any clue?
Best regards,
César
2012/9/28 Jose Garcia <jose.garcia@anonymised.com>:
Hi Maria
harvester).
Jose García
Hi
matadatos found
to
be displayed.
Thank you.
Got visibility?
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Got visibility?
   César Martínez Izquierdo
   GIS developer
   ETC-SIA: http://sia.eionet.europa.eu/
   Universitat Autònoma de Barcelona (SPAIN)
Hi Cesar
When the harvester finishes do you get any error in the harvester list? If
you put the mouse over the error icon, should provide some information
about the error.
Also hopefully more detailed information about the issue should be
available in the log file (logs/geonetwork.log). If no information in the
log file, please set DEBUG level for harvester module in
INSTALL_DIR/geonetwork/WEB-INF/log4j.cfg, adding or editing if exists this
line:
log4j.logger.geonetwork.harvester = DEBUG
Restart GeoNetwork after the change and execute the harvester to check the
log file.
Jose García
On Fri, Sep 28, 2012 at 12:12 PM, César Martínez Izquierdo <
Best regards,
César
> Hi Maria
is
this
> harvester).
> Regards,
> Jose García
>> Hi
>> matadatos found
them
>> to
>> be displayed.
>> Thank you.
>> Got visibility?
>> _______________________________________________
on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
> Got visibility?
   GIS developer
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Thanks for the advise Jose, we'll perform several tests on DEBUG mode
and report back the results.
Best regards,
César
Hi Cesar
you put the mouse over the error icon, should provide some information about
the error.
Also hopefully more detailed information about the issue should be available
in the log file (logs/geonetwork.log). If no information in the log file,
line:
log file.
Jose García
Best regards,
César
> Hi Maria
> run
> is
> same
> this
> harvester).
> Regards,
> Jose García
>> Hi
>> matadatos found
>> them
>> to
>> be displayed.
>> Thank you.
>> Got visibility?
> on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
> Got visibility?
   GIS developer
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
   GIS developer
Hello again, we have performed some tests.
It seems the harvester finds an offending XML file and the process
stops, thus no metadata is imported. This is quite inconvenient (and
IMHO should be considered a bug), as many .XML files may be present in
the file system, not necessarily being metadata records, so the proper
behaviour should be to skip invalid metadata and import real metadata.
The log says:
    <error id="no-schema-matches">
      <message>Autodetecting schema failed for metadata record with
root element PAMDataset in namespace [Namespace: prefix "" is mapped
to URI ""].</message
      <class>NoSchemaMatchesException</class>
      <stack>
        <at class="org.fao.geonet.kernel.SchemaManager"
file="SchemaManager.java" line="640" method="autodetectSchema" />
        <at class="org.fao.geonet.kernel.DataManager"
file="DataManager.java" line="1362" method="autodetectSchema" />
file="DataManager.java" line="1343" method="autodetectSchema" />
        <at class="org.fao.geonet.kernel.harvest.harvester.localfilesystem.LocalFilesystemHarvester"
file="LocalFilesystemHarvester.java" line="244" method="align" />
file="LocalFilesystemHarvester.java" line="397" method="doHarvest" />
        <at class="org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor"
file="AbstractHarvester.java" line="397" method="process" />
        <at class="org.fao.geonet.kernel.MetadataIndexerProcessor"
file="MetadataIndexerProcessor.java" line="39"
method="processWithFastIndexing" />
        <at class="org.fao.geonet.kernel.harvest.harvester.AbstractHarvester"
file="AbstractHarvester.java" line="427" method="harvest" />
        <at class="org.fao.geonet.kernel.harvest.harvester.HarvesterJob"
file="HarvesterJob.java" line="29" method="execute" />
        <at class="org.quartz.core.JobRunShell"
file="JobRunShell.java" line="213" method="run" />
        <skip>...</skip>
      </stack>
    </error>
Best regads,
César Martínez
2012/10/1 César Martínez Izquierdo <cesar.izq@anonymised.com>:
Best regards,
César
Hi Cesar
the error.
line:
log file.
Jose García
Best regards,
César
> Hi Maria
> run
> is
> same
> this
> harvester).
> Regards,
> Jose García
>> Hi
>> matadatos found
>> them
>> to
>> be displayed.
>> Thank you.
>> Got visibility?
> on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
> Got visibility?
   GIS developer
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
   GIS developer
   GIS developer
Hi again, I have workarounded the problem by setting "Validate"
option. Maybe this is the intended behaviour of the harvester..
Best regards,
César
2012/10/4 César Martínez Izquierdo <cesar.izq@anonymised.com>:
The log says:
      <stack>
        <skip>...</skip>
      </stack>
    </error>
Best regads,
César Martínez
Best regards,
César
Hi Cesar
the error.
line:
log file.
Jose García
Best regards,
César
> Hi Maria
> run
> is
> same
> this
> harvester).
> Regards,
> Jose García
>> Hi
>> matadatos found
>> them
>> to
>> be displayed.
>> Thank you.
>> Got visibility?
> on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
> Got visibility?
   GIS developer
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
   GIS developer
   GIS developer
   GIS developer
