Hi All,
Many thanks for Jesse's comments and Heikki's and Jose's presentation on
"Mastering Advanced GeoNetwork" at URL
http://geonetwork-opensource.org/_static/foss4g2010/FOSS4G_Mastering_Adv
anced_GeoNetwork.pdf.
I have been able to rebuild the database but unable to load the database
dump from postgresql version 8.3 (the old GN setup) to postgresql
version 8.4 (the new GN setup). However, I have started copying and
pasting the content from one GN setup to another. It looks like about
three days work and I'm about half way through it. Having said that, I
am still happier than before because I now know why the errors were
occuring (the database was not a postgis database), learnt a lot about
the GN database structure and have now been able to load by hand the
metadata and it isn't creating errors!
So many thanks to those on this list who have helped.
John Hockaday
-----Original Message-----
From: Jesse Eichar [mailto:jesse.eichar@anonymised.com]
Sent: Monday, June 04, 2012 5:15 PM
To: john.hockaday
Cc: geonetwork-users; geonetwork-devel
Subject: Re: [GeoNetwork-devel] Have rebuild database and
loaded GN but still get WARNING: CORRUPT DATA IN DATABASE: No
localization found for record in table Groups with id: 2,
skipping it. errors
I just think this means that you need to add translations for
your groups. This really is just a warning. I am not sure
the fix, I think you might be able to go to the
/geonetwork/srv/eng/localization and descriptions to all your
groups (just english in your case most likely).
Or perhaps you will have to edit the table directly. What I
just went through this myself and what I did was I created a
empty postgis database and started vanilla geonetwork
configured to use that database. Then I compared my
configuration against the clean one.
Jesse
On Mon, Jun 4, 2012 at 9:00 AM, john.hockaday
<john.hockaday@anonymised.com> wrote:
Hi All,
Thanks to Jesse I have been able to rebuild the postgis
database and
start GN. I have had to copy by hand all the content
from the original
GN into the new one. During that process I have been
adding the 'groups'
using the administration interface. I keep on getting
the following in
the catalina.out file:
WARNING: CORRUPT DATA IN DATABASE: No localization
found for record in
table Groups with id: 2, skipping it.
Does anyone know what this is? Will it mean that all my
work will be in
vane?
Thanks in advance for any help.
John Hockaday
Live Security Virtual Conference
Exclusive live event will cover all the ways today's
security and
threat landscape has changed and how IT managers can
respond. Discussions
will include endpoint security, mobile security and the
latest in malware
threats.
http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
The information contained in this e-mail, and any attachments to it,
is intended for the use of the addressee and is confidential. If you
are not the intended recipient you must not use, disclose, read,
forward, copy or retain any of the information. If you received this
e-mail in error, please delete it and notify the sender by return
e-mail or telephone.
The Commonwealth does not warrant that any attachments are free
from viruses or any other defects. You assume all liability for any
loss, damage or other consequences which may arise from opening
or using the attachments.
The security of emails transmitted in an unencrypted environment
cannot be guaranteed. By forwarding or replying to this email, you
acknowledge and accept these risks.
