I would like to customize the export as csv function in Geonetwork 3.8.1.
I know that the file to edit is the tpl-csv.xsl which, in my case, is located here
geonetwork/WEB-INF/data/config/schema_plugins/iso19115-3.2018/layout/tpl-csv.xsl
The output I would like to have is the following one:
"title","cloud coverage","category","date-creation" "S2A_MSIL1C_20151127T103352_N0204_R108_T32TLS_20151127T103440","36.6172","dataset","2015-11-27T10:34:40"
I did some test but I'm only able to have
"schema","uuid","id","cit:title","gco:Real","category","date-creation" "iso19115-3.2018","89d82f0a-051e-11ea-80ac-02000a08f492","1155","S2A_MSIL1C_20151127T103352_N0204_R108_T32TLS_20151127T103440","36.6172","dataset","2015-11-27T10:34:40",
How can I edit in a more correct way the tpl-csv.xsl?
Bartolomeo Ventura, PhD
Eurac Research
Institute for Earth Observation
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/>
