Hi Benchekroun,
I posted some scripts a few weeks back about how to do this on MS-SQL, in case you are using this DBMS. You can check the archives, or mail me off line if you need more details. I have not checked these against the latest versions though, so the scripts may or may not work, but the procedure should be the same.
Good luck.
From: geonetwork-users-bounces@lists.sourceforge.net on behalf of Andrea Carboni
Sent: Wed 5/30/2007 3:58 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] How to install the Database on an atherserver
Hi Benchekroun,
start GAST and:
- select a different dbms
- redo the setup into the new db
Make sure to copy the jdbc driver of your dbms into the web/WEB-INF/lib folder.
Hi All,
Could any one help me on how to install the database (data, xml files, etc)
on an other server than the one where geonetwork is installed?.The default installing process installs the database on the server wher
geonetwork is installed and don't allow to modify the location for the
database.Thanks in advance,
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-users mailing list
