[GeoNetwork-users] How to integrate MapServer instead of Intermap
Hello list,
starting the new year I made an upgrade to GN2.2. Now I'm going to customize the application.
I'm using MapServer for publishing spatial data. So I would like to integrate MapServer in GN instead of Intermap. Does anyone tried to change the mapping application? Which files have to be modified?
Any suggestions are welcome.
Best regards,
Christian
Hi Christian,
InterMap is not the same as MapServer. InterMap is only a web client application while MapServer can serve up the maps. So you can use MapServer to run your WMS services and then visualize them in InterMap. This is what we do for all the services at the FAO for instance.
Ciao,
Jeroen
On Jan 7, 2009, at 4:25 PM, Christian Gadge wrote:
Hello list,
Best regards,
Christian
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
