[GeoNetwork-users] Implementing custom schema
Dear List,
I am currently implementing a schema for a bespoke iso 19139 profile. I
have managed to get the project compiling using the .xyz template and
GeoNetwork seems to accept the profile. However, I get the following error
when trying to view or edit the metadata using the bespoke profile:
Error at xsl:call-template on line 93 of base-variables-metadata.xsl:
Template get-<profile name>-configuration has not been defined
I imagine that I have to configure the style sheets somewhere, but I cannot
find where!
Thanks
Hi Sam
https://github.com/geonetwork/schema-plugins/tree/develop/iso19139.xyz was
updated 4 years ago, there're quite changes in the schemas since then.
You need to check the documentation of the schemas:
https://geonetwork-opensource.org/manuals/3.4.x/en/customizing-application/implementing-a-schema-plugin.html,
to check if helps with all the templats that require to be implemented.
Additionally you can give a try to this tool:
https://github.com/josegar74/generator-geonetwork-metadata-schema
Jose García
On Tue, Aug 21, 2018 at 11:57 AM, Sam Meek <sam.meek@anonymised.com> wrote:
Dear List,
find where!
Thanks
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
