[GeoNetwork-users] import contacts into the Organizations & contacts directory
I saw that it is now possible to import a point of contact into the /Organizations & contacts/ directory, using the import form.
I can do it easily one by one, by dropping the xml file into the form. But I would like to do it on a large number of files.
Is it possible to import a bunch of points of contacts, using a MEF archive ?
If yes, do you have an example of what this archive should look like (beside ? Since I didn't find a way to export the points of contact as a MEF archive, I find it difficult to guess exactly what is expected (And I must admit, a bit too lazy to look in the code for that)
Actually, in an ideal world, I would even like to run the import using the API. Is there an API endpoint for that ? I didn't find any
Thanks in advance,
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
linkedin : jean-pommier <https://www.linkedin.com/in/jean-pommier/&gt;
