Hi!
What can I do to populate the empty items with swedish titles? There are
valid INSPIRE themes behind them.
!image.png|1853x936
*GisKraft*, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se
On Tue, Jul 20, 2021 at 12:12 PM Mats Elfström via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Hi!
[image: image.png]
Use a RDF thesaurus with Swedish translations. You can do this:
1. Go to
https://example.com/geonetwork/srv/eng/admin.console#/classification/thesaurus
(Admin Console -> Classification Systems -> Thesaurus )
2. Delete the current GEMET - INSPIRE Themes, version 1.0 (themes)
thesaurus
3. Add thesaurus -> From Registry
4. Use the INSPIRE Registry (to fill the URL field)
5. Choose the languages you want to provide to your users (English, Swedish)
6. Choose registry item class: INSPIRE theme registry and Theme
7. Click on the Upload button. This should download the thesaurus from the
INSPIRE Registry in the languages selected and install it in GeoNetwork.
8. Run a Reindex so the index contain the right data (I'm not sure if this
step is needed)
Another option could be to download the GEMET RDF file from GeoNetwork,
modify it to add your translations and upload it again to GN.
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
