[GeoNetwork-users] Install geonetwork release 2.1
Hello,
I was working with the release 2.0.3 and i try today ton install the release
2.1.
We use geonetwork for the futur metadata management on the Europeen evoltree
project
We work with java 1.5.0 and tomcat 4.1.
When i start tomcat i have the error bellow with the new release:
Did the tomcat release 5 is necessary ?
I haven't see anything strange on the config.xml.
Do you have any idea of the problem ?
localhost_2007-09-24.log
2007-09-24 15:06:32 WebappLoader[/geonetwork]: Deploy JAR
/WEB-INF/lib/xalan.jar to
/usr/local/geonetworkbeta/web/geonetwork/WEB-INF/lib/xalan.jar
2007-09-24 15:06:32 StandardManager[/geonetwork]: Alimentation de la classe
du g?n?rateur de nombre al?atoire java.security.SecureRandom
2007-09-24 15:06:32 StandardManager[/geonetwork]: L'alimentation du
g?n?rateur de nombre al?atoire est termin?
2007-09-24 15:06:32 gn-servlet: init
2007-09-24 15:06:32 StandardContext[/geonetwork]: La servlet /geonetwork a
g?n?r? une exception "load()"
javax.servlet.ServletException: "Servlet.init()" pour la servlet gn-servlet
a g?n?r? une exception
  at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:916)
  at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:776)
  at
org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3363)
  at
org.apache.catalina.core.StandardContext.start(StandardContext.java:3586)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1141)
  at org.apache.catalina.core.StandardHost.start(StandardHost.java:707)
  at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:316)
  at org.apache.catalina.core.StandardService.start(StandardService.java:450)
  at org.apache.catalina.core.StandardServer.start(StandardServer.java:2143)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:463)
  at org.apache.catalina.startup.Catalina.execute(Catalina.java:350)
  at org.apache.catalina.startup.Catalina.process(Catalina.java:129)
  at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:156)
----- Root Cause -----
java.lang.ExceptionInInitializerError
  at jeeves.server.JeevesEngine.loadConfigFile(JeevesEngine.java:182)
  at jeeves.server.JeevesEngine.init(JeevesEngine.java:131)
  at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:65)
  at javax.servlet.GenericServlet.init(GenericServlet.java:258)
  at
org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:888)
  at
  at
  at
  at
Caused by: java.lang.IllegalArgumentException:
http://www.w3.org/2001/XMLSchema
  at javax.xml.validation.SchemaFactory.newInstance(Unknown Source)
  at jeeves.utils.Xml.<clinit>(Xml.java:262)
  ... 22 more
2007-09-24 15:06:32 StandardWrapper[/geonetwork:default]: Chargement du
conteneur (container) de servlet default
2007-09-24 15:06:32 default: init
2007-09-24 15:06:32 StandardWrapper[/geonetwork:invoker]: Chargement du
conteneur (container) de servlet invoker
2007-09-24 15:06:32 invoker: init
2007-09-24 15:06:32 jsp: init
2007-09-24 15:06:32 WebappLoader[/tomcat-docs]: Deploying class repositories
to work directory /var/lib/tomcat4/work/Standalone/localhost/tomcat-docs
catalina_2007-09-24.log
Using CATALINA_BASE: /var/lib/tomcat4
Using CATALINA_HOME: /usr/share/tomcat4
Using CATALINA_TMPDIR: /var/lib/tomcat4/temp
Using JAVA_HOME: /opt/jdk1.5.0_10
Using Security Manager
24 sept. 2007 15:06:32 org.apache.coyote.http11.Http11Protocol init
INFO: Initialisation de Coyote HTTP/1.1 sur http-8180
D?marrage du service Tomcat-Standalone
Apache Tomcat/4.1
2007-09-24 15:06:32,893 INFO [jeeves.engine] - === Starting system
2007-09-24 15:06:32,894 INFO [jeeves.engine] - Java version : 1.5.0_10-b03
2007-09-24 15:06:32,894 INFO [jeeves.engine] - Java vendor : Sun
Microsystems Inc.
2007-09-24 15:06:32,904 INFO [jeeves.engine] - XSLT factory :
org.apache.xalan.transformer.TransformerIdentityImpl
2007-09-24 15:06:32,905 INFO [jeeves.engine] - Path :
2007-09-24 15:06:32,905 INFO [jeeves.engine] - BaseURL : geonetwork
2007-09-24 15:06:32,905 INFO [jeeves.engine] - Loading :
/usr/local/geonetworkbeta/web/geonetwork/WEB-INF/config.xml
24 sept. 2007 15:06:33 org.apache.struts.util.PropertyMessageResources
<init>
INFO: Initializing, config='org.apache.struts.util.LocalStrings',
returnNull=true
<init>
INFO: Initializing, config='org.apache.struts.action.ActionResources',
returnNull=true
24 sept. 2007 15:06:34 org.apache.struts.util.PropertyMessageResources
<init>
INFO: Initializing, config='org.apache.webapp.admin.ApplicationResources',
returnNull=true
24 sept. 2007 15:06:35 org.apache.coyote.http11.Http11Protocol start
INFO: D?marrage de Coyote HTTP/1.1 sur http-8180
24 sept. 2007 15:06:35 org.apache.jk.common.ChannelSocket init
INFO: JK2: ajp13 listening on /0.0.0.0:8009
24 sept. 2007 15:06:35 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=1/83 config=/var/lib/tomcat4/conf/jk2.properties
Thank you by advance for your help.
Fabien Bachraty
INRA Avignon France
View this message in context: http://www.nabble.com/Install-geonetwork-release-2.1-tf4509555s18419.html#a12861104
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Fabien,
Yes, you will have to use Tomcat 5.5. Most configuration can now also be done through the admin interface and by using GAST. You will have to run GeoNetwork temporarily on the embedded Jetty servlet engine when using GAST.
Ciao,
Jeroen
On Sep 24, 2007, at 4:32 PM, FBachraty wrote:
Hello,
2.1.
project
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 22 more
Apache Tomcat/4.1
Microsystems Inc.
<init>
returnNull=true
<init>
returnNull=true
<init>
returnNull=true
Fabien Bachraty
INRA Avignon France
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Thank you!
I am going to try it :slight_smile:
Have a nice day
View this message in context: http://www.nabble.com/Install-geonetwork-release-2.1-tf4509555s18419.html#a12874129
