hello together,
i want to install gn261 on a debian box without x. the following problem occur
when filling the database with gast over :
Exception in thread "main" java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which
requires it.
the old sqls which are normally stored in gast/setup/sql/ are not there. it
seems to be, that the sql's are generated dynamically by using the file
database.druid.
is there a chance to get the sql's and push them by psql or mysql cli into the
database?
thanks and regrads
armin
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
http://www.geoportal.rlp.de
hi,
you can find sql scripts to create, and to populate your DB, in
<installation-dir>/web/src/main/webapp/WEB-INF/classes/setup/sql.
Kind regards
Heikki Doeleman
2010/11/22 Armin Retterath <armin.retterath@anonymised.com>
hello together,
occur
which
requires it.
database.druid.
the
database?
thanks and regrads
armin
Im Auftrag
Armin Retterath
beim
56073 Koblenz
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
GeoNetwork-users mailing list
