Hi, I have embedded Intermap in Geonetwork and when I want to send a WMC
context I get an error:
An unexpected error has been encountered while processing the mail:
Resource not found
Have I to configure anything? thank you for answers, regards
View this message in context: http://n2.nabble.com/Intermap%3A-Send-a-WMC-Context-via-e-mail-tp2454240p2454240.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Resource not found
Ok, I only had to configure the SMTP server in config.xml, regards
View this message in context: http://n2.nabble.com/Intermap%3A-Send-a-WMC-Context-via-e-mail-tp2454240p2454338.html
From http://geonetwork3.fao.org/geonetwork I sent a context file to myself,
and my application is uploading it for minutes and minutes... I think we
don't need to keep the original name InteractiveMap.cml?
I just try to create a context to be used to quickly tailor the view.
Saving a cml seems not to work ("not able to find the site", localhost). Why
so? What needs to be configured? In our case the GN server is in intranet,
or standalone.
Arto
P.S. You could also give some details on how to configure the SMTP server in
config.xml (of intermap or of geonetwork)? What exactly to write and where?
If someone's using mostly a web mail, from where to get the settings? See
http://lifehacker.com/111166/how-to-use-gmail-as-your-smtp-server.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Intermap-Send-a-WMC-Context-via-e-mail-tp2454240p5075250.html
In Firefox 3.6.3 the cml from the FAO site seems to upload OK, in IE
8.0.6001.18702CO not.
Saving a cml would be nice if it worked on our own site, too...
Arto
Some more experiences with cml files, but not sure which depend on the
instantenous state of the network here or whatever reason making things a
bit unreliable:
If you Upload a Context (in Firefox where it works), it seems the map scale
text is not refreshed but remains as the global 1: 414 million or so, until
you e.g. hide and show a layer.
Sometimes the mini map keeps on loading for ever. And the "The context file
is uploading..." message never disappears or changes even when the mini map
becomes ready.
Saving the cmls actually seems possible using Firefox. If you load the cml
you e-mailed, the scale of map is about twice smaller but the location
correct. If you zoom in, save and load the new cml, the loading did not get
ready.
What to do to make the Select Area of Interest tool available in the larger
Map Viewer too?
Arto
