Hi all!!!!!
I have some problems with intermap (I'm looking forward for OpenLayer
in GN!!!!!).
Some time this tool crash, and the only this to do is restart tomcat!!!!
To day the problem is related to error below:
<error id="error">
<message/>
<class>NullPointerException</class>
<stack>
<at class="org.wfp.vam.intermap.kernel.map.MapMerger"
file="MapMerger.java" line="600" method="merge"/>
<at class="org.wfp.vam.intermap.services.map.Update"
file="Update.java" line="80" method="exec"/>
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService"/>
file="ServiceInfo.java" line="141" method="execServices"/>
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="377" method="dispatch"/>
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" method="dispatch"/>
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="174" method="execute"/>
file="JeevesServlet.java" line="89" method="doGet"/>
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="617" method="service"/>
line="717" method="service"/>
</stack>
<request>
<language>en</language>
<service>main</service>
</request>
</error>
This appears when I try to call http://localhst:8080/intermap.
Obviously with this error I can't to use interactive map in Geonetwork.
Any suggestions about???
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
can you start intermap from your tomcat manager?
Are the ports ok? Do you made changes to any server.xml or something like
that in the meantime?
I'm not keen with stacktraces sorry but of the message related to
httpservlet I give you my hints.
best regards
Sarah
franko wrote:
Hi all!!!!!
in GN!!!!!).
<error id="error">
<message/>
<stack>
</stack>
<request>
</request>
</error>
(IIA)
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/Intermap-tp3859071p3859216.html
