I'm sort of beginning with geonetwork.
I have to permit filling some extra information like price of the data,
contact for distribution for off-line data and some other fields that don't
seem to be in the current GN ISO19139 formular.
I may be wrong, but i believe they are part of the ISO19115. Have they been
removed from the ISO19139 spec ? Or is it just that the GN's ISO19139
profile is not complete ?
What shall i do to add these functionnalities ?
Thanks
I can only answer your questions regarding the ISO 19115 standard and ISO 19139 specification but not GN. Please see comments below:
Someone else will have to answer the rest.
-----Original Message-----
From: Jean Pommier (IGE) [mailto:jean.pommier@anonymised.com]
Sent: Monday, 19 January 2009 10:55 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] is ISO19139 schema complete ?
the data,
fields that don't
Yes.
The 'fees' element is in the MD_StandardOrderProcess class.
The 'offLine' element is in the MD_DigitalTranserOptions class.
Both of the above elements, and many more, are in the MD_Distribution package.
Have they been
I don't believe so. I have found all the above elements in the ./gmd/distribution.xsd XSD.
I didn't find it in the schemas.
OK then, i'll have to looks a bit more in the XSD to see where it should
appera in the GN interface : i still can't find it...
Thank you for your help !
Jean
2009/1/20 <John.Hockaday@anonymised.com>
Hi Jean,
> Hi,
> the data,
> fields that don't
Yes.
package.
> Have they been
Hi Jean,
The schemas have not been modified, so the fields should be there. If you can't find them in the default view, use the advanced view and you should normally be able to add them from there. If you still can't find them, try to make the required part of the document in XML format and use the XML edit view to update the XML file. That should then also make the fields useable in the advanced view and possibly in the default view.
Ciao,
Jeroen
On Jan 20, 2009, at 7:54 AM, Jean Pommier (IGE) wrote:
Thank you John !
Jean
Hi Jean,
the data,
fields that don't
Yes.
package.
Have they been
creating a new iso19139 metadata (using vector profile), the above
mentionned parts ('fees' and so on) are not present, even in the xml view. I
can find the <gmd:MD_Distribution> part, but it does not provide
MD_StandardOrderProcess sections. In the advanced view neither.
Do you mean i should add it manually in the xml view, and THEN, it will be
displayed in the other views ?
If yes, so, what is the pb ? I believe there are things I still don't
understand : where do the base metadata come from ? I believed it was an xml
squeletton automatically generated by the xsd specifications. But i suppose
i'm wrong. So where is it stored, basically ? I mean, the templates (iso
19139 for vector, iso 19139 for raster, dublin-core and fgdc-std) ?
Thanks
Hi Jean,
Ciao,
Jeroen
Thank you John !
Jean
Hi Jean,
the data,
fields that don't
Yes.
package.
Have they been
? It is wonderfully helpful in understanding how the stylesheets, schemas, and associated XML files work together to create what the user sees on the screen. After reading that document, I was able to install a totally new, non-ISO schema/template into a GeoNetwork instance in a matter of hours.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Jan 20, 2009, at 9:21 AM, Jean Pommier (IGE) wrote:
Hi Jeroen,
Thanks
Hi Jean,
Ciao,
Jeroen
Thank you John !
Jean
Hi Jean,
the data,
fields that don't
Yes.
package.
Have they been
> Hi Jeroen,
> view. I
> will be
> was an xml
> suppose
> (iso
> Thanks
> Jean
> 2009/1/20 Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>
>> Hi Jean,
>> If you
>> should
>> them, try
>> XML edit
>> useable
>> Ciao,
>> Jeroen
>> Thank you John !
>>> should
>>> Jean
>>> Hi Jean,
>>>> and ISO
>>>>> Hi,
>>>>> the data,
>>>>> fields that don't
>>>> Yes.
>>>> MD_Distribution
>>>> package.
>>>> Have they been
>>>> I can't answer these latter questions.
>>>> John
>>>> Thanks
>>>>> Jean
>>>>> This SF.net email is sponsored by:
>>>>> SourcForge Community
>>>>> SourceForge wants to tell your story.
>>>>> http://p.sf.net/sfu/sf-spreadtheword
>>>>> _______________________________________________
>>>>> GeoNetwork-users mailing list
>>>>> GeoNetwork-users@lists.sourceforge.net
>>>>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
>>>>> GeoNetwork OpenSource is maintained at
>>>>> http://sourceforge.net/projects/geonetwork
> GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
And when i open /gmd/metadataentity.xsd, XML Spy that the schema is not
valid.
So I feel lost and alone
Can you help please ?
Michel
John.Hockaday wrote:
Hi Jean,
the data,
fields that don't
Yes.
package.
Have they been
valid.
Michel
Hi Jean,
the data,
fields that don't
Yes.
package.
Have they been
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD http://p.sf.net/sfu/XcvMzF8H
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
