[GeoNetwork-users] ISO 19115-2
Hello,
I'm running Geonetwork 3.1.0 and I'm wondering if the templates I'm using
are the most up to date for the metadata? I have ISO/TS 19139:2007 but I'm
pretty sure that 19115-2 was implemented in 2009 which makes this template
out of date. Does anyone know where I can get a template for the 19115-2
standards that I can use in Geonetwork?
Heather
Heather M. Lucier
M.S. Earth System Science & Engineering
University of Michigan, 2013
2016-05-27 22:09 GMT+02:00 Heather Lucier <hlucier@anonymised.com>:
Hello,
Maybe an option is to use ISO19115-3 which includes 115-2 (see
https://github.com/metadata101/iso19115-3/tree/develop/src/main/plugin/iso19115-3/schema/standards.iso.org/19115/-2/gmi/1.0)
even if this is not yet really tested.
Some work was made in previous version of GeoNetwork but I'm not sure where
this was implemented and published.
HTH.
Francois
Heather
Heather M. Lucier
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
GeoNetwork-devel mailing list
Hi Francois,
Thanks for the link! I think that will really help. I'm fairly new to
GeoNetwork, so do I have to do anything other than following the
instructions in the README.md? For example, do I need to download any files?
Heather
On Mon, May 30, 2016 at 2:12 AM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
Hello,
where this was implemented and published.
HTH.
Francois
Heather
Heather M. Lucier
traffic
are
planning reports.
Heather M. Lucier
