Hello,
I've deployed 3.2 with a 19115-3 plugin. The current default plugin from
metadata101/19115-3 does not work. That is the edit page does not appear.
Anyway,I got it to work through a workaround....
Currently I'm trying to do a transformation from 19115:2003 to 19115-3 when
I harvest.I'm not seeing the options in the dropdown list when I batch
import or harvest. Can someone please point me in the right direction as to
where I pick up the convert folder, or is this a two prong process where I
convert from 19115:2003 to 19139 and then from 19139 to 19115-3? If that is
the case, again, where are the convert files?
Thanks in advance
Suresh
View this message in context: http://osgeo-org.1560.x6.nabble.com/iso19115-2003-to-iso19115-3-transformation-tp5302244.html
2017-01-06 4:58 GMT+01:00 sramayah <sureshramayah@anonymised.com>:
Hello,
Could you check that you're not having the same problem as here
https://github.com/metadata101/iso19115-3/issues/25 ?
Would be good to share the workaround or fix the problem if problem there
is?
Conversion for 19139<>19115-3 are here
https://github.com/metadata101/iso19115-3/tree/develop/src/main/plugin/iso19115-3/convert/ISO19139
Check that
https://github.com/metadata101/iso19115-3/blob/3.2.x/README.md#adding-the-conversion-to-the-import-record-page
and let me know if that works ok for both import record page and harvesters.
HTH.
Francois
Thanks in advance
Suresh
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
Hi Francois,Sorry for the late reply....Please see responses in >>>>Suresh
Francois Prunayre wrote
Hi,2017-01-06 4:58 GMT+01:00 sramayah <
sureshramayah@
>:> Hello,>> I've deployed 3.2 with a 19115-3 plugin. The current
default plugin from> metadata101/19115-3 does not work.Could you check
herehttps://github.com/metadata101/iso19115-3/issues/25 ?>>>>No this is an
issue with the 19115-3 plugin itself I believe. I've had a quick look at
the service.xml in the template folder. The following seems to work, at
least from what I've implemented:
service
service
AU/NZS ISO 19115-1:2014
ISO 19115-1:2014
ISO 19115-3 (Draft Schemas 2015)
2015-07-01T00:00:00
services
creation
geoscientificInformation
-180
180
-90
90
unknown
Creative Commons Attribution 4.0 International Licence
CC-BY
4.0
http://creativecommons.org/licenses/
tight
WebServices
TEXT
false
false
That is the edit page does not appear.> Anyway,I got it to work through a
workaround....>>>>>With the above service.xml I can now add a new record
from the template whereas previously I could not. I have not investigated
more dependencies around this yet....Would be good to share the
workaround or fix the problem if problem thereis?>>>>see above>>
when> I harvest.I'm not seeing the options in the dropdown list when I
batch> import or harvest. Can someone please point me in the right
direction as to> where I pick up the convert folder, or is this a two
prong process where I> convert from 19115:2003 to 19139 and then from
19139 to 19115-3? If that is> the case, again, where are the convert
files?>Conversion for 19139<>19115-3 are
herehttps://github.com/metadata101/iso19115-3/tree/develop/src/main/plugin/iso19115-3/convert/ISO19139Check
thathttps://github.com/metadata101/iso19115-3/blob/3.2.x/README.md#adding-the-conversion-to-the-import-record-pageand
harvesters.>>>>I implemented the transformation and am getting a
IllegalArgumentExceptionXML fragment is invalid. Error is Error on line
4: The prefix "gmd" for element "gmd:MD_Metadata" is not
bound.Error.......I will have to dig through this now....Will save me a
lot of time if anyone has come across this message and knows the fix
straight away.....HTH.Francois>> Thanks in advance> Suresh>>>> --> View
this message in context: http://osgeo-org.1560.x6.>
nabble.com/iso19115-2003-to-iso19115-3-transformation-tp5302244.html>
Sent from the GeoNetwork users mailing list archive at Nabble.com.>>
------------------> Check out the vibrant tech community on one of the
world's most> engaging tech sites, SlashDot.org!
http://sdm.link/slashdot>
_______________________________________________> GeoNetwork-users mailing
list>
GeoNetwork-users@anonymised.com
https://lists.sourceforge.net/lists/listinfo/geonetwork-users> GeoNetwork
OpenSource is maintained at http://sourceforge.net/>
projects/geonetwork>------------------------------------------------------------------------------Check
out the vibrant tech community on one of the world's most engaging tech
http://sdm.link/slashdot_______________________________________________GeoNetwork-users
mailing list
https://lists.sourceforge.net/lists/listinfo/geonetwork-usersGeoNetwork
OpenSource is maintained at http://sourceforge.net/projects/geonetwork
View this message in context: http://osgeo-org.1560.x6.nabble.com/iso19115-2003-to-iso19115-3-transformation-tp5302244p5302552.html
Hi Francois,
Apologies. Message got mangled. Reposting this for readability:
No this is an issue with the 19115-3 plugin itself I believe. I've had a
quick look at the service.xml in the template folder. The following seems to
work, at least from what I've implemented:
<mdb:MD_Metadata xmlns:mdb="http://standards.iso.org/iso/19115/-3/mdb/1.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:cat="http://standards.iso.org/iso/19115/-3/cat/1.0"
xmlns:cit="http://standards.iso.org/iso/19115/-3/cit/1.0"
xmlns:gcx="http://standards.iso.org/iso/19115/-3/gcx/1.0"
xmlns:gex="http://standards.iso.org/iso/19115/-3/gex/1.0"
xmlns:lan="http://standards.iso.org/iso/19115/-3/lan/1.0"
xmlns:srv="http://standards.iso.org/iso/19115/-3/srv/2.0"
xmlns:mas="http://standards.iso.org/iso/19115/-3/mas/1.0"
xmlns:mcc="http://standards.iso.org/iso/19115/-3/mcc/1.0"
xmlns:mco="http://standards.iso.org/iso/19115/-3/mco/1.0"
xmlns:mda="http://standards.iso.org/iso/19115/-3/mda/1.0"
xmlns:mds="http://standards.iso.org/iso/19115/-3/mds/1.0"
xmlns:mdt="http://standards.iso.org/iso/19115/-3/mdt/1.0"
xmlns:mex="http://standards.iso.org/iso/19115/-3/mex/1.0"
xmlns:mmi="http://standards.iso.org/iso/19115/-3/mmi/1.0"
xmlns:mpc="http://standards.iso.org/iso/19115/-3/mpc/1.0"
xmlns:mrc="http://standards.iso.org/iso/19115/-3/mrc/1.0"
xmlns:mrd="http://standards.iso.org/iso/19115/-3/mrd/1.0"
xmlns:mri="http://standards.iso.org/iso/19115/-3/mri/1.0"
xmlns:mrl="http://standards.iso.org/iso/19115/-3/mrl/1.0"
xmlns:mrs="http://standards.iso.org/iso/19115/-3/mrs/1.0"
xmlns:msr="http://standards.iso.org/iso/19115/-3/msr/1.0"
xmlns:mdq="http://standards.iso.org/iso/19157/-2/mdq/1.0"
xmlns:mac="http://standards.iso.org/iso/19115/-3/mac/1.0"
xmlns:gco="http://standards.iso.org/iso/19115/-3/gco/1.0"
xmlns:gml="http://www.opengis.net/gml/3.2"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:geonet="http://www.fao.org/geonetwork"
xsi:schemaLocation="http://standards.iso.org/iso/19115/-3/cat/1.0
http://standards.iso.org/iso/19115/-3/cat/1.0/cat.xsd
http://standards.iso.org/iso/19115/-3/cit/1.0/cit.xsd
http://standards.iso.org/iso/19115/-3/gcx/1.0/gcx.xsd
http://standards.iso.org/iso/19115/-3/gex/1.0/gex.xsd
http://standards.iso.org/iso/19115/-3/lan/1.0/lan.xsd
http://standards.iso.org/iso/19115/-3/srv/2.0/srv.xsd
http://standards.iso.org/iso/19115/-3/mas/1.0/mas.xsd
http://standards.iso.org/iso/19115/-3/mcc/1.0/mcc.xsd
http://standards.iso.org/iso/19115/-3/mco/1.0/mco.xsd
http://standards.iso.org/iso/19115/-3/mda/1.0/mda.xsd
http://standards.iso.org/iso/19115/-3/mdb/1.0/mdb.xsd
http://standards.iso.org/iso/19115/-3/mds/1.0/mds.xsd
http://standards.iso.org/iso/19115/-3/mdt/1.0/mdt.xsd
http://standards.iso.org/iso/19115/-3/mex/1.0/mex.xsd
http://standards.iso.org/iso/19115/-3/mmi/1.0/mmi.xsd
http://standards.iso.org/iso/19115/-3/mpc/1.0/mpc.xsd
http://standards.iso.org/iso/19115/-3/mrc/1.0/mrc.xsd
http://standards.iso.org/iso/19115/-3/mrd/1.0/mrd.xsd
http://standards.iso.org/iso/19115/-3/mri/1.0/mri.xsd
http://standards.iso.org/iso/19115/-3/mrl/1.0/mrl.xsd
http://standards.iso.org/iso/19115/-3/mrs/1.0/mrs.xsd
http://standards.iso.org/iso/19115/-3/msr/1.0/msr.xsd
http://standards.iso.org/iso/19157/-2/mdq/1.0/mdq.xsd
http://standards.iso.org/iso/19115/-3/mac/1.0/mac.xsd
http://standards.iso.org/iso/19115/-3/gco/1.0/gco.xsd
http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd
http://www.w3.org/1999/xlink.xsd">
<mdb:metadataIdentifier>
<mcc:MD_Identifier>
<mcc:code>
<gco:CharacterString></gco:CharacterString>
</mcc:code>
</mcc:MD_Identifier>
</mdb:metadataIdentifier>
<mdb:metadataScope>
<mdb:MD_MetadataScope>
<mdb:resourceScope>
<mcc:MD_ScopeCode codeList="codeListLocation#MD_ScopeCode"
codeListValue="service">service</mcc:MD_ScopeCode>
</mdb:resourceScope>
<mdb:name>
<gco:CharacterString>service</gco:CharacterString>
</mdb:name>
</mdb:MD_MetadataScope>
</mdb:metadataScope>
<mdb:contact
xlink:href="local://subtemplate?uuid=urn:ga-contacts:11&process=cit:role/cit:CI_RoleCode/@codeListValue~author"/>
<mdb:metadataStandard>
<cit:CI_Citation>
<cit:title>
<gco:CharacterString>AU/NZS ISO 19115-1:2014</gco:CharacterString>
</cit:title>
</cit:CI_Citation>
</mdb:metadataStandard>
<cit:CI_Citation>
<cit:title>
<gco:CharacterString>ISO 19115-1:2014</gco:CharacterString>
</cit:title>
</cit:CI_Citation>
<cit:CI_Citation>
<cit:title>
<gco:CharacterString>ISO 19115-3 (Draft Schemas
2015)</gco:CharacterString>
</cit:title>
<cit:editionDate>
<gco:DateTime>2015-07-01T00:00:00</gco:DateTime>
</cit:editionDate>
</cit:CI_Citation>
<mdb:identificationInfo>
<srv:SV_ServiceIdentification>
<mri:citation>
<cit:CI_Citation>
<cit:title>
<gco:CharacterString>ABARES Draft Template for services in
19115-1:2014 and 19115-3</gco:CharacterString>
</cit:title>
<cit:date>
<cit:CI_Date>
<cit:date>
<gco:DateTime></gco:DateTime>
</cit:date>
<cit:dateType>
<cit:CI_DateTypeCode
codeList="codeListLocation#CI_DateTypeCode"
codeListValue="creation">creation</cit:CI_DateTypeCode>
</cit:dateType>
</cit:CI_Date>
</cit:date>
</cit:CI_Citation>
</mri:citation>
<mri:abstract>
</mri:abstract>
<mri:pointOfContact
xlink:href="local://subtemplate?uuid=urn:ga-contacts:11&process=cit:role/cit:CI_RoleCode/@codeListValue~pointOfContact"/>
<mri:topicCategory>
<mri:MD_TopicCategoryCode>geoscientificInformation</mri:MD_TopicCategoryCode>
</mri:topicCategory>
<mri:extent>
<gex:EX_Extent>
<gex:geographicElement>
<gex:EX_GeographicBoundingBox>
<gex:westBoundLongitude>
<gco:Decimal>-180</gco:Decimal>
</gex:westBoundLongitude>
<gex:eastBoundLongitude>
<gco:Decimal>180</gco:Decimal>
</gex:eastBoundLongitude>
<gex:southBoundLatitude>
<gco:Decimal>-90</gco:Decimal>
</gex:southBoundLatitude>
<gex:northBoundLatitude>
<gco:Decimal>90</gco:Decimal>
</gex:northBoundLatitude>
</gex:EX_GeographicBoundingBox>
</gex:geographicElement>
</gex:EX_Extent>
</mri:extent>
<mri:resourceMaintenance>
<mmi:MD_MaintenanceInformation>
<mmi:maintenanceAndUpdateFrequency>
<mmi:MD_MaintenanceFrequencyCode
codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_MaintenanceFrequencyCode"
codeListValue="unknown"
codeSpace="ISOTC211/19115">unknown</mmi:MD_MaintenanceFrequencyCode>
</mmi:maintenanceAndUpdateFrequency>
</mmi:MD_MaintenanceInformation>
</mri:resourceMaintenance>
<mri:resourceConstraints>
<mco:MD_LegalConstraints uuid="urn:ga-licences:232">
<mco:reference>
<cit:CI_Citation>
<cit:title>
<gco:CharacterString>Creative Commons Attribution
4.0 International Licence</gco:CharacterString>
</cit:title>
<cit:alternateTitle>
<gco:CharacterString>CC-BY</gco:CharacterString>
</cit:alternateTitle>
<cit:edition>
<gco:CharacterString>4.0</gco:CharacterString>
</cit:edition>
<cit:onlineResource>
<cit:CI_OnlineResource>
<cit:linkage>
<gco:CharacterString>http://creativecommons.org/licenses/</gco:CharacterString>
</cit:linkage>
</cit:CI_OnlineResource>
</cit:onlineResource>
</cit:CI_Citation>
</mco:reference>
<mco:accessConstraints>
<mco:MD_RestrictionCode
codeList="codeListLocation#MD_RestrictionCode" codeListValue="license"/>
</mco:accessConstraints>
<mco:useConstraints>
</mco:useConstraints>
</mco:MD_LegalConstraints>
</mri:resourceConstraints>
<mco:MD_SecurityConstraints>
<mco:classification>
<mco:MD_ClassificationCode
codeList="codeListLocation#MD_ClassificationCode"
codeListValue="unclassified"/>
</mco:classification>
</mco:MD_SecurityConstraints>
<srv:serviceType>
<gco:ScopedName></gco:ScopedName>
</srv:serviceType>
<srv:serviceTypeVersion>
</srv:serviceTypeVersion>
<srv:couplingType>
<srv:SV_CouplingType codeList="codeListLocation#SV_CouplingType"
codeListValue="tight">tight</srv:SV_CouplingType>
</srv:couplingType>
<srv:containsOperations>
<srv:SV_OperationMetadata>
<srv:operationName>
</srv:operationName>
<srv:distributedComputingPlatform>
<srv:DCPList codeList="codeListLocation#DCPList"
codeListValue="WebServices">WebServices</srv:DCPList>
</srv:distributedComputingPlatform>
<srv:operationDescription>
</srv:operationDescription>
<srv:connectPoint>
<cit:linkage>
</cit:linkage>
<cit:protocol>
</cit:protocol>
</srv:connectPoint>
<srv:parameter>
<srv:SV_Parameter>
<srv:name>
<gco:MemberName>
<gco:aName>
</gco:aName>
<gco:attributeType>
<gco:TypeName>
<gco:aName>
<gco:CharacterString>TEXT</gco:CharacterString>
</gco:aName>
</gco:TypeName>
</gco:attributeType>
</gco:MemberName>
</srv:name>
<srv:direction>
<srv:SV_ParameterDirection></srv:SV_ParameterDirection>
</srv:direction>
<srv:description>
</srv:description>
<srv:optionality>
<gco:Boolean>false</gco:Boolean>
</srv:optionality>
<srv:repeatability>
</srv:repeatability>
</srv:SV_Parameter>
</srv:parameter>
</srv:SV_OperationMetadata>
</srv:containsOperations>
</srv:SV_ServiceIdentification>
</mdb:identificationInfo>
<mdb:resourceLineage>
<mrl:LI_Lineage>
<mrl:statement>
<gco:CharacterString/>
</mrl:statement>
<mrl:scope>
<mcc:MD_Scope>
<mcc:level>
codeListValue="service"/>
</mcc:level>
</mcc:MD_Scope>
</mrl:scope>
</mrl:LI_Lineage>
</mdb:resourceLineage>
<mdb:metadataConstraints>
</mdb:metadataConstraints>
</mdb:MD_Metadata>
With the above service.xml I can now add a new record from the template
whereas previously I could not. I have not investigated more dependencies
around this yet....
With the transformation from 19139 to 19115-3, I implemented the
transformation and am getting a IllegalArgumentException XML fragment is
invalid. Error is Error on line 4: The prefix "gmd" for element
"gmd:MD_Metadata" is not bound. Error....... I will have to dig through this
now....Will save me a lot of time if anyone has come across this message and
knows the fix straight away....
Suresh
View this message in context: http://osgeo-org.1560.x6.nabble.com/iso19115-2003-to-iso19115-3-transformation-tp5302244p5302556.html
