[GeoNetwork-users] [ISO19115-3] simple view doesn't show lineage
Hi list,
I'm using GeoNetwork 4.0.3. On my ISO 19115-3 metadata, in the simple view, I would have expected to see the lineage appear, as in ISO 19139, but apparently not.
From what I've read on GN doc, to be bale to add it in the AngularJS view <https://github.com/geonetwork/core-geonetwork/blob/main/schemas/&gt;, it need to be indexed.
If I look in index-fields/index.xsl <https://github.com/geonetwork/core-geonetwork/blob/main/schemas/iso19115-3.2018/src/main/plugin/iso19115-3.2018/index-fields/index.xsl#L1047&gt;, it seems to me that the lineage field should be indexed, right ?
But when I look in the ElasticSearch records, I can see that, while there is a lineageObject for ISO19139 metadata, there is nothing similar for ISO19115-3 metadata.
Any hint on how to add the lineage in the simple view, for ISO19115-3 metadata ?
Thanks !
Best,
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Indeed Jean, there is an error in the XPath.
If you have the chance to test
https://github.com/geonetwork/core-geonetwork/pull/5637 It should fix the
problem.
Thanks for reporting.
Francois
Le mar. 27 avr. 2021 à 18:51, Jean Pommier <jean.pommier@anonymised.com>
a écrit :
Hi list,
but apparently not.
metadata ?
Thanks !
Best,
Jean
GeoNetwork-users mailing list
Thanks François, it indeed fixes the issue
If you have the chance to test https://github.com/geonetwork/core-geonetwork/pull/5637 It should fix the problem.
Francois
Le mar. 27 avr. 2021 à 18:51, Jean Pommier <jean.pommier@anonymised.com <mailto:jean.pommier@anonymised.com>> a écrit :
    Hi list,
    19139,
    but apparently not.
    view
    <https://github.com/geonetwork/core-geonetwork/blob/main/schemas/&gt;&gt;,
    <https://github.com/geonetwork/core-geonetwork/blob/main/schemas/iso19115-3.2018/src/main/plugin/iso19115-3.2018/index-fields/index.xsl#L1047&gt;&gt;,
    similar
    metadata ?
    Thanks !
    Best,
    Jean
    E-mail : jp@anonymised.com <mailto:jp@anonymised.com>
    Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
    <mailto:GeoNetwork-users@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geonetwork-users&gt;
    <http://sourceforge.net/projects/geonetwork&gt;
