[GeoNetwork-users] Issue setting Connection timeout - WAF Harvesting failing on GN 3.10.6
I have GN 3.10.6 running behind Nginx and I am getting issues harvesting from a WAF - I consistently get a "Read Time out" error on the harvester ("java.net.SocketTimeoutException: Read timed out") - I have tried increasing the connectorTimeout values in the Tomcat server.xml as well as adding the line "server.connection-timeout=20s" in the file geonetwork/WEB-INF/config.properties - but none of this makes a difference. When I manually run a harvest, after 2-3s I get the fail.
I know the source WAF is fine, and I can wget/directly load into oXygen from it - so can any anybody tell me if there is another setting I need to adjust in Tomcat or the GN configuration? The harvest does occasionally work at times of low load on the source WAF, but it seems to be something at the GN end being too impatient?
Steve
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
