Hi everybody,
I have discovered the cause of the problems related to the installation of
geonetwork. This comes out when a dbms other than McKoi is selected
during install. The installation phase goes well but geonetwork doesn't start.
Why?
Simple. The config.xml is correctly configured but the installer doesn't remove
the McKoi activator. When geonetwork starts, it tries to start the activator
(even if you choose a dbms different than mcKoi) but it fails because McKoi
doesn't find any data file (you created the db schema into another dbms, do
you remember?). So, the solution is to install geonetwork and remove the
activator from the config.xml file. Basically, you have to remove these lines:
<activator class="org.fao.geonet.activators.McKoiActivator">
<configFile>WEB-INF/db/db.conf</configFile>
</activator>
I just tried a clean reinstall of 2.0.1 on my Mac.
The fix below did not help. My installation was configured to use McKoi so I'm not sure that the rationale for the fix makes sense for my installation. I'll try Archie's suggestion of first installing 2.0.0 and then 2.0.1 as soon as I can.
Allan
On Jan 19, 2006, at 19:42, Andrea Carboni wrote:
Hi everybody,
Why?
</activator>
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&dat=121642
GeoNetwork-users mailing list
Allan Doyle
+1.781.433.2695
adoyle@anonymised.com
Allan
from an email to [geonetwork-devel]
I have been able to get a 2.0.1 install running with jetty and McKoi by
install 2.0.0 with jetty and McKoi.
install 2.0.1 with jetty and McKoi onto the same directory (overwriting files).
2.0.0 gets McKoi setup properly, 2.0.1 will leave McKoi alone if it exists but installs the other things.
This method works on FC4 and on FC3
from another email to [geonetwork-devel]
I was able to get geonetwork-2.0.1 working against Postgresql 8.0.
the only real issue seems to be, don't use the longvarchar type and use the text type instead.
and add an type alias into Data Druid for the postgresql driver.
As a manual process
Let a standard geonetwork install against McKoi run.
As a Postgresql DB Admin
create user geonetwork (create user geonetwork password 'mypass'
create schema geonetwork (create schema geonetwork authorization geonetwork;)
Create objects using the MySQL script in setup/sql/create-db-mysql.sql
(the create-db-postgresql.sql script is broken. Druid needs to have a type alias for longvarchar to text added for postgresql)
Download Database-Druid version 3.7 (http://druid.sf.net) version 3.2 does not work
add the postgresql driver to Druid
connect to the postgresql database
navigate to the tables in the geonet schema
select a table and use the "data" tab
import from the setup/db/<tab>.ddf file in the geonetwork installation
import tables in the order
Categories, Users, User Groups, Groups, Metadata, Metadataategories, Operations, OperationsAllowed
(foreign keys will fail otherwise. Commit after each import)
copy a postgresql JDBC jar into web/WEB-INF/lib (http://jdbc.postgresql.org)
edit web/WEB-INF/config.xml
add
<resource enabled="true">
<name>main-db</name>
<provider>jeeves.resources.dbms.DbmsPool</provider>
<config>
<user>geonetwork</user>
<password>[PASS]</password>
<driver>org.postgresql.Driver</driver>
<url>jdbc:postgresql://[HOST]/[DB]</url>
<poolSize>4</poolSize>
</config>
</resource>
change [HOST] to be your postgresql host name
change [DB] to be your postgresql database name
change [PASS] to be your geonet login password
set all other main-db resources to be enabled="false"
start geonetwork
C.
OK, a clean install of 2.0.0 followed by an install of 2.0.1 worked.
By the way, the installer welcome screen says "Welcome to the installation of geonetwork 2.0.0" and the "about" page also talks about 2.0.0
Allan
Allan
Hi everybody,
Why?
</activator>
Allan Doyle
+1.781.433.2695
Allan Doyle
+1.781.433.2695
Thanks Carl. I just sent mail, the 2.0.0 followed by 2.0.1 trick worked. And one of my next questions was going to be about PostgreSQL since I want to also put PostGIS on the machine. So your additional info about that is going to be helpful.
Allan
Allan
As a manual process
add
<config>
</config>
</resource>
start geonetwork
C.
Allan Doyle
+1.781.433.2695
