[GeoNetwork-users] java.lang.NullPointerException at org.fao.geonet.monitor.health.HarvestersHealthCheck
Dear GN User community,
in one of our GN instances (v4.0.2) we are having this error in Non-critical System checks (the full error message can be found in the attached fail.log) :
Harvesting, however, seems to work ok in both directions, as long as we use only other GN instances to check (using generic OGC CSW 2.0.2). That is why we haven't been concerned about it too much so far.
But now we are having troubles to harvest our GN node from an ESRI geoportal instance. While this might be caused by a myriad of other issues, we would like to rule out that this error above is somehow related.
Does anyone of you have an idea what might be causing this error message, and or even a pointer were to dig deeper into the potential roots of the problem? None of the log files in $CATALINA_HOME/logs seem to indicate that there is something wrong or malfunctioning concerning csw - well at least if you ignore multiple instances of this message:
2021-02-08 09:45:47,669 ERROR [geonetwork.csw] - Error getting domain value for specified PropertyName : org.apache.commons.lang.NotImplementedException: CSW not implemented in ES
But this doesn't seem to be related.
Thank you for thinking about it!
Best regards and stay safe,
Lars Möller
Dr. Lars Möller
Helmholtz-Zentrum Geesthacht
Zentrum für Material und Küstenforschung
-Modellierung zur Bewertung von Küstensystemen (KBS)
Max-Planck-Straße 1
21502 Geesthacht
Germany
Fon +49 (0) 4152- 87 - 1849
Fax +49 (0) 4152- 87 - 41849
E-mail: lars.moeller@anonymised.com
www.hzg.de
Helmholtz-Zentrum Geesthacht Zentrum für Material- und Küstenforschung GmbH Max-Planck-Straße 1 I 21502 Geesthacht I Deutschland/Germany
Geschäftsführung/Board of Management: Prof. Dr. Matthias Rehahn, Silke Simon Vorsitzender des Aufsichtsrates/Chairman of the Supervisory Board: Ministerialdirigent Engelbert Beyer Amtsgericht Lübeck HRB 285 GE (Register Court) Internet: http://www.hzg.de
(attachments)
gn_harvhc_fail.log (8.95 KB)
Hi Lars
The GetDomain error is related to a GetCapabilities request which was
collecting keywords to be added to the capabilities document.
This will be disabled in 4.0.3 and it is recommended to use a service
metadata for the GetCapabilities configuration
https://geonetwork-opensource.org/manuals/4.0.x/en/administrator-guide/configuring-the-catalog/csw-configuration.html#service-metadata-record
https://github.com/geonetwork/core-geonetwork/commit/762d8ad46babc368dd2f02eaa802ddd3f2c41de2
So I don't think it relates to your harvesting issue.
Francois
Le lun. 8 févr. 2021 à 12:11, Lars Möller <lars.moeller@anonymised.com876...> a écrit :
Lars Möller
Dr. Lars Möller
Max-Planck-Straße 1
21502 Geesthacht
Germany
www.hzg.de
Simon
GeoNetwork-users mailing list
