Hello,
In GAST / Database /Setup I get this error when clicking on Setup:
Java Runtime Environment (JRE) version 1.6 is not supported by this driver.
Use the sqljdbc4.jar class library which provides support for JDBC 4.0
I have both sqljdbc4.jar and sqljdbc.jar in the WEBINF/lib directory. JAva
version: 6 update 17. In DBMS configuration I have the following:
JDBC driver: com.microsoft.sqlserver.jdbc.SQLServerDriver
URL: jdbc:sqlserver://server;databaseName=db
Any ideas?
Manolo
View this message in context: http://n2.nabble.com/JRE-error-setting-up-GN-tp3986194p3986194.html
I have the same Java version as you, but not this problem.
What version of GeoNetwork are you using ?
Kind regards
Heikki Doeleman
On Wed, Nov 11, 2009 at 1:45 PM, Manolo Frias <manuel.frias@anonymised.com>wrote:
Hello,
Any ideas?
Manolo
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
Hi Heikki,
I am using the latest I found in the GN webpage: 2.4.2
Manolo
Kind regards
Heikki Doeleman
Hello,
driver.
JAva
Any ideas?
Manolo
30-Day
focus
on
30-Day
on
View this message in context: http://n2.nabble.com/JRE-error-setting-up-GN-tp3986194p3986383.html
