Hi Jean Pommier,
and many thanks for your quick reply!
Sure, I can share my config files with you.
I modified them following the guide for LDAP on version 3.110.x (https://geonetwork-opensource.org/manuals/3.10.x/en/administrator-guide/managing-users-and-groups/authentication-mode.html#authentication-ldap-hierarchy).
The first one is config-security.xml, in wich, as per the guide, I just enabled the ldap-recursive module:
~ Copyright (C) 2001-2016 Food and Agriculture Organization of the
~ United Nations (FAO-UN), United Nations World Food Programme (WFP)
~ and United Nations Environment Programme (UNEP)
~ This program is free software; you can redistribute it and/or modify
~ it under the terms of the GNU General Public License as published by
~ the Free Software Foundation; either version 2 of the License, or (at
~ your option) any later version.
~ This program is distributed in the hope that it will be useful, but
~ WITHOUT ANY WARRANTY; without even the implied warranty of
~ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
~ General Public License for more details.
~ You should have received a copy of the GNU General Public License
~ along with this program; if not, write to the Free Software
~ Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301, USA
~ Contact: Jeroen Ticheler - FAO - Viale delle Terme di Caracalla 2,
~ Rome - Italy. email: geonetwork@anonymised.com
<beans
xmlns:ctx="http://www.springframework.org/schema/context"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.springframework.org/schema/beans
http://www.springframework.org/schema/beans/spring-beans-3.0.xsd
http://www.springframework.org/schema/context/spring-context-3.0.xsd"
xmlns="http://www.springframework.org/schema/beans">
<!-- <sec:debug/> -->
<import resource="config-security-core.xml"/>
<import resource="config-security-mapping.xml"/>
<!--<import resource="config-security-ldap.xml"/>-->
<import resource="config-security-ldap-recursive.xml"/>
<!-- <import resource="config-security-ecas.xml"/> -->
<!--<import resource="config-security-cas.xml"/>-->
<!--<import resource="config-security-cas-ldap.xml"/>-->
<!-- <import resource="config-security-cas-database.xml"/> -->
<!-- <import resource="config-security-shibboleth.xml"/> -->
<ctx:property-placeholder location="WEB-INF/config-security/config-security.properties"
file-encoding="UTF-8" ignore-unresolvable="true" order="100"/>
</beans>
And here you are the config-security-ldap-recursive.xml file:
<beans
</beans>
pierpaolo@anonymised.com:~/work/k8s/geonetwork/production$ cat config-security/config-security-ldap-recursive.xml
<beans xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:util="http://www.springframework.org/schema/util"
http://www.springframework.org/schema/beans/spring-beans.xsd
http://www.springframework.org/schema/util/spring-util.xsd
http://www.springframework.org/schema/data/jpa/spring-jpa-1.3.xsd
<!-- <ctx:property-placeholder location="classpath:org/fao/geonet/kernel/security/ldap/LDAP-test-properties.properties"/>-->
<bean id="ldapRoleConverterGroupNameParser"
class="org.fao.geonet.kernel.security.ldap.LDAPRoleConverterGroupNameParser">
<property name="ldapMembershipQueryParser" value="GCAT_(.*)_(.*)"/>
<property name="groupIndexInPattern" value="1"/>
<property name="profileIndexInPattern" value="2"/>
<property name="profileMapping">
<map>
<entry key="ADMIN" value="Administrator"/>
<entry key="EDITOR" value="Editor"/>
</map>
</property>
</bean>
<!-- Add ldap authentication to authentication manager -->
<bean id="ldapAuthenticationProviderPostProcessor"
class="jeeves.config.springutil.AddAuthenticationProviderPostProcessor">
<constructor-arg ref="ldapAuthProvider"/>
</bean>
<!-- LDAP configuration-->
<bean id="contextSource"
class="org.springframework.security.ldap.DefaultSpringSecurityContextSource">
<constructor-arg value="ldap://ldap.ve.ismar.cnr.it:389/dc=ismar,dc=cnr,dc=it"/>
<!-- For non anonymous binding -->
<property name="userDn" value="cn=XXXXXXX,cn=XXXXXXX,dc=ismar,dc=cnr,dc=it"/>
<property name="password" value="XXXXXXXXXXXX"/>
</bean>
<bean id="ldapUserSearch" class="org.springframework.security.ldap.search.FilterBasedLdapUserSearch">
<constructor-arg name="searchBase" value="ou=people"/>
<constructor-arg name="searchFilter" value="(uid={0})"/>
<constructor-arg name="contextSource" ref="contextSource"/>
<property name="searchSubtree" value="true"/>
</bean>
<bean id="usernameMapper"
class="org.fao.geonet.kernel.security.ldap.SearchingLdapUsernameToDnMapper">
<property name="ldapContextSource" ref="contextSource"/>
<property name="ldapUserSearch" ref="ldapUserSearch"/>
</bean>
<bean id="ldapAuthProvider"
class="org.springframework.security.ldap.authentication.LdapAuthenticationProvider">
<constructor-arg>
<bean class="org.springframework.security.ldap.authentication.BindAuthenticator">
<constructor-arg ref="contextSource"/>
<property name="userSearch" ref="ldapUserSearch"/>
</bean>
</constructor-arg>
<property name="userDetailsContextMapper" ref="ldapUserContextMapper"/>
</bean>
<bean id="ldapUserDetailsService"
class="org.fao.geonet.kernel.security.ldap.LdapUserDetailsManager">
<constructor-arg name="groupMemberAttributeName"
value="cn"/>
<constructor-arg name="query"
value="mail={1}"/>
<property name="groupSearchBase"
value="ou=groups,ou=ve,dc=ismar,dc=cnr,dc=it"/>
<property name="usernameMapper" ref="usernameMapper"/>
<property name="userDetailsMapper" ref="ldapUserContextMapper"/>
</bean>
<bean id="ldapUtils" class="org.fao.geonet.kernel.security.ldap.LDAPUtils"/>
<bean id="ldapUserContextMapper" class="org.fao.geonet.kernel.security.ldap.LDAPUserDetailsContextMapperWithProfileSearchEnhanced">
<property name="mapping">
<map>
<entry key="name" value="givenName,"/>
<entry key="surname" value="sn,"/>
<entry key="mail" value="mail,"/>
<entry key="organisation" value="o,"/>
<entry key="address" value=","/>
<entry key="zip" value=","/>
<entry key="state" value=","/>
<entry key="city" value=","/>
<entry key="country" value=","/>
<entry key="profile" value=",RegisteredUser"/>
<entry key="privilege" value=",none"/>
</map>
</property>
<map/>
</property>
<property name="ldapUtils" ref="ldapUtils"/>
<property name="importPrivilegesFromLdap" value="true"/>
<!-- typically, don't want GN to modify the LDAP server! -->
<property name="createNonExistingLdapGroup" value="false" />
<property name="createNonExistingLdapUser" value="false" />
<property name="ldapManager" ref="ldapUserDetailsService" />
<property name="membershipSearchStartObject" value=""/>
<property name="ldapMembershipQuery" value="(&(objectClass=groupOfUniqueNames)(uniquemember={2})(cn=GCAT_*))"/>
<property name="ldapRoleConverters">
<util:list>
<ref bean="ldapRoleConverterGroupNameParser"/>
</util:list>
</property>
<property name="contextSource" ref="contextSource" />
</bean>
</beans>
Hope it will help to resolve my issue.
Pierpaolo
Quoting Jean Pommier via GeoNetwork-users <geonetwork-users@lists.sourceforge.net>:
Hi Pierpaolo,
From the logs, it looks like the issue is not with k8s but with your xml configuration. Can you share your custom config files ?
Best,
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Le 22/03/2022 à 12:28, Pierpaolo Culurciello via GeoNetwork-users a écrit :
Dear all,
I am trying to migrate a Kubernetes GeoNetwork deployment from 3.10.6 to 4.0.6.
When using 3.106 version I just configured a couple of configmaps for all the modified config files (config-security.xml, config-security-ldap-recursive.xml, web.xml) and mount them at the proper path, here's the kubernetes manifest part used for this:
volumeMounts:
- mountPath: /var/lib/geonetwork_data
- mountPath: /usr/local/tomcat/webapps/geonetwork/WEB-INF/config-security/config-security.xml
subPath: config-security.xml
- mountPath: /usr/local/tomcat/webapps/geonetwork/WEB-INF/config-security/config-security-ldap-recursive.xml
subPath: config-security-ldap-recursive.xml
- mountPath: /usr/local/tomcat/webapps/geonetwork/WEB-INF/web.xml
volumes:
- name: geonetwork-sec-conf
configMap:
- name: geonetwork-ldap-conf
configMap:
- name: geonetwork-webxml
configMap:
when I tried to use the same configuration fro Geonetwork-4.0.6 I saw the folowing errors in container logs:
2022-03-22 10:46:18,659 ERROR [jeeves] - JeevesContextLoaderListener: Error creating bean with name 'ldapAuthenticationProviderPostProcessor' defined in ServletContext resource [/WEB-INF/config-security/config-security-ldap-recursive.xml]: Cannot resolve reference to bean 'ldapAuthProvider' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapAuthProvider' defined in ServletContext resource [/WEB-INF/config-security/config-security-ldap-recursive.xml]: Cannot resolve reference to bean 'ldapUserContextMapper' while setting bean property 'userDetailsContextMapper'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapUserContextMapper' defined in ServletContext resource [/WEB-INF/config-security/config-security-ldap-recursive.xml]: Cannot resolve reference to bean 'ldapUtils' while setting bean property 'ldapUtils'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapUtils': Injection of persistence dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/var/lib/jetty/webapps/geonetwork/WEB-INF/lib/gn-domain-4.0.6-0.jar!/config-spring-geonetwork.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: [PersistenceUnit: default] Unable to build Hibernate SessionFactory; nested exception is org.hibernate.exception.GenericJDBCException: Unable to open JDBC Connection for DDL execution
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapAuthenticationProviderPostProcessor' defined in ServletContext resource [/WEB-INF/config-security/config-security-ldap-recursive.xml]: Cannot resolve reference to bean 'ldapAuthProvider' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapAuthProvider' defined in ServletContext resource [/WEB-INF/config-security/config-security-ldap-recursive.xml]: Cannot resolve reference to bean 'ldapUserContextMapper' while setting bean property 'userDetailsContextMapper'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapUserContextMapper' defined in ServletContext resource [/WEB-INF/config-security/config-security-ldap-recursive.xml]: Cannot resolve reference to bean 'ldapUtils' while setting bean property 'ldapUtils'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'ldapUtils': Injection of persistence dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in URL [jar:file:/var/lib/jetty/webapps/geonetwork/WEB-INF/lib/gn-domain-4.0.6-0.jar!/config-spring-geonetwork.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: [PersistenceUnit: default] Unable to build Hibernate SessionFactory; nested exception is org.hibernate.exception.GenericJDBCException: Unable to open JDBC Connection for DDL execution
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:342)
So I decided to build a custom image slightly modifying GeoNetwork 4.0.6 Dockerfile and copying the modified configuration files just before runnign the command "java -jar /usr/local/jetty/start.jar".
Here's my modification to the Dockerfile:
USER jetty
ENV GN_FILE geonetwork.war
ENV GN_VERSION 4.0.6
ENV GN_DOWNLOAD_MD5 793732cb9c723e73857a4da73b78451b
RUN cd /var/lib/jetty/webapps/geonetwork/ && \
curl -fSL -o geonetwork.war \
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v$\{GN\_VERSION\}/$\{GN\_FILE\}/download && \
echo "${GN_DOWNLOAD_MD5} *geonetwork.war" | md5sum -c && \
unzip -q geonetwork.war && \
rm geonetwork.war
COPY ./docker-entrypoint.sh /geonetwork-entrypoint.sh
COPY ./configs/config-security/* /var/lib/jetty/webapps/geonetwork/WEB-INF/config-security/
COPY ./configs/web.xml /var/lib/jetty/webapps/geonetwork/WEB-INF/web.xml
ENTRYPOINT ["/geonetwork-entrypoint.sh"]
CMD ["java","-jar","/usr/local/jetty/start.jar"]
VOLUME [ "${DATA_DIR}" ]
I then removed from the Kubernetes GeoNetwork deployment manifest file the lines above that mount the configmaps for LDAP and web.xml, since they are now replaced by the COPY commands in Dockerfile.
Anyway when I start the container I still see the same ERRORS as above.
Does anybody of you know how to run GeoNetwork 4.0.6 in Kubernetes with modified config files?
Best regards,
Pierpaolo
GeoNetwork-users mailing list
