Thanks Francois,
I was looking at the GCMD spec here:
http://gcmd.gsfc.nasa.gov/User/difguide/spatial_coverage.html
I'm not sure if the ISO 19115 or CSW spec has similar guidelines or not, but this suggests the use of 0-360 is not allowed, but supports tests where the E limit is less than the W limit & E limit is negative to imply a 180 cross.
In which case, the issue is not one of accepting 180-360 coordinates, but instead is one of supporting proper searches by creating either a 0-360 bounding box, or 2 boxes, one at +180 and one at -180 for such cases.
This may be a more elegant solution, as data is always stored consistently, and the issue is then recognised and dealt with correctly in the code.
Ideally the search map can then be implemented in +-180 or 0-360 (chosen at install time), allowing cross 180 searches, and again, the search code can build appropriate +-180 bounding boxes from the users' selection to suit the underlying values in the metadata records.
Brent Wood
--- On Wed, 9/23/09, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
From: Francois Prunayre <fx.prunayre@anonymised.com>
Subject: Re: [GeoNetwork-users] 180 degree issue
To: pcreso@anonymised.com
Cc: geonetwork-users@lists.sourceforge.net
Date: Wednesday, September 23, 2009, 3:21 AM
Hello Brent,
2009/9/14 <pcreso@anonymised.com>:
> I'm trying to use GN for metadata from surveys in the
Ross Sea (Antarctica) and of the Chatham Rise (E of New
Zealand).
> Both surveys, & the datasets I need to describe,
cross 180 degrees.
> With most FOSS tools (PostGIS, mapserver, OpenLayers,
GMT, etc) I can use longitudes in a 0-360 degree space, so
my extent becomes (for example)
> -35
> 160 195
> -55
> GN accepts these values, but a map search fails to
locate them.
> How can I properly represent & map search datasets
crossing 180 in GN?
As suggested in previous post, some workaround could help.
Anyway, I've been testing this use case on the extent
editor committed
last week which will allow to set such a bounding box.
The bounding box is indexed and CSW search is also working
[1].
The issue remains on the search form based on Intermap.
We have to address that issue in current discussion in the
replacing
intermap proposal.
Ciao.
Francois
[1] http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk/web/geonetwork/xml/csw/test/csw-GetRecordsFilterGeoBboxForMoreThan180degrees.xml?revision=5194&view=markup
> Thanks,
> Brent Wood
> Let Crystal Reports handle the reporting - Free
Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and
deployment - and focus on
> what you do best, core application coding. Discover
what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
