I have seen that Geonetwork also uses the log4 lib.
https://geonetwork-opensource.org/manuals/3.10.x/en/install-guide/logging.html
What do I have to do to avoid attacks and fix the current security warnings regarding log4?
https://www.govcert.ch/blog/zero-day-exploit-targeting-popular-java-library-log4j/
Thanks + Greetings
Sven
Hi and thanks for raising the topic. There is a GitHub issue on that
matter, I suggest that we use it to centralize communication and exchanges:
https://github.com/geonetwork/core-geonetwork/issues/6076
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Olivier Guyot*
Geospatial Developer
+49 89 2620 89 924
On Mon, Dec 13, 2021 at 9:34 AM Sven Schroeter via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
Thanks + Greetings
Sven
GeoNetwork-users mailing list
Hi Sven
For the
issue, today has been released the version 3.10.10 with the library
upgraded (
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v3.10.10/)
and tomorrow we plan to release 3.12.2 with the same upgrade.
Jose Garc'ia
Thanks + Greetings
Sven
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi Olivier,
thanks for the tip!
we are currently using geonetwork 3.10.8.
I am not a Java expert and have looked what libs are used here. In the directory WEB-INF/lib are the following .jar files:
log4j-api-2.7.jar
log4j-core-2.7.jar
log4j-1.2.17.jar
What do I need to do to get the service back up and running safely?
Thanks Sven
Am 13.12.2021 um 12:37 schrieb Olivier Guyot:
Hi and thanks for raising the topic. There is a GitHub issue on that matter, I suggest that we use it to centralize communication and exchanges: https://github.com/geonetwork/core-geonetwork/issues/6076
*camptocamp*
*Olivier Guyot
Geospatial Developer*
+49 89 2620 89 924
On Mon, Dec 13, 2021 at 9:34 AM Sven Schroeter via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote:
Thanks + Greetings
Sven
Hi Sven,
The safest is probably to migrate to the 3.10.10 version published by Jose,
see:
This contains the 2.15 version of log4j instead of 2.7.
*camptocamp*
*Olivier Guyot*
+49 89 2620 89 924
On Mon, Dec 13, 2021 at 1:42 PM Sven Schroeter <schroeter@anonymised.com> wrote:
Hi Olivier,
thanks for the tip!
log4j-api-2.7.jar
log4j-core-2.7.jar
log4j-1.2.17.jar
Thanks Sven
*camptocamp*
*Olivier Guyot *
+49 89 2620 89 924
Thanks + Greetings
Sven
Hi Sven
I you can not upgrade to version 3.10.10, a quick fix is to remove these 2
files from WEB-INF/lib:
log4j-api-2.7.jar
log4j-core-2.7.jar
Download log4j2 version 2.15.0 and and replace them by the ones in the
version 2.15.0
Jose García
On Mon, Dec 13, 2021 at 1:43 PM Sven Schroeter via GeoNetwork-users <
Hi Olivier,
thanks for the tip!
log4j-api-2.7.jar
log4j-core-2.7.jar
log4j-1.2.17.jar
Thanks Sven
> *camptocamp*
> *Olivier Guyot
> +49 89 2620 89 924
> Hi,
> Thanks + Greetings
> Sven
this email.*
