[GeoNetwork-users] managing contacts
I am new to Geonetwork, and trying to evaluate it. I have 2.10.3 installed on a windows machine, as well as deployed on Ubuntu/Tomcat.
As I understand it there is no simple interface to managing contacts, right? One would have to enter them in metadata items, and then using "fragments" and XPath to extract it into the directories (which are accessible from the admin menu "manage directories")
Also - I am using the modern widget UI - the "Extract subtemplates" option is not present in any of the menus, but I can see it if I dip into the classic/old UI. Is this a bug?
Hugo
Hugo Ahlenius
Hugo Ahlenius E-Mail: hugo.ahlenius(at)nordpil.com
                         Phone: +46 75 7575284
Nordpil Mobile: +46 733 467111
http://nordpil.com Skype: callto:hugo.ahlenius
                         Twitter: https://twitter.com/nordpil
       vCard: http://nordpil.com/hugoahlenius.vcf
2014-06-12 12:32 GMT+02:00 Hugo Ahlenius <hugo.ahlenius@anonymised.com>:
Some users generate XML fragments from LDAP or CSV files containing contact
details and use batch import to load them in the catalog as subtemplate.
They can then use them in the metadata editor (and basically manage
contacts using other tools).
I created an issue for that:
https://github.com/geonetwork/core-geonetwork/issues/558
Cheers.
Francois
Hugo
Hugo Ahlenius
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
GeoNetwork-users mailing list
