[GeoNetwork-users] Map Server
Hi Francois!
2007/8/29, François-Xavier PRUNAYRE <fx.prunayre@anonymised.com>:
Which version of GeoNetwork are you using ? 2.0 or 2.1
Francois
*De :* Igor V. Burago [mailto:iburago@anonymised.com]
*Envoyé :* mercredi 29 août 2007 03:32
*À :* François-Xavier PRUNAYRE
*Objet :* Re: [GeoNetwork-users] Map Server
Hi Francois!
2007/8/28, François-Xavier PRUNAYRE < fx.prunayre@anonymised.com>:
I think you could not get intermap works with mapserver without using a
wms
service. So first set up a wms service for your mapfile :
http://mapserver.gis.umn.edu/docs/howto/wms_server
Name should be the name of the layer as defined in the getCapabilities
operation of the WMS services.
For example :
    <onLineSrc>
        <linkage> http://gesteau.eaufrance.fr/service?&lt;/linkage&gt;
        <protocol>OGC:WMS-1.1.1-http-get-map</protocol>
        <orName>CONTRATEX</orName>
        <orDesc>Carte des contrats de rivière en cours
d'exécution</orDesc>
    </onLineSrc>
Maybe you could also get more info on that thread :
http://www.nabble.com/Need-help-configuring-geonetwork-to-use-WMS-tf3230378s
18419.html#a8975280
HTH
Francois
-----Message d'origine-----
De: geonetwork-users-bounces@lists.sourceforge.net
[mailto: geonetwork-users-bounces@lists.sourceforge.net] De la part de
KiranShakya
Envoyé: mardi 28 août 2007 10:55
À: geonetwork-users@lists.sourceforge.net
Objet: Re: [GeoNetwork-users] Map Server
hi Igor
I am also facing the same problem. I have UMN Mapserver and
GeoNetwork. I
want to use InterMap as the client for MapServer but no idea where to
configure.
I did went to Distribution of geonetwork > Distribution info> online
resources.
On linkage :
http://myhost/cgi-bin/mapserv.exe?map=/ms4w/apps/kiranWMS/map/demo.map
on protocol: OpenGIS Map service (ver 1.1.1)
on Name:
on Description: My Site
by doing this, i get the link "Internet mapping" but it does not connect
to
my UMN MapServer. I could not see any maps.
If any of you have found the solution in this matter, I will be very
grateful, if you could share the information with me (or all of us).
Thank you in advance.
Kiran
View this message in context:
http://www.nabble.com/Map-Server-tf4320729s18419.html#a12364340
Sent from the geonetwork-users mailing list archive at Nabble.com.
GeoNetwork-users mailing list
I've tried your solution from http://www.nabble.com/Need-help-configuring-geonetwork-to-use-WMS-tf3230378s18419.html#a8975280
thread. But it does not work.
I entered these data:
Linkage = http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/workshop/itasca.map
Name = drgs;
Select protocol = OpenGIS Map service (ver. 1.1.1) ("<protocol>OGC:
WMS-1.1.1-http-get-map </protocol>" in XML).
When I'm trying http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/workshop/itasca.map&service=wms&version=1.1.1&layers=drgs&request=GetMap
URL in my browser everything works correctly (I can see map in browser).
But GeoNetwork makes another URL: http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/workshop/itasca.map&service=drgs&type=2
. It seems strange, I thought service should be "wms". And when I'm trying
this URL in browser, it does not work.
Thank You,
Igor V. Burago
Now I'm using GeoNetwork 2.0.3, but soon I'll have to switch over to new
GeoNetwork 2.1 release.
Is there valuable changes in linking maps between 2.0.3 and 2.1 versions of
GeoNetwork?
By the way, may be you have tiny working map with WMS at hand? I would like
to check is there problem in my maps. But still I can't, because I'm not
sure I have correct WMS map. Could you send me complete example (map file,
shape file, etc.) of map that really works and supports WMS? I'll really
appreciate it.
Thank You,
Igor V. Burago
Hi Francois!
2007/8/31, François-Xavier PRUNAYRE <fx.prunayre@anonymised.com>:
Hi Igor, could you try to make it work with these parameters :
<onLineSrc>
</onLineSrc>
And check that intermap is showing the map (zoom to France to check the
map).
I'm not an Intermap expert but I think it could be linked to the url of
intermap
If that works :
... you're WMS is up and running.
Maybe having a "?" or "&" in the linkage is the origin. I'll try to test
that ... but I'm quite busy today.
Cheers. Francois
[mailto:geonetwork-users-bounces@lists.sourceforge.net ] De la part de
Igor
V. Burago
Envoyé: jeudi 30 août 2007 02:00
Hi Francois!
> Francois
> Hi Francois!
> wms
> For example :
> <onLineSrc>
> </onLineSrc>
> 18419.html#a8975280
> HTH
> Francois
> KiranShakya
> hi Igor
> GeoNetwork. I
> configure.
> resources.
> On linkage :
> on Name:
> to
> Kiran
18419.html#a8975280
> Linkage =
> Name = drgs;
> When I'm trying
ice=drgs&type=2
trying
> Thank You,
> Igor V. Burago
of
GeoNetwork?
like
appreciate it.
Thank You,
Igor V. Burago
Unfortunately, I can't. There is no possible way to connect the Internet,
except proxy at my organization. But there is no way to specify login name
and password for proxy in GeoNetwork now. (This feature will be added in new
2.1 release, I think. That's why I'll have to switch over to new release
soon.) So I can't test InterMap using remote map services.
But I can't understand why InterMap fails viewing local maps. I've tried to
use alias (using RewriteEngine of Apache) instead of long URL with '?' and
'&'. But there is no positive result: "The requested operation could not be
performed." May be InterMap has detailed diagnostics, may be I can see it?
Thank You,
Igor V. Burago
