[GeoNetwork-users] maxClauseCount Problem
Kai
Joint Center for Intelligent Spatial Computing
703-395-2337
I have the same problem right now.
I harvested the FAO node and I encountered this error while performing some
spatial search (in some cases it works...).
The error message is TooManyClauses : maxClauseCount is set to 1024
The GN version is the same as Kai's: 2.4.3
Thanks for your help.
Bye
Paolo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fwd-maxClauseCount-Problem-tp5495565p5510498.html
Hi Paolo,
If the number of records is not big(less than 40K)in your GeoNetwork. A simple way to avoid this error is that You can increase the maxClauseCount to (16384)in /luceneQueryBuilder.java and /luceneSearcher.java .
Kai
Kai
703-395-2337
----- Original Message -----
From: Paolo Pasquali <paolo.pasquali@anonymised.com>
Date: Wednesday, September 8, 2010 8:48 am
Subject: Re: [GeoNetwork-users] Fwd: maxClauseCount Problem
performing some
Bye
Paolo
tp5495565p5510498.htmlSent from the GeoNetwork users mailing list
This SF.net Dev2Dev email is sponsored by:
Show off your parallel programming skills.
Enter the Intel(R) Threading Challenge 2010.
http://p.sf.net/sfu/intel-thread-sfd
GeoNetwork-users mailing list
Hi Paolo,
And another way maybe from Francois you can try:
http://osgeo-org.1803224.n2.nabble.com/maxClauseCount-Problem-td5493735.html#a5493735
2010/9/3 Kai Liu <kliu4@anonymised.com>:
Hi All,
We've havested 440K metadata to GEOSS clearinghouse(http://clearinghouse.cisc.gmu.edu/geonetwork).
But When I do the boundingbox search, the following problem occurs:
<error id="error">
<message>maxClauseCount is set to 32768</message>
<class>TooManyClauses</class>
<stack>
   <at class="org.apache.lucene.search.BooleanQuery" file="BooleanQuery.java" line="153" method="add" />
   <at class="org.apache.lucene.search.BooleanQuery" file="BooleanQuery.java" line="144" method="add" />
   <at class="org.apache.lucene.search.MultiTermQuery$ScoringBooleanQueryRewrite" file="MultiTermQuery.java" line="110" method="rewrite" />
   <at class="org.apache.lucene.search.MultiTermQuery" file="MultiTermQuery.java" line="382" method="rewrite" />
   <at class="org.apache.lucene.search.RangeQuery" file="RangeQuery.java" line="106" method="rewrite" />
   <at class="org.apache.lucene.search.BooleanQuery" file="BooleanQuery.java" line="438" method="rewrite" />
   <at class="org.apache.lucene.search.IndexSearcher" file="IndexSearcher.java" line="307" method="rewrite" />
   <at class="org.apache.lucene.search.Query" file="Query.java" line="98" method="weight" />
   <at class="org.apache.lucene.search.Searcher" file="Searcher.java" line="230" method="createWeight" />
   <at class="org.apache.lucene.search.Searcher" file="Searcher.java" line="171" method="search" />
</stack>
<request>
   <language>en</language>
   <service>main.search.embedded</service>
</request>
</error>
When I increase the maxClauseCount to (Integer.MAX_VALUE) but this will trigger out of memory exception and the boundingbox search still doesn't work.
The version we used is 2.4.3. Is there a way to avoid maxClauseCount Problem when boundingbox search is done?
I've one node with 140K records and don't face that issue for now. An
option could be to switch from northBL, southBL, eastBL and westBL
parameters to the geometry parameter (geometry=POLYGON(...)) which use
the spatial index instead of Lucene for the spatial part of the
search... but you need to make some changes to the JS for that (see
gn_search.js).
Cheers.
Francois
Thanks and best regards,
Kai
703-395-2337
Kai
703-395-2337
performing some
Bye
Paolo
Hi Kai and Paolo,
2010/9/8 Kai Liu <kliu4@anonymised.com>:
Hi Paolo,
Another option is also to use precise search using a similarity
parameter set to 1 instead of .8 by default.
OpenSearch suggestion could help to suggest indexed terms to users
before searching and then make precise search instead of fuzzy ones.
Francois.
Hi All,
<error id="error">
<stack>
</stack>
<request>
</request>
</error>
gn_search.js).
Cheers.
Francois
Kai
703-395-2337
Kai
703-395-2337
performing some
Bye
Paolo
this sounds like I have to change a java class... I'm not a java expert so
I'll try other ways first.
I mean, I have a GN 2.1 node up and running that is harvesting the same FAO
node. The same search doesn't cause the maxClauseCount Problem as the GN
2.4.3 (i.e. keyword: boundaries and country: Madagascar, selected from the
drop down menu).
But if you try the same Madagascar search on the FAO GN
(http://www.fao.org/geonetwork) it causes the problem! Could it be a problem
with the Lucene index?
Bye
Paolo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fwd-maxClauseCount-Problem-tp5495565p5513940.html
