[GeoNetwork-users] Maximum upload size
Dear Geonetwork team,
How can I increase the Maximum upload size from 100MB to 500MB or more in versions 3.2 and 2.10? when I change the MaxUploadSize variable on config.xml or add a configuration for it to config-spring-geonetwork.xml, It does not work. Can you please tell me how to solve this problem? This is a big issue for our company because many of our files are more than 100MB and our data management team has to spend too much time on preprocessing those files and then uploading them.
Best,
Samin Payro
Center of Development Research
University of Bonn
Hi Samin
In *3.2.x versions *should be using Spring MVC for uploads (although can
still be some services using old jeeves):
1) For Spring MVC services, it's defined in
https://github.com/geonetwork/core-geonetwork/blob/3.2.x/services/src/main/resources/config-spring-geonetwork.xml#L62-L65
The problem with that configuration file is that is packaged in a jar, so
most probably you'll need to checkout the source code and rebuild the
module with the new configuration value. Or to unzip the current jar,
update the file and package it again.
This is not really nice, I have open a issue in GitHub to track this:
https://github.com/geonetwork/core-geonetwork/issues/2030
2) For possible services using still old jeeves, I recommend also to update
the config.xml also.
For *2.10.x versions*, afaik no Spring MVC is used, so the update in
config.xml should work (requires restarting Geonetwork).
Jose García
On Mon, Jun 19, 2017 at 2:26 PM, Samin Payrosangari <s6sapayr@anonymised.com>
Best,
Samin Payro
University of Bonn
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Dear jose,
I have deployed the .war file for version 3.2 using tomcat. You mean for the .war file I should undeploy the current version I have, unzip it, change the config-spring-geonetwork.xml, zip it again, then deploy with tomcat again?
For version 2.10 unfortunately your solution does not work. What could be the problem? MAybe with tomcat or something?
Best,
Samin Payro
University of Bonn
On Mon, 19 Jun 2017 14:45:43 +0200
  Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Samin
Jose García
Best,
Samin Payro
University of Bonn
s/geonetwork
Hi Samin
No idea what can be the issue in 2.10, I have a version running 2.10 and
just changing this value looks working fine:
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/WEB-INF/config.xml#L8
Have you restart GeoNetwork after the change?
Jose García
On Tue, Jun 20, 2017 at 4:44 PM, Samin Payrosangari <s6sapayr@anonymised.com>
wrote:
Dear jose,
tomcat again?
Best,
Samin Payro
University of Bonn
Hi Samin
update
Jose García
is
Best,
Samin Payro
University of Bonn
s/geonetwork
+31
Dear Jose,
We have the official version. Actually decreasing the upload size from 100Mb works fine for us too. But increasing it to 200Mb does not work.
Also in geonetwork 3.2 when I increased the maxuploadsize to 200Mb and tried to upload a 165Mb file, it did not show an error but it was unable to finish uploading and nothing occured.
Then I undeployed and deployed the geonetwork as you said I should do after changing config-spring-geonetwork.xml and config.xml. The the only thing that happens is that although the maxuploadsize is set to 200Mb, when I try to upload the 165Mb file it releases an error of uploading a big file. I think there is another file which manages the maxuploadsize.
Best,
Samin Payro
Center for Development research,
University of Bonn
On Tue, 4 Jul 2017 14:18:22 +0200
Hi Samin
I have done a test with the 2.10.4 installer (
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v2.10.4/geonetwork-install-2.10.4-0.jar/download
I changed to 1 Mb in geonetwork/WEB-INF/config.xml
  <general>
               <profiles>user-profiles.xml</profiles>
               <!-- Size must be in megabyte (integer), 100MB by default
               <maxUploadSize>1</maxUploadSize>
               <uploadDir>./data/tmp</uploadDir>
               <debug>true</debug>
  </general>
and tried to upload to a metadata a file bigger of 15Mb, getting an error
in the console and also in the metadata editor an error message:
2017-07-04 14:12:41,830 INFO [jeeves.request] - HTML Request (from
0:0:0:0:0:0:0:1) : /geonetwork/srv/eng/resource.upload.and.link
2017-07-04 14:12:41,835 ERROR [jeeves.request] - File upload too big -
exceeds 1 Mb
Error : jeeves.exceptions.FileUploadTooBigEx
Stack :
FileUploadTooBigEx : File upload too big
at
jeeves.server.sources.ServiceRequestFactory.getMultipartParams(ServiceRequestFactory.java:324)
at
jeeves.server.sources.ServiceRequestFactory.extractParameters(ServiceRequestFactory.java:252)
at
jeeves.server.sources.ServiceRequestFactory.create(ServiceRequestFactory.java:150)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:187)
Restored to 100Mb and could upload it:
<general>
               <maxUploadSize>100</maxUploadSize>
               <debug>true</debug>
  </general>
It's strange there's no error in the log file for you. Do you have a custom
version of 2.10 or it's the official version?
Jose García
On Mon, Jul 3, 2017 at 4:58 PM, Samin Payrosangari <s6sapayr@anonymised.com>
wrote:
Dear Jose,
Yes, I restarted geonetwork, I am so confused with this problem.
Best,
Samin
On Mon, 3 Jul 2017 14:38:15 +0200
Hi Samin
Jose García
wrote:
Dear jose,
tomcat again?
Best,
Samin Payro
University of Bonn
Hi Samin
so
update
Jose García
in
This
is
100MB
preprocessing
Best,
Samin Payro
University of Bonn
s/geonetwork
+31
+31
