Hallo,
I have serious problems with importing thumbnails. I wrote a Java program, which is parsing shapefiles and acompanying aux. information and creates valid metadata.xml, and info.xml along with rendered thumbnail images. The output of the program is a) a valid .mef file and b) the not zipped mef as folder with its public subfolder and the thumbnails in there. If I use the mef import in gast of gn2.1 the data are correctly imported except for the thumbnails which do not show up in the web frontend. the funny thing is, when i create the zip (mef) archive manually from the folder and import it again with gast, the thumbnails show up. another thing i realized is, that both mef archives (the java generated and the manually zipped) differ in size, even if there content files are exactly the same.
does anybody know what might be the problem?
thanks a lot.
steffen
ps: i work on windows.
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Hi Steffen,
Do you have the mef files concerned somewhere available that we could look at them?
Jeroen
On Oct 26, 2007, at 2:37 PM, Steffen Gebhardt wrote:
Hallo,
thanks a lot.
steffen
Ideal für Modem und ISDN: GMX Handytarife 2024 | jetzt wechseln & sparen
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
yes, of course. See attached files.
Steffen.
-------- Original-Nachricht --------
Datum: Mon, 29 Oct 2007 07:59:54 +0100
Von: Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>
An: Steffen Gebhardt <steffen_gebhardt@anonymised.com>
CC: geonetwork-users@lists.sourceforge.net
Betreff: Re: [GeoNetwork-users] MEF import thumbnail problem
Hi Steffen,
look at them?
Jeroen
> Hallo,
> thanks a lot.
> steffen
> browser.
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at http://sourceforge.net/
> projects/geonetwork
GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS.
Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail
(attachments)
7f5c94fe-586f-4b76-899b-aeb09115f962.mef (14.3 KB)
421e1633-e5f3-4fe6-8d3c-375e1661690d.mef (5.71 KB)
Hi Steffen,
I compared the two files. It seems that the embedded thumbnails are significantly different in the two files:
ticheler:~/Desktop/mef ticheler$ unzip -vl 421e1633-e5f3-4fe6-8d3c-375e1661690d.mef
Archive: 421e1633-e5f3-4fe6-8d3c-375e1661690d.mef
Length Method Size Ratio Date Time CRC-32 Name
2485 Defl:N 2483 0% 10-29-07 08:50 f1c9c8d8 /public/thumb.gif
776 Defl:N 760 2% 10-29-07 08:50 2e4e228b /public/thumb_s.gif
728 Defl:N 361 50% 10-29-07 08:50 f2121b9f info.xml
4952 Defl:N 1745 65% 10-29-07 08:50 f9c4e311 metadata.xml
8941 5349 40% 4 files
ticheler:~/Desktop/mef ticheler$ unzip -vl 7f5c94fe-586f-4b76-899b-aeb09115f962.mef
Archive: 7f5c94fe-586f-4b76-899b-aeb09115f962.mef
9386 Defl:N 9298 1% 10-29-07 08:50 cfba58e0 /public/thumb.gif
2731 Defl:N 2710 1% 10-29-07 08:50 bacf11f3 /public/thumb_s.gif
728 Defl:N 359 51% 10-29-07 08:50 078bf0d0 info.xml
4938 Defl:N 1729 65% 10-29-07 08:50 0a999216 metadata.xml
17783 14096 21% 4 files
Taking a closer look at the metadata, they even concern different data sets. So I can't compare a working with a non working version of the same data
3c3
< <mdFileID>7f5c94fe-586f-4b76-899b-aeb09115f962</mdFileID>
> <mdFileID>421e1633-e5f3-4fe6-8d3c-375e1661690d</mdFileID>
73c73
< <resTitle>Tam Nong boundary</resTitle>
> <resTitle>Tam Nong roads</resTitle>
154c154
< <idAbs>Tam Nong boundary.shp</idAbs>
> <idAbs>Tam Nong roads.shp</idAbs>
To check, I need both files you said are identical (Java zipped and manually zipped).
Ciao,
Jeroen
On Oct 29, 2007, at 6:34 PM, Steffen Gebhardt wrote:
Steffen.
Von: Jeroen Ticheler <Jeroen.Ticheler@...5...>
An: Steffen Gebhardt <steffen_gebhardt@...38...>
Hi Steffen,
look at them?
Jeroen
Hallo,
thanks a lot.
steffen
browser.
projects/geonetwork
Alle Infos und kostenlose Anmeldung: GMX E-Mail ✉ sichere & kostenlose E-Mail-Adresse ✉
<7f5c94fe-586f-4b76-899b-aeb09115f962.mef>
<421e1633-e5f3-4fe6-8d3c-375e1661690d.mef>
