[GeoNetwork-users] metadata records not visible in the web interface
Hello,
I am using GeoNetwork 3.4.3. The records on my catalogue are mainly in
french. When I use the web interface, some of these records are only
visible when the french language on the interface is selected. If I choose
any other language, this records are not visible, as if they didn't exist
(even if I search for the record with the exact ID, it wont appear on the
search results). The problem occurs only with some of the records : I
attach one of them here.
Is there a way to get to see all my records regardless of the language
selected on the interface ?
(The problem occurs only with the web interface, the CSW interface works
fine.)
Thanks in advance
María IBARRA
(attachments)
IGNF_ORTHO-SATr_1-0_WALLIS-ET-FUTUNA_2015032979573680.xml (61.5 KB)
Hi Maria, maybe you played with
https://geonetwork-opensource.org/manuals/3.8.x/en/administrator-guide/configuring-the-catalog/system-configuration.html?#multilingual-settings
? "All
documents in all languages (No preferences)" is probably a good default
value.
HTH
Francois
Le mar. 7 janv. 2020 à 17:42, María del Mar Ibarra <
mariadelmariv22@anonymised.com> a écrit :
Hello,
fine.)
Thanks in advance
María IBARRA
GeoNetwork-users mailing list
