[GeoNetwork-users] Metadata validation and Inspire rules for the conformance degree [SEC=UNCLASSIFIED]
I re-open the topic about the INSPIRE conformity and ISO 19139 :
- Conformity degree :
Conforme ===> <gmd:result><gmd:DQ_ConformanceResult>...<gmd:pass><gco:Boolean>true</gco:Boolean></gmd:pass>
    </gmd:DQ_ConformanceResult></gmd:result>
Not Conforme ===> <gmd:result><gmd:DQ_ConformanceResult>...<gmd:pass><gco:Boolean>false</gco:Boolean></gmd:pass>
Not evaluated ===> <gmd:result gco:nilReason="inapplicable"/>
Resource locator - connect point
<gmd:MD_DigitalTransferOptions><gmd:onLine><gmd:CI_OnlineResource><gmd:linkage>XXXXX</gmd:linkage></gmd:CI_OnlineResource>
</gmd:onLine></gmd:MD_DigitalTransferOptions></gmd:transferOptions></gmd:MD_Distribution>
Coupled resource
  ISO 19119 specificiation ==> <operatesOn xmlns="srv" uuidref="2837462ZEHS28272"/>
Classification of spatial data services ( Geographic service )
       ISO 19119 specification ==> <srv:serviceType><gco:LocalName>infoMapAccessService</gco:LocalName></srv:serviceType>
Pierre
-----Message d'origine-----
De : geonetwork-users-bounces@lists.sourceforge.net [mailto:geonetwork-users-bounces@lists.sourceforge.net] De la part de FBachraty
Envoyé : lundi 7 janvier 2008 09:53
À : geonetwork-users@lists.sourceforge.net
Objet : Re: [GeoNetwork-users] Metadata validation and Inspire rules for the conformance degree [SEC=UNCLASSIFIED]
So for the moment, i have to do the choice between the Inspire conformity and the ISO 19139 one :wink:
Anyway i think that for the moment the INSPIRE conformity is not possible with ISO19139 for this field and others like :
  Coupled resource
Thank you John for your answer.
Fabien Bachraty.
John.Hockaday wrote:
Hi Fabien,
ISO 19115 is implemented into XML using ISO 19139. ISO 19139 defines
the gco:boolean element as type xs:boolean. The definition of an
xs:boolean type
is:
"An instance of a datatype that is defined as boolean can have the
following legal literals {true, false, 1, 0}."
Therefore, the only values available are "true", "false", "1" or "0".
Hence
the INSPIRE use is incorrect unless INSPIRE has redefined the XML
implementation of the boolean type.
I hope that this helps.
John
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of
FBachraty
Sent: Saturday, 22 December 2007 1:49 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Metadata validation and Inspire rules for
Hello,
A question about the Quality conformity degree
<gmd:dq_conformanceresult>
  <gmd:pass>
    <gco:boolean>0</gco:boolean>
  </gmd:pass>
</gmd:dq_conformanceresult>
In the Inspire rules for the conformance test, the degree is
specified as the level of conformity of the resource to the related
specification. The value domain of this metadata element is :
1. Conformant :The resource is fully conformant with the cited
specification 2. Not Conformant : The resource does not conform with
the cited specification 3. Not evaluated : Conformance has not been
evaluated
But on the Geonetwork the values defined for the field are 0=fail and
1=pass.
Witch is the good specification : The Inspire or the Geonetwork one ?
For the moment the problem is that I can not fill in the value "2 or
3" on the degree metadata element or the metadata can not be
validated.
  <gmd:pass>
    <gco:boolean>0/1</gco:boolean>
  </gmd:pass>
>> Valide
  <gmd:pass>
    <gco:boolean>2/3</gco:boolean>
  </gmd:pass>
>> Not Valide
Thank you.
Fabien Bachraty
View this message in context:
http://www.nabble.com/Metadata-validation-and-Inspire-rules-fo
r-the-conformance-degree-tp14456579s18419p14456579.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
--- This SF.net email is sponsored by: Microsoft Defy all challenges.
Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Re%3A-Metadata-validation-and-Inspire-rules-for-the-conformance-degree--SEC%3DUNCLASSIFIED--tp14588630s18419p14660398.html
Defy all challenges. Microsoft(R) Visual Studio 2005.
Pensez à l'environnement avant d'imprimer ce message
Think Environment before printing
Le contenu de ce mél et de ses pièces jointes est destiné à l'usage exclusif du (des) destinataire(s) désigné
(s)
comme tel(s).
En cas de réception par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifiée à l'émission, il convient néanmoins de s'assurer de l'absence de
contamination à sa réception.
The contents of this email and any attachments areconfidential. They are intended for the named recipient
(s)
only.
If you have received this email in error please notifythe system manager or the sender immediately and do
not
disclose the contents to anyone or make copies.
eSafe scanned this email for viruses, vandals and malicious content.
Thank you very much Pierre for this interesting precision !
Best regards,
Fabien Bachraty
Lagarde Pierre wrote:
Conforme ===>
Not Conforme ===>
Coupled resource
Pierre
FBachraty
  Coupled resource
Fabien Bachraty.
Hi Fabien,
xs:boolean type
is:
Hence
John
FBachraty
Hello,
  <gmd:pass>
  </gmd:pass>
evaluated
1=pass.
validated.
  <gmd:pass>
  </gmd:pass>
>> Valide
  <gmd:pass>
  </gmd:pass>
>> Not Valide
Thank you.
Fabien Bachraty
View this message in context: http://www.nabble.com/Re%3A-Metadata-validation-and-Inspire-rules-for-the-conformance-degree--SEC%3DUNCLASSIFIED--tp15475491s18419p15475685.html
