I must modify the Create/Insert Schemas. Can someone call the associated java classes.
I work with geonetwork 2.2.0.
Thanks and best regards
Joerg
Joerg
Hi Joerg,
What do you mean by "I must modify the Create/Insert Schemas".
May this tutorial help you ?
http://geonetwork-opensource.org/documentation/how-to/geonetwork-v2-2-shema-template-howto
Feel free to give list more details,
HTH
Mathieu
On Fri, Mar 6, 2009 at 9:54 AM, Joerg Matthes <Joerg.Matthes@anonymised.com> wrote:
java classes.
I work with geonetwork 2.2.0.Thanks and best regards
Joerg------------------------------------------------------------------------------
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco,
CA
-OSBC tackles the biggest issue in open source: Open Sourcing the
Enterprise
-Strategies to boost innovation and cut costs with open source
participation
-Receive a $600 discount off the registration fee with the source code:
SFAD
http://p.sf.net/sfu/XcvMzF8H
GeoNetwork-users mailing list
Mathieu Coudert
mcoudert@anonymised.com
thanks for the link.
Ok we need another textbox in the forms of metadata-create.xsl and
metadata-insert-form.xsl.
I have added a textbox in these schemas files, now the value of the
textbox must send to the next form and then with the metadates in the
database. So I need the associated java classes for the
metadata-create.xsl and java classes to write the metadata data in the db.
As db we use mysql and have create a new field in the table metadata.
The sourcen are installed, but I don 't know which classes are correct.
Joerg
Mathieu Coudert schrieb:
Hi Joerg,
http://geonetwork-opensource.org/documentation/how-to/geonetwork-v2-2-shema-template-howtoFeel free to give list more details,
HTHCheers,
MathieuOn Fri, Mar 6, 2009 at 9:54 AM, Joerg Matthes <Joerg.Matthes@anonymised.com
<mailto:Joerg.Matthes@anonymised.com>> wrote:Hi all,
associated
java classes.
Francisco, CA
Enterprise
participation
code: SFAD
<mailto:GeoNetwork-users@lists.sourceforge.net>
http://sourceforge.net/projects/geonetwork--
Mathieu Coudert
mcoudert@anonymised.com <mailto:mcoudert@anonymised.com>
Joerg,
Here you have some clues to help you go ahead...
First, metadata create form calls the metadata.create service as you can see
below :
<form name="createform" accept-charset="UTF-8"
action="/geonetwork/srv/fr/metadata.create" method="post">
Then, if you have a look to the xml config file for metadata service
(config-metadata.xml) you will have the description of the metadata.create
service, described below :
<service name="metadata.create">
<class name=".services.metadata.Create"/>
<output forward="metadata.edit" />
</service>
You can then see that called java class is : Create (Create.java file in
package org.fao.geonet.services.metadata).
So you just have to modifiy this class to get your param(s) and insert them
into your current database (using dbms).
HTH,
Mathieu
On Fri, Mar 6, 2009 at 12:57 PM, Joerg Matthes <Joerg.Matthes@anonymised.com> wrote:
metadata-create.xsl and java classes to write the metadata data in the db.As db we use mysql and have create a new field in the table metadata.
The sourcen are installed, but I don 't know which classes are correct.Joerg
> Hi Joerg,
> HTH
> Cheers,
> Mathieu
> Hi all,
> associated
> java classes.
> Joerg
> Francisco, CA
> Enterprise
> participation
> code: SFAD
> Mathieu Coudert
Mathieu Coudert
Hi Mathieu,
best Thanks, this will help us.
Best regards
Jörg
Joerg,
below :<form name="createform" accept-charset="UTF-8"
action="/geonetwork/srv/fr/metadata.create" method="post">Then, if you have a look to the xml config file for metadata service
service, described below :<service name="metadata.create">
<class name=".services.metadata.Create"/><output forward="metadata.edit" />
</service>You can then see that called java class is : Create (Create.java file in
package org.fao.geonet.services.metadata).So you just have to modifiy this class to get your param(s) and insert them
into your current database (using dbms).HTH,
MathieuOn Fri, Mar 6, 2009 at 12:57 PM, Joerg Matthes <Joerg.Matthes@anonymised.com> wrote:
Hi Joerg,
HTHCheers,
associated
java classes.
Francisco, CA
Enterprise
participation
code: SFAD
Mathieu Coudert
Using svn trunk, when updating my user information
(/geonetwork/srv/en/user.infoedit?id=$id when logged in as a user,
/geonetwork/srv/en/user.get?id=$id when logged in as admin), I find most
of the form nicely organized.
I notice that there is no "City" field for user information. Where is a
user's City information supposed to go? Can we add this as a field?
This would (at least) involve:
- alter table Users add column city varchar(128)
- updating the user information form
- updating the code between the form and the db
There may be other areas.
Comments? If this is useful/viable, I can file a ticket.
..Tom
Hi Tom,
Yes, I think you would best file a ticket and possibly provide the patch if you have it.
Ciao,
Jeroen
of the form nicely organized.I notice that there is no "City" field for user information. Where is a
This would (at least) involve:- alter table Users add column city varchar(128)
- updating the code between the form and the dbThere may be other areas.
..Tom
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
Best Open Source Mac Front-Ends 2024
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
