Hi
I have installed GN3 on Postgres, all is fine. Installed in the "public"
schema of Postgres.
But I would move tables in other shema, I have done it with just a table
("user"), but without success, GN do not run like this
Is it possible ?
Thank you !
You could set the search_path to make your schema accessible without a
prefix.
ALTER DATABASE myDB SET search_path = geonetwork,public ;
On Fri, May 22, 2015 at 3:21 PM, Georges H <georges.hinot@anonymised.com> wrote:
Hi
schema of Postgres.
Is it possible ?
Thank you !
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
Application Monitoring Software and Tool - ManageEngine Applications Manager
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
OK thanks
But I have run this command, after having moved the table "users", and the
connexion do not run on GN.
Is it important to move all the tables on my geonetwork schema before run
this command ?
2015-05-22 15:44 GMT+02:00 Florent Gravin <florent.gravin@anonymised.com>:
prefix.
wrote:
Hi
schema of Postgres.
Is it possible ?
Thank you !
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Florent Gravin
0479444492
*Georges Hinot*
*CNRS - DRIIHM - UMS BBEES (3468)*
Musée d'Histoire Naturelle de Paris, Maison Buffon
Géomaticien - Administrateur BDD - Intégrateur
*Tél : 01 40 79 80 44*
*Tél : 06 47 61 84 92*
Le nouveau site DRIIHM-ROHM ! <http://driihm.fr>
this command ?
No it should'nt, but what error do you have exactly ?
On Fri, May 22, 2015 at 4:51 PM, Georges H <georges.hinot@anonymised.com> wrote:
OK thanks
this command ?
prefix.
wrote:
Hi
schema of Postgres.
Is it possible ?
Thank you !
Florent Gravin
0479444492
*Georges Hinot*
Florent Gravin
0479444492
OK, I go to retry with another GN3 and another Postgres, in oldest version.
But my first error was about "Lucene index", which, I think, refused to
re-create them.
2015-05-26 10:16 GMT+02:00 Florent Gravin <florent.gravin@anonymised.com>:
this command ?
wrote:
OK thanks
the connexion do not run on GN.
this command ?
prefix.
wrote:
Hi
schema of Postgres.
Is it possible ?
Thank you !
Florent Gravin
0479444492
*Georges Hinot*
Florent Gravin
0479444492
*Georges Hinot*
OK ! I think it is necessary to restart the VM after have to move tables in
other schema.
2015-05-26 11:15 GMT+02:00 Georges H <georges.hinot@anonymised.com>:
re-create them.
this command ?
wrote:
OK thanks
run this command ?
prefix.
wrote:
Hi
"public"
schema of Postgres.
table
Is it possible ?
Thank you !
Insights
Florent Gravin
0479444492
*Georges Hinot*
Florent Gravin
0479444492
*Georges Hinot*
*Georges Hinot*
