[GeoNetwork-users] NullPointerException on login
Can someone help with the NullPointerException error I've suddenly started
getting at login? All was working fine yesterday.
Log is below.
Thanks
Dan
2011-12-07 15:48:12,597 ERROR [jeeves.service] - Exception when executing
service
2011-12-07 15:48:12,597 ERROR [jeeves.service] - (C) Exc :
java.lang.NullPointerException
2011-12-07 15:48:12,597 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">^M
  <message />^M
  <class>NullPointerException</class>^M
  <stack>^M
    <at class="org.fao.geonet.services.login.Login" file="Login.java"
line="68" method="exec" />^M
    <at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService" />^M
file="ServiceInfo.java" line="141" method="execServices" />^M
    <at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="399" method="dispatch" />^M
    <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="670" method="dispatch" />^M
    <at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="185" method="execute" />^M
file="JeevesServlet.java" line="108" method="doPost" />^M
    <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="637" method="service" />^M
line="717" method="service" />^M
    <at class="org.apache.catalina.core.ApplicationFilterChain"
file="ApplicationFilterChain.java" line="290" method="internalDoFilter" />^M
  </stack>^M
  <request>^M
    <language>en</language>^M
    <service>user.login</service>^M
  </request>^M
</error>
2011-12-07 15:48:12,603 INFO [jeeves.service] - -> dispatching to error
for : user.login
2011-12-07 15:48:12,607 ERROR [jeeves.service] - Exception executing gui
service : java.lang.NullPointerException
2011-12-07 15:48:12,607 ERROR [jeeves.service] - (C) Stack trace is :
        at org.fao.geonet.guiservices.util.Env.exec(Env.java:55)
        at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
        at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:119)
        at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:103)
        at
jeeves.server.dispatchers.ServiceManager.dispatchError(ServiceManager.java:757)
        at
jeeves.server.dispatchers.ServiceManager.handleError(ServiceManager.java:498)
        at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:443)
        at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:670)
        at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:185)
        at
jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:108)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
        at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
        at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
        at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
        at java.lang.Thread.run(Thread.java:619)
2011-12-07 15:48:12,614 INFO [jeeves.service] - -> transforming with
stylesheet : /usr/apache-tomcat-6.0/webapps/geonetwork/xsl/error.xsl
2011-12-07 15:48:12,615 DEBUG [jeeves.engine] - TransformerFactoryFactory:
de.fzi.dbs.xml.transform.CachingTransformerFactory
produces transformer implementation net.sf.saxon.IdentityTransformer
2011-12-07 15:48:12,648 INFO [jeeves.service] - -> end error
transformation for : user.login
2011-12-07 15:48:12,649 INFO [jeeves.service] - -> error ended for :
user.login
hi Dan,
a NPE at login is usually when you have no connection to the database. Can
you still search and view metadata without logging in ? Then it's not that.
Kind regards
Heikki Doeleman
On Wed, Dec 7, 2011 at 4:54 PM, Dan Lear <dblear@anonymised.com> wrote:
Log is below.
Thanks
Dan
service
executing service
<message />^M
<stack>^M
/>^M
</stack>^M
<request>^M
</request>^M
</error>
for : user.login
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
user.login
Cloud Services Checklist: Pricing and Packaging Optimization
This white paper is intended to serve as a reference, checklist and point
of
discussion for anyone considering optimizing the pricing and packaging
model
of a cloud services business. Read Now!
http://www.accelacomm.com/jaw/sfnl/114/51491232/
GeoNetwork-users mailing list
Heikki,
Thanks for the advice, searching for metadata also triggers a NPE error, so
does that mean I’m looking at a db connection error? It’s a more or less
vanilla install and I haven’t modified the db connections at all. Where
should I start looking to put it right? Sorry but this is all new to me!
Thanks Dan
On Dec 7, 2011 4:03 PM, "heikki" <tropicano@anonymised.com> wrote:
hi Dan,
Kind regards
Heikki Doeleman
Log is below.
Thanks
Dan
service
executing service
<message />^M
<stack>^M
/>^M
</stack>^M
<request>^M
</request>^M
</error>
error
for : user.login
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
user.login
of
model
Ah, OK. And did you set up a database ?
You have first to create and pre-populate a database (in mysql, postgresql
or other) for it to work.
2011/12/8 Dan Lear <dblear@anonymised.com>
Hi Jean,
GAST doesn't appear to be installed. It's running on a Fedora 11 box and
installed from the .war.
Thanks
Dan
On Thu, Dec 8, 2011 at 9:47 AM, Jean Pommier (IGE) <jean.pommier@anonymised.com.>wrote:
Have you first created the database with GAST ? I guess it should be the
problem..
Jean
2011/12/7 Dan Lear <dblear@anonymised.com>
Heikki,
so
Thanks Dan
> hi Dan,
Can
that.
> Kind regards
> Heikki Doeleman
>> Hi,
started
>> Log is below.
>> Thanks
>> Dan
executing
>> service
while
>> executing service
>> <message />^M
>> <stack>^M
>> />^M
>> </stack>^M
>> <request>^M
>> </request>^M
>> </error>
>> error
>> for : user.login
gui
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
with
for :
>> user.login
point
>> of
>> model
>> _______________________________________________
point of
model
N'imprimez ce message qu'en cas de nécessité. Soyons éco-responsables !
Donnez une nouvelle dimension à vos données
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Port : +33 6 09 23 21 36
Skype : igejean
Information Géographique et Environnement
12 rue Arnaud Vidal
31000 Toulouse
France
Tel : +33 5 61 86 81 49
Fax : +33 5 61 86 09 23
Mail : contact@anonymised.com
Site web : www.ige.fr <http://wwww.ige.fr/&gt;
*L'actualité d'IGE sur RSS : *http://www.ige.fr/actualites/rss.php
*Localisez IGE dans WorldWind : *
worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
- Afficher le texte des messages précédents -
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
